1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: asyn R4-12 released
To: <[email protected]>
Date: Thu, 20 Aug 2009 11:53:17 -0500
Folks,
asyn R4-12 has been released.  This is from the release notes:
asynManager
A problem was introduced in R4-11 by not starting the autoconnect
process until iocInit(), and operations that do not use the XXXSyncIO
functions thus fail before iocInit(). This means, for example, that
calls to asynSetOption() to set serial port parameters fail if done in a
startup script before iocInit(). R4-12 fixes this problem by decoupling
autoconnect operations from iocInit(). NOTE: The first call to the
pasynCommon->connect() function now happens almost immediately after
pasynManager->registerInterface() is called for the asynCommon
interface. This timing is different from all previous asyn releases, and
it means that port drivers must initialize everything required by
asynCommon->connect() before they register the asynCommon interface.
This may require minor re-ordering of the initialization sequence in
some drivers.
drvAsynSerialPort
Requests to set end-of-string values or serial port parameters are
accepted even when the port is not connected. The request takes effect
when the port is connected. This makes IOC startup more robust in the
face of network or USB to serial adapters that may be unavailable on
startup.
asynInt32Average, asynFloat64Average
If record is processed before new data have arrived (numAverage==0) set
record to UDF/INVALID, set UDF to TRUE and leave value unchanged.
asyn's home page is:
http://www.aps.anl.gov/epics/modules/soft/asyn/
Prev: Re: anyone seen this error Andrew Johnson
Next: Online access to ZTEC's EPICS oscilloscopes Boyd Shaw
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
