Hi Csaba,
Welcome to the EPICS community.
On Friday 04 September 2009 02:59:55 Csaba Gajo wrote:
> So it all compiled fine, I've set the environment variables in .bashrc:
> export EPICS_CA_ADD_LIST=127.0.0.1
The correct name for this variable is EPICS_CA_ADDR_LIST, and you don't
usually need to set it unless you're trying to communicate with IOCs on a
different IP subnet.
> export EPICS_ROOT=/opt/epics
> export EPICS_HOST_ARCH=linux-x86
> export EPICS_BASE=$EPICS_ROOT/base
> export EPICS_EXTENSIONS=$EPICS_ROOT/extensions
> export PATH=$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH
> export
> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EX
>TENSIONS/lib/$EPICS_HOST_ARCH:$EPICS_APPS/lib/$EPICS_HOST_ARCH
I'm interested why you think you have to set LD_LIBRARY_PATH - did you read
that in our documentation somewhere, and if so where? Recent versions of the
EPICS Base build rules do not require that you set LD_LIBRARY_PATH, and we
actually recommend *against* doing so unless it's really necessary. If you
need to build Base so it can be installed in a different location we provide
a better way to do that. The only time you should really need to set
LD_LIBRARY_PATH is if you don't know where the final install location is
going to be when you compile.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- Problems with installing EPICS Csaba Gajo
Re: Events Ralph Lange
RE: Events Dalesio, Leo
<2009>
RE: Problems with installing EPICS Rees, Nick (DLSLtd,RAL,DIA)
Events Csaba Gajo
<2009>
