Subject: |
RE: CA reconnection problem |
"Jeff Hill" <[email protected]> |
To: |
"'Shepherd, Emma \(DLSLtd,RAL,DIA\)'" <[email protected]>, "'Rees, Nick \(DLSLtd,RAL,DIA\)'" <[email protected]>, "'Dirk Zimoch'" <[email protected]> |
Cc: |
"'Amedeo Perazzo'" <[email protected]>, "'Ernest L. Williams Jr.'" <[email protected]>, "'tech-talk'" <[email protected]> |
Date: |
Thu, 13 Aug 2009 19:06:08 -0600 |
> DB CA link does not connect through the gateway
I committed a PCAS change this evening to the R3.14 branch which is
hopefully a fix for this issue. See mantis entry 360. This fix, and a number
of other fixes to PCAS will be in R3.14.11 RC1. I also installed an upgrade
into the gateway so that it can now use ca_put for put requests and
ca_put_callback for put callback requests.
PS: These changes impact the CA gateway, but not IOCs.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Shepherd, Emma (DLSLtd,RAL,DIA) [mailto:[email protected]]
> Sent: Tuesday, August 11, 2009 3:00 AM
> To: Jeff Hill; Rees, Nick (DLSLtd,RAL,DIA); Dirk Zimoch
> Cc: tech-talk
> Subject: RE: CA reconnection problem
> Hi all,
> I've gone back through my notes as well to see what I can remember about
> this. I think part of the problem is that we have had several different
> issues at Diamond with similar symptoms:
> 1) The CAC-TCP-recv task gets suspended - I don't know what causes it but
> things are well and truly broken when this happens and we have to reboot
> the IOC. I haven't seen this in quite a while though.
> 2) A timerQueue task responsible for scheduling UDP requests gets
> suspended. In one investigation the task trace showed that an exception
> had been thrown and not handled properly - Mantis entry 336 was created
> for this and I believe you committed a fix Jeff.
> 3) Some CA links not working but nothing obvious wrong, no suspended
> tasks. Like in Dirk's case, the link is connecting through a gateway and
> re-writing the record name to the link can fix that particular link.
> I hope that helps to explain our situation at the moment, let me know if
> there's any more investigation I can do here.
> Emma
> > From: [email protected]
> > [mailto:[email protected]] On Behalf Of Jeff Hill
> > Sent: 11 August 2009 02:02
> > To: Rees, Nick (DLSLtd,RAL,DIA); 'Dirk Zimoch'
> > Cc: 'tech-talk'
> > I had another look at this issue this evening and suspect now
> > that the timer queue entries with negative delays reflect
> > only the time spent (on the order of 20 seconds) holding the
> > lock while dumping "dbcar" at high intrest levels to the slow
> > 9600 baud serial port.
> > So perhaps its best to step back a bit and look at what
> > Diamond and SLS have in common. It seems that both sites have
> > a db ca link connecting through the gateway when this occurs.
> > Dirk mentioned that R3.13 CA links connect fine at SLS, but
> > R3.14 ones don't. That can probably be explained by the fact
> > that the R3.13 ca client library disconnects both the circuit
> > and the application when a circuit is unresponsive. In
> > contrast, the R3.14 ca client library disconnects only the
> > application, and not the circuit when the circuit is
> > unresponsive relying instead on TCP to disconnect broken circuits.
> > So what probably is occurring is an issue with the gateway
> > where PCAS isn't properly scheduling itself to interact with
> > the R3.14 ca client's circuit, but the circuit remains
> > connected at TCP's level. In Dirk's situation I seem to
> > recall that a power outage was the precipitating event. A
> > precipitating event at Diamond maybe isn't identified?
> > There are an assortment of PCAS, and also gateway
> > improvements, coming soon in R3.14.11 RC1 but I'm not certain
> > that this one has been fixed. I will see if I can reproduce it.
> > Jeff
> > > Sent: Monday, August 10, 2009 11:05 AM
> > > To: 'Rees, NP (Nick)'; 'Dirk Zimoch'
> > > Cc: 'tech-talk'
> > > Nick, Dirk,
> > > > I think this is possibly the same problem we described in the
> > > > thread:
> > > > "Inter-IOC link problems"
> > > > http://www.aps.anl.gov/epics/tech-talk/2008/msg01103.php
> > > I vaguely recall that there was a mantis entry for the
> > above, but have
> > > had no success finding it. I did find 164 which is somewhat
> > close, but
> > > probably not the same issue. Also 330 (which will probably soon be
> > > assigned not-a- bug
> > > status) might be of some interest if you are seeing
> > unexpectedly long
> > > reconnect times with R3.14.
