You need to use the calcout record which can generate an event as spec'd
in the OEVT field. The event record and perhaps a few other record types
can generate events, which by the way are local to the IOC.
-ps
On 09/04/2009 10:46 AM Csaba Gajo wrote:
Hello,
I was reading the documentation about events, and was trying to make a
simple program to see how it works. In it I have a calc record, which
increments itself by 1 each second. When the values is 10, it raises a
HIHI signal.
I also have another calc record, whose SCAN field is Event, and it's
supposed to react when the value of the first calc reaches 10.
In the documentation, I was reading that when a user-defined event is
thrown, "all records will be processed whose SCAN field specifies
event and whose event number is the same as the generated event". So,
obviously HIHI is not a user-defined event. How should I throw an
event when the value of calc1 reaches 10?
Regards, Csaba
- Events Csaba Gajo
Events Csaba Gajo
Re: Events nda
<2009>
Events Csaba Gajo
Re: Events Ralph Lange
<2009>
