Mark Rivers wrote:
Hi Burkhard,
I'm glad to hear it is working for you.
I remembered what indicated a potential problem with Wago controllers in the NSLS driver. It appears that the address to read a particular register is different from the address to write that register. Normally each of my Modbus port drivers only reads or writes, not both. The exception is output drivers which can be configured to read once at iocInit to allow for a "bumpless" reboot, i.e. the output record value will match the current state of the hardware. If the Modbus addresses for write and read are not the same then this will not work. Have you tested this, i.e. do output records obtain the current values in the Modbus hardware when the IOC boots?
Cheers,
Sent: Fri 8/14/2009 7:51 AM
To: Mark Rivers
Subject: Re: uptodate version of modtcp?
Mark Rivers wrote:
I have an EPICS module called "modbus". It uses asyn, and works on all supported EPICS architectures (Linux, Windows, vxWorks, etc.). It supports TCP, serial RTU, and serial ASCII. It has been tested on a variety of Modbus devices, but probably not WAGO. Are you using a WAGO? I looked at the NSLS WAGO support when I was writing my package, and I recall that there was something strange about the way WAGO treated addresses. I didn't have a WAGO to test, so the driver may need a small addition to work on WAGO.
Here is the link:
http://cars.uchicago.edu/software/epics/modbus.html
Hi Mark,
thanks, it works out of the box also with WAGO. We have a 750-341
controller and several 750-460 (4 ch Pt100) modules. All I had to do
was modifying the startup script and the database.
Best regards,
Burkhard
Dr. Burkhard Kolb
HADES and CBM
E-Mail: [email protected]
Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2155
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker, Christiane Neumann
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Hi Mark,
no I could not test this. The modules I have are input registers
only (function code 4).
Cheers, Burkhard
- uptodate version of modtcp? Burkhard Kolb
- RE: uptodate version of modtcp? Mark Rivers
TDS3000 Support for edm Mathew Hicks
<2009>
RE: uptodate version of modtcp? So, Sung-Leung
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