> > > Nevertheless, working only from my memory, it's not clear that Emma
> > > Shepherd's and Dirk's issues have the same symptoms. In Dirk's
> > > situation dbcar (at high interest levels) shows entries in the CA
> > > client library's timer queue with negative expiration which, as I
> > > recall, was not identified as a symptom with Emma Shepherd's
> > > situation? The tech-talk thread does indicate some close
> > examination
> > > of the dbcar output occurred, which probably
> > > would have immediately identified the negative expiration
> > times on the
> > > timer
> > > queue as a problem?
> > > In any case you now have a common symptom to look for with
> > dbcar the
> > > next time that it happens.
> > > Stack traces from _all_ of the dbca, CA client library, and timer
> > > threads involved will be the information I need to
> > determine a cause.
> > > When deciding on which threads traces to send, look at the threads
> > > operating at close to the same scheduling priority as dbca in the
> > > vxWorks "i" output. Emphasis on
> > > all because if there is a deadlock issue they can be tricky
> > to identify
> > > w/o
> > > clear understanding of the lock hierarchy interactions
> > between the two or
> > > more threads involved. Of course, if we have a deadlock
> > situation, then
> > > any
> > > threads that are continuously blocking on a mutex are of particular
> > > interest.
> > > Thanks for your help,
> > > Jeff
> > > > From: Rees, NP (Nick) [mailto:[email protected]]
> > > > Sent: Thursday, August 06, 2009 6:29 AM
> > > > To: Dirk Zimoch; Jeff Hill
> > > > Cc: tech-talk
> > > > Hi Dirk, Jeff,
> > > > thread:
> > > > That thread seemed to peter out because we basically developed
> > > > reboot workarounds that meant it didn't bother us as
> > much. However,
> > > > I don't think it was ever solved. I don't know whether there is a
> > > > Mantis entry for it.
> > > > Cheers,
> > > > Nick Rees
> > > > Principal Software Engineer Phone: +44 (0)1235-778430
> > > > Diamond Light Source Fax: +44 (0)1235-446713
> > > > > [mailto:[email protected]] On Behalf Of Dirk Zimoch
> > > > > Sent: 06 August 2009 10:22
> > > > > To: Jeff Hill
> > > > > Cc: 'tech-talk'
> > > > > Subject: Re: CA reconnection problem
> > > > > Hi Jeff,
> > > > > Time advances normally on the IOC.
> > > > > Bug 299 is not related because I have no suspended
> > tasks. Bug 330
> > > > > is also not related because my channels never reconnect, even
> > > > > after days.
> > > > > The IOC connects to the gateway with normal broadcasts on the
> > > > > local network. I can see beacons from all IOCs and
> > gateway and I
> > > > > can see the beacon anomaly when
> > > > > I start a softioc. Still the IOC does not send any search
> > > > > requests to reconnect
> > > > > the links. I can see the search requests from 3.13 IOCs,
> > > > > 3.14.8 medms and the
> > > > > gateway after a beacon anomaly, but not from 3.14.8 IOCs. It
> > > > > is definitely not
> > > > > the case that the 3.14.8 IOC never stops searching.
> > > > > I do not want to restart the gateway at the moment
> > because we have
> > > > > user operation. I also think it's not necessary because
> > I can see
> > > > > the channels
> > > > > through the gateway with caget. I doubt that it is a gateway
> > > > > problem at all.
> > > > > Rebooting the IOC helps. Writing the record name to the
> > link again
> > > > > helps too, but only for this link. All other links on
> > the same IOC
> > > > > to the same target
> > > > > record stay disconnected. I do not understand this.
> > > > > UDP package size is not an issue because its only 8 broken CA
> > > > > links to 2 records. So it should easily fit into one
> > package. But
> > > > > as I said, I see no
> > > > > package at all (except when I rewnew the link).
> > > > > I would send a stack trace of the CAC timer thread if I
> > could find
> > > > > it. What's the name?
