1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Access security problem
To: <[email protected]>
Date: Thu, 10 Sep 2009 10:43:04 +0200
Dear Andrew,
I think you are wrong. Remember that the CALC expression must return TRUE or FALSE which will not be the case with A&2, A&4 ...
I guess my scheme is correct. Everything works except this problem with this spiral2mgr user that I don't understand (see the table below from my previous mail). We will try to overcome it in a way or another ... unless somebody has another idea about it !!!
J.F. Gournay
CEA Saclay
IRFU/SIS
-----Message d'origine-----
De : Andrew Johnson [mailto:[email protected]]
Envoyé : mercredi 9 septembre 2009 16:56
À : [email protected]
Cc : GOURNAY Jean-Francois
Objet : Re: Access security problem
On Wednesday 09 September 2009 07:34:52 GOURNAY Jean-Francois wrote:
> I did more systematic tests and I have this strange situation:
> ASGVAL  UAG      spiral2  spiral2mgr      gournay
> 1       tous      W        W               W        OK
> 2       develop   -        - (should be W) -        WRONG
> 4       physique  W        -               -        OK
> 8       gournay   -        W (should be -) W        WRONG
> W : database WRITE access
> - :  no write access
> I modified the CALC expressions accordingly to Martin suggestion :
> CALC("A&1") instead of CALC("A&1=1").  But I don't think I have to write
> CALC (A>0&&A<2) as my A value comes from a longout record.
You're right there, but for historical reasons the relative precedence of
the ">>" and "=" operators are different in C and CALC, so you do need to
change your expressions:
>             CALC("A&1=1")
As Marty suggested "A&1" is sufficient here
>             CALC("A>>1=1")
CALC actually evaluates this as "A>>(1=1)" which is not what you mean.  You
could use "(A>>1)=1" but I would suggest "A&2" here instead.
>             CALC("A>>2=1")
"A&4"
>             CALC("A>>3=1")
"A&8"
Using fewer operators will also parse and execute faster.
> This message sent yesterday didn't show up.
That's because you actually sent it to tech-talk-bounces@aps., not to
tech-talk@aps., and I didn't get a chance to forward it manually before you
re-sent it.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: Access security problem Martin L. Smith
TR: Access security problem GOURNAY Jean-Francois
RE: Access security problem GOURNAY Jean-Francois
Re: Access security problem Andrew Johnson
Prev: Recommendation for digitizer? Rarback, Harvey M.
Next: Re: Access security problem Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Access security problem Andrew Johnson
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
