Mr. Expedient here.
With any luck, all the code in the sequencer uses MACRO_STR_LEN, and a change to something larger but static (perhaps 61 or 100?) might just work after a recompile. Doing something dynamic requires actual thinking and more extensive testing. How about an initial static bump with a subsequent dynamic solution?
Ron Chestnut
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Eric Norum
Sent: Wednesday, September 09, 2009 6:15 AM
To: [email protected] Techtalk
Subject: Re: sequencer feature request
Mr. Small IOC here.
Rather than allocating the maximum-sized space for every single name,
why not expand the name into a 'big-enough' buffer and then allocate
only the required size and copy the result?
On Sep 9, 2009, at 5:13 AM, Dirk Zimoch wrote:
> I found several places in the code where the sequencer uses
> MAX_STRING_SIZE+1 for string lengths of PV names and macros. In
> EPICS base MAX_STRING_SIZE is defined as 40. For example in
> seq_main.c:
> * Evaluate channel names by macro substitution.
> #define MACRO_STR_LEN (MAX_STRING_SIZE+1)
> LOCAL void seqChanNameEval(pSP)
> SPROG *pSP;
> CHAN *pDB;
> int i;
> pDB = pSP->pChan;
> for (i = 0; i < pSP->numChans; i++, pDB++)
> pDB->dbName = calloc(1, MACRO_STR_LEN);
> seqMacEval(pDB->dbAsName, pDB->dbName, MACRO_STR_LEN, pSP->pMacros);
> #ifdef DEBUG
> printf("seqChanNameEval: \"%s\" evaluated to \"%s\"\n",
> pDB->dbAsName, pDB->dbName);
> #endif /*DEBUG*/
> It might help to replace those uses of MAX_STRING_SIZE+1 with
> PVNAME_STRINGSZ.
> Dirk
> Dirk Zimoch wrote:
>> I tested the sequencer with a long name and it seems that it
>> truncates the PV name to 41 chars.
>> A seqChanShow shows the difference between the name used in assign
>> and the actual name used in CA:
>> Channel name: "DZ:45678901234567890123456789012345678901"
>> Unexpanded (assigned) name: "DZ:
>> 456789012345678901234567890123456789012345678901234567890"
>> Dirk
>> Mark Rivers wrote:
>>> EPICS base defines the maximum length of the PV name to be
>>> PVNAME_STRINGSZ, which is currently 61 including the nil terminator.
>>> What length limitation does the sequencer impose? Is it more
>>> restrictive than this?
>>> Mark
>>> ________________________________
>>> From: [email protected] on behalf of Patrick Thomas
>>> Sent: Thu 9/3/2009 6:29 PM
>>> Subject: sequencer feature request
>>> Hi,
>>> I was wondering if I could ask for a feature request for the next
>>> version of the sequencer? Is there any chance that it would be
>>> possible
>>> to use unlimited length record names in assign to statements?
>>> Thank you,
>>> Patrick
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: sequencer feature request Eric Norum
- sequencer feature request Patrick Thomas
- RE: sequencer feature request Mark Rivers
- Re: sequencer feature request Dirk Zimoch
2eSST??? Eric Bjorklund
RE: 2eSST??? Kalantari Babak
<2009>
<2009>