> > > > > Here is the full dbcar output, mybe it helps:
> > > > > X04SA-VME-ID2 > dbcar "",100
> > > > > connected X04SA-VME-ID2 X04SA-ID-LMD:PMD.INPB
> > > > > X04SA-ID-LMD:SCALER.S3
> > > > > connected X04SA-VME-ID2 X04SA-ID-LMD:PMD-INJ.INPB
> > > > > X04SA-ID-LMD:PMD
> > > > > connected X04SA-VME-ID2 X04SA-ID-LMD:PMD-NOINJ.INPB
> > > > > X04SA-ID-LMD:PMD
> > > > > connected X04SA-VME-ID2 X04SA-ID-LMD:PMU.INPB
> > > > > X04SA-ID-LMD:SCALER.S2
> > > > > connected X04SA-VME-ID2 X04SA-ID-LMU:PMD.INPB
> > > > > X04SA-ID-LMU:SCALER.S3
> > > > > connected X04SA-VME-ID2 X04SA-ID-LMU:PMU.INPB
> > > > > X04SA-ID-LMU:SCALER.S2
> > > > > connected 129.129.104.31:5064 X04SA-ID-FBPMD:ALARM.INPD
> > > > > X04SA-ID-GAP:ISOPEN not_connected X04SA-ID-FBPMD:X-COMP.INPE
> > > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMD:X-COMP.INPI
> > > > > ARIDI-PCT:CURRENT not_connected X04SA-ID-FBPMD:Y-COMP.INPE
> > > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMD:Y-COMP.INPI
> > > > > ARIDI-PCT:CURRENT
> > > > > connected 129.129.104.31:5064 X04SA-ID-FBPMU:ALARM.INPD
> > > > > X04SA-ID-GAP:ISOPEN not_connected X04SA-ID-FBPMU:X-COMP.INPE
> > > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMU:X-COMP.INPI
> > > > > ARIDI-PCT:CURRENT not_connected X04SA-ID-FBPMU:Y-COMP.INPE
> > > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMU:Y-COMP.INPI
> > > > > ARIDI-PCT:CURRENT
> > > > > connected 129.129.104.31:5064 X04SA-ID:FBPM-ILK.OUT
> > > > > X04SA-ID:ILK-BITS.B1
> > > > > connected X04SA-VME-ID2 X04SA-VME-ID2:HBTSYNC.INPA
> > > > > X04SA-VME-ID2:HBT.VAL
> > > > > connected X04SA-VME-ID2 X04SA-VME-ID2:MEMALLOC.INPA
> > > > > X04SA-VME-ID2:MEMALLOCRA W
> > > > > connected X04SA-VME-ID2 X04SA-VME-ID2:MEMFREE.INPA
> > > > > X04SA-VME-ID2:MEMFREE-RAW
> > > > > connected X04SA-VME-ID2 X04SA-VME-ID2:MEMMAX.INPA
> > > > > X04SA-VME-ID2:MEMMAX-RAW
> > > > > ncalinks 21 not connected 8 no_read_access 0 no_write_access 0
> > > > > nDisconnect 0 nNoWrite 0
> > > > > ca_client_context at 0x7ca6c90 pndRecvCnt=0 ioSeqNo=0
> > > > > dbContext at 0x7ca6a80
> > > > > event call back cache location 0x7bac130, and
> > its size 24
> > > > > dbContextReadNotifyCache
> > > > > dbContextReadNotifyCacheAlocator
> > > > > count 1 and size 88
> > > > > epicsMutexId 0x7ca6c20 source
> > > > > ../../../src/libCom/osi/epicsMutex.cpp line 197
> > > > > Semaphore Id : 0x7ca6c50
> > > > > Semaphore Type : MUTEX
> > > > > Task Queuing : PRIORITY
> > > > > Pended Tasks : 3
> > > > > Owner : 0x7a331e0 (tShell)
> > > > > Options : 0xd SEM_Q_PRIORITY
> > > > > SEM_DELETE_SAFE
> > > > > SEM_INVERSION_SAFE
> > > > > VxWorks Events
> > > > > Registered Task : NONE
> > > > > Event(s) to Send : N/A
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > NAME TID PRI TIMEOUT
> > > > > timerQueue 7bf5d20 148 0
> > > > > CAC-event 7bb5a90 148 0
> > > > > CAC-TCP-recv 7a5e3b0 150 0
> > > > > Channel Access Client Context at 0x7bf8cc0 for user ioc
> > > > > revision "@(#) EPICS 3.14.8.2, CA Client
> > Library Nov 29
> > > > > 2006" Hash table with 512 buckets and 2 items of type 6tcpiiu
> > > > > installed Virtual circuit to "129.129.104.31:5064" at
> > version V4.8 state 1
> > > > > current data cache pointer = 0x7b88c20 current
> > data cache
> > > > > size = 16384
> > > > > contiguous receive message count=0, busy
> > detect bool=0,
> > > > > flow control boo l=0
> > > > > eceive thread is busy=0
> > > > > virtual circuit socket identifier 20
> > > > > send thread flush signal:
> > > > > Semaphore Id : 0x7b88bc0
> > > > > Semaphore Type : BINARY
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 1
> > > > > State : EMPTY
> > > > > Options : 0x0 SEM_Q_FIFO
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > CAC-TCP-send 7b8fba0 148 0
> > > > > send thread:
> > > > > recv thread:
> > > > > echo pending bool = 0
> > > > > IO identifier hash table:
> > > > > Connected channels
> > > > > Channel "X04SA-ID-GAP:ISOPEN", connected to server
