Hi Eric,
1. Yes, I have recently done quite some
work on this issue (hopefully I will talk about it in EPICS meeting).
2. The bandwidth you get depends on the
hardware of course. I tried it on a SIS3302 ADC from Struck with mvme-6100 and
mvme-4100 SBC’s (vxWorks OS). In the best case I could get like 85 MB/s.
The guys in Struck told me that the highest rate they have measured is about 90
MB/s but they use a special self-developed PCI/cPCI-VME interface card to read
the data.
3. Yes, mvme-6100 and mvme-3100
BSP’s have a usable driver (much better than mvme-5100 / 2300) but you
have still to do some work. First issue is that you have to set the right
transfer protocol for the VME (outbound) window in use. If you always use the
same protocol (very unlikely!) you can hard code this only once in the BSP but
if you have boards with different protocols e.g. MBLT, 2eVME, etc. then you
have to be able to set the protocol of the corresponding window dynamically at
runtime. Second issue is that the API provided with the out-of-the-box BSP is
single-requester; meaning that while one DMA transfer is executing the second
transfer request is not accepted. Therefore the application program has to keep
retrying until his request gets accepted (at some time when DMA engine is not busy).
I have written a (BSP) driver on top of
the existing
routines which addresses above mentioned problems. We also use the same API for
all our SBC’s (mevme-6100, 4100, 5100, 2300 series) to ease writing and
maintaining our drivers/application programs.
Babak
PS: you may get a little bit better
rates by disabling the caching/snooping in the BSP but you have to then take
care of data consistency too.
This is another one of those "help me not re-invent the
wheel" surveys...
1. Is anyone currently using 2eSST DMA ?
2. If so, what kind of bandwidth are you getting, and,
3. Did you have to do anything special to get it to work? (e.g.
BSP mods, etc.)
-Eric Bj.
Los Alamos Neutron Science Center (LANSCE)
"The universe is
full of magical things,
patiently waiting for
our wits to grow sharper"
-- Eden Phillpotts
Correspondence
