1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn compiler problems
To: Pierrick Hanlet <[email protected]>
Date: Tue, 08 Sep 2009 12:54:04 -0700
Pierrick Hanlet wrote:
n attempting to build the asyn support package, v4.12, and even v4.11, I cannot even compile the
package.  Initially, I found some spurious characters in the dbd file.  I'm now stumped (and have
been since 08:00 today) with the compilation error message.
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/os/Linux -I../../include   -I/home/epics/epics/base/include/os/Linux -I/home/epics/epics/base/include        ../../asyn/asynRecord/asynRecord.c
../../asyn/asynRecord/asynRecord.c: In function ‘init_record’:
../../asyn/asynRecord/asynRecord.c:264: error: ‘asynRecord’ has no member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:272: error: ‘asynRecord’ has no member named ‘dpvt’
../../asyn/asynRecord/asynRecord.c:285: error: ‘asynRecord’ has no member named ‘udf’
../../asyn/asynRecord/asynRecord.c:296: error: ‘asynRecord’ has no member named ‘name’
It seems asyn cannot find dbCommon.dbd where all those fields are declared.
dbCommon is located in the epics base. So check where your config/configure files are pointing to. (did you 'make' the base?)
These members are defined in a number of /home/epics/epics/base/include files of different
record types.  Can (will) you kindly assist me?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
RE: asyn compiler problems Mark Rivers
asyn compiler problems Pierrick Hanlet
Prev: Re: TR: Access security problem Martin L. Smith
Next: RE: asyn compiler problems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: asyn compiler problems Eric Norum
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