> > > > > 129.129.104.31:5064, native t ype DBF_ENUM, native
> > element count
> > > > > 1, read access, write access
> > > > > network IO pointer = 0x7b96cd0
> > > > > server identifier 392
> > > > > search retry number=1
> > > > > name length=20
> > element count
> > > > > server identifier 393
> > > > > name length=20
> > > > > Channel "X04SA-ID:ILK-BITS.B1", connected to server
> > > > > 129.129.104.31:5064, native type DBF_CHAR, native
> > element count 1,
> > > > > server identifier 394
> > > > > name length=21
> > > > > Virtual circuit to "129.129.104.14:5064" at version
> > V4.11 state 1
> > > > > current data cache pointer = 0x7af62b0 current
> > data cache
> > > > > size = 16384
> > detect bool=0,
> > > > > virtual circuit socket identifier 22
> > > > > Semaphore Id : 0x7a1f670
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 1
> > > > > State : EMPTY
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > CAC-TCP-send 7a61590 148 0
> > > > > send thread:
> > > > > recv thread:
> > > > > Unresponsive circuit channels
> > > > > Channel "ARIDI-PCT:CURRENT" is disconnected
> > > > > network IO pointer = 0x7b96f58
> > > > > server identifier 1
> > > > > name length=18
> > > > > server identifier 2
> > > > > name length=18
> > > > > server identifier 3
> > > > > name length=18
> > > > > server identifier 4
> > > > > name length=18
> > > > > Channel "ACOAU-ACCU:OP-MODE" is disconnected
> > > > > server identifier 5
> > > > > name length=19
> > > > > server identifier 6
> > > > > name length=19
> > > > > server identifier 7
> > > > > name length=19
> > > > > server identifier 8
> > > > > name length=19
> > > > > Virtual circuit to "129.129.104.31:5064" at version V4.8 state 1
> > data cache
> > > > > size = 16384
> > detect bool=0,
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 1
> > > > > State : EMPTY
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > send thread:
> > > > > recv thread:
> > > > > Connected channels
> > element count
> > > > > name length=20
> > element count
> > > > > name length=20
> > element count 1,
> > > > > name length=21
> > V4.11 state 1
> > data cache
> > > > > size = 16384
> > detect bool=0,
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 1
> > > > > State : EMPTY
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > send thread:
> > > > > recv thread:
> > > > > server identifier 1
> > > > > name length=18
> > > > > server identifier 2
> > > > > name length=18
> > > > > server identifier 3
> > > > > name length=18
> > > > > server identifier 4
> > > > > name length=18
> > > > > server identifier 5
> > > > > name length=19
> > > > > server identifier 6
> > > > > name length=19
> > > > > server identifier 7
> > > > > name length=19
> > > > > server identifier 8
> > > > > name length=19
> > > > > entries per bucket: mean = 0.003906 std dev = 0.062378 max = 1
> > > > > connection time out watchdog period 30.000000
> > Datagram IO
> > > > > circuit (and disconnected channel repository)
> > > > > repeater port 5065
> > > > > default server port 5064
> > > > > Channel Access Address List
> > > > > 129.129.104.255:5064
> > > > > socket identifier 18
> > > > > bytes in xmit buffer 16
> > > > > shut down command bool 0
> > > > > recv thread exit signal:
> > > > > repeater subscribe timer: attempts=2 registered=1 once=0
> > > > > disconnect governor timer: search timer delay 0.032000
> > > > > 0 channels with search request pending
> > > > > 0 channels with search response pending
> > > > > search timer delay 0.064000
> > > > > search timer delay 0.128000
> > > > > search timer delay 0.256000
> > > > > search timer delay 0.512000
> > > > > search timer delay 1.024000
> > > > > search timer delay 2.048000
> > > > > search timer delay 4.096000
> > > > > search timer delay 8.192000
> > > > > search timer delay 16.384000
> > > > > search timer delay 32.768000
> > > > > search timer delay 65.536000
> > > > > search timer delay 131.072000
> > > > > search timer delay 262.144000
> > > > > Program begin time:
> > > > > epicsTime: MON MAY 11 2009 16:53:29.047623310
> > > > > epicsTime: revision "@(#) EPICS 3.14.8.2, Common Utilities
> > > > > Library Nov 29 2006"
> > > > > Channel identifier hash table:
> > > > > Hash table with 512 buckets and 11 items of type 4nciu installed
> > > > > ype DBF_ENUM, native element count 1, read access, write access
> > > > > name length=20
> > > > > server identifier 5
> > > > > name length=19
> > > > > server identifier 1
> > > > > name length=18
> > > > > server identifier 6
> > > > > name length=19
> > > > > server identifier 2
> > > > > name length=18
> > > > > name length=20
> > > > > server identifier 7
> > > > > name length=19
> > > > > server identifier 3
> > > > > name length=18
> > > > > server identifier 8
> > > > > name length=19
> > > > > server identifier 4
> > > > > name length=18
> > > > > type DBF_CHAR, native element count 1, read access, write access
> > > > > name length=21
> > > > > name length=20
> > > > > server identifier 5
> > > > > name length=19
> > > > > server identifier 1
> > > > > name length=18
> > > > > server identifier 6
> > > > > name length=19
> > > > > server identifier 2
> > > > > name length=18
> > > > > name length=20
> > > > > server identifier 7
> > > > > name length=19
> > > > > server identifier 3
> > > > > name length=18
> > > > > server identifier 8
> > > > > name length=19
> > > > > server identifier 4
> > > > > name length=18
> > > > > name length=21
> > > > > entries per bucket: mean = 0.021484 std dev = 0.144992 max = 1
> > > > > Hash table with 512 buckets and 10 items of type
> > 8baseNMIU installed
> > > > > event subscription IO at 0x7ae2ef0, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae2f1c, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae2f48, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae2f74, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae2fa0, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae2fcc, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae2ff8, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae3024, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae3050, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > event subscription IO at 0x7ae307c, type DBF_invalid, element
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > count 1, mask 5
> > > > > entries per bucket: mean = 0.019531 std dev = 0.138383 max = 1
> > > > > Beacon source identifier hash table:
> > > > > Hash table with 512 buckets and 11 items of type 3bhe installed
> > > > > CA beacon hash entry for 129.129.104.13:32771 with period
> > > > > estimate 15.049622
> > > > > beacon number 718291, on MON JUN 29 2009 13:59:03
> > > > > CA beacon hash entry for 129.129.104.33:5064 with period
> > > > > estimate 14.849221
> > > > > beacon number 0, on THU AUG 06 2009 10:56:40
> > > > > CA beacon hash entry for 129.129.104.34:5064 with period
> > > > > estimate 14.891577
> > > > > beacon number 0, on THU AUG 06 2009 10:56:30
> > > > > CA beacon hash entry for 129.129.104.36:5064 with period
> > > > > estimate 14.936137
> > > > > beacon number 0, on THU AUG 06 2009 10:56:36
> > > > > CA beacon hash entry for 129.129.104.37:5064 with period
> > > > > estimate 14.915017
> > > > > beacon number 26678, on THU AUG 06 2009 10:56:33
> > > > > CA beacon hash entry for 129.129.104.39:5064 with period
> > > > > estimate 14.838267
> > > > > beacon number 0, on THU AUG 06 2009 10:56:39
> > > > > CA beacon hash entry for 129.129.104.13:5064 with period
> > > > > estimate 20.991435
> > > > > beacon number 51, on THU AUG 06 2009 10:56:33
> > > > > CA beacon hash entry for 129.129.104.14:5064 with period
> > > > > estimate 14.935088
> > > > > beacon number 218331, on THU AUG 06 2009 10:56:37
> > > > > CA beacon hash entry for 129.129.104.15:5064 with period
> > > > > estimate 14.881638
> > > > > beacon number 218058, on THU AUG 06 2009 10:56:29
> > > > > CA beacon hash entry for 129.129.104.30:5064 with period
> > > > > estimate 14.953183
> > > > > CA beacon hash entry for 129.129.104.31:5064 with period
> > > > > estimate 14.925085
> > > > > beacon number 0, on THU AUG 06 2009 10:56:34
> > > > > estimate 15.049622
> > > > > estimate 14.849221
> > > > > estimate 14.891577
> > > > > estimate 14.936137
> > > > > estimate 14.915017
> > > > > estimate 14.838267
> > > > > estimate 20.991435
> > > > > estimate 14.935088
> > > > > estimate 14.881638
> > > > > estimate 14.953183
> > > > > estimate 14.925085
> > > > > Timer queue:
> > > > > EPICS threaded timer queue at 0x7bf6240
> > > > > epicsTimerQueue with 15 items pending
> > > > > 11searchTimer, state = pending, delay = -19.894333
> > > > > 11searchTimer, state = pending, delay = -20.000999
> > > > > 11searchTimer, state = pending, delay = -20.163666
> > > > > 11searchTimer, state = pending, delay = -20.235666
> > > > > 11searchTimer, state = pending, delay = -20.296333
> > > > > 11searchTimer, state = pending, delay = -18.926999
> > > > > 11searchTimer, state = pending, delay = -17.095666
> > > > > 23disconnectGovernorTimer, state = pending, delay = -16.191666
> > > > > 11searchTimer, state = pending, delay = -13.316332
> > > > > 11searchTimer, state = pending, delay = -5.424332
> > > > > 11searchTimer, state = pending, delay = -5.590332
> > > > > 15tcpRecvWatchdog, state = pending, delay = 1.191668
> > > > > Receive virtual circuit watchdog at 0x7b96df0, period 30.000000
> > > > > 11searchTimer, state = pending, delay = 6.361002
> > > > > 11searchTimer, state = pending, delay = 51.530337
> > > > > 11searchTimer, state = pending, delay = 236.852334
> > > > > reschedule event
> > > > > Semaphore Id : 0x7bf6070
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 0
> > > > > State : EMPTY
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > exit event
> > > > > Semaphore Id : 0x7bf6030
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 0
> > > > > State : EMPTY
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > exitFlag = F, terminateFlag = F
> > > > > IP address to name conversion engine:
> > > > > ipAddrToAsciiEngine at 0x7bf86c0 with 0 requests pending
> > > > > mutex:
> > > > > epicsMutexId 0x7bf8650 source
> > > > > Semaphore Id : 0x7bf8680
> > > > > Pended Tasks : 0
> > > > > SEM_DELETE_SAFE
> > > > > SEM_INVERSION_SAFE
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > laborEvent:
> > > > > Semaphore Id : 0x7bf8610
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 1
> > > > > State : EMPTY
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > ipToAsciiProxy 7bf82c0 189 0
> > > > > exitFlag boolean = 0
> > > > > exit event:
> > > > > Default mutex:
> > > > > Pended Tasks : 5
> > > > > SEM_DELETE_SAFE
> > > > > SEM_INVERSION_SAFE
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > scan10 7c2d530 136 0
> > > > > CAC-UDP 7be23d0 147 0
> > > > > mutex:
> > > > > Pended Tasks : 5
> > > > > SEM_DELETE_SAFE
> > > > > SEM_INVERSION_SAFE
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Pended Tasks
> > > > > preemptive callback is enabled
> > > > > there are 0 unsatisfied IO operations blocking
> > ca_pend_io()
> > > > > the current io sequence number is 0
> > > > > IO done event:
> > > > > Semaphore Id : 0x7ca6b70
> > > > > Task Queuing : FIFO
> > > > > Pended Tasks : 0
> > > > > State : EMPTY
> > > > > VxWorks Events
> > > > > Options : N/A
> > > > > Synchronous group identifier hash table:
> > > > > Hash table with 0 buckets and 0 items of type 4CASG installed
> > > > > value = 0 = 0x0 X04SA-VME-ID2 >
> > > > > Jeff Hill wrote:
> > > > > > Dirk,
> > > > > > The R3.14 design is more conservative from a perspective of
> > > > > > avoiding positive congestion feedback. Here are the primary
> > > > > > differences.
> > > > > > O When a circuit times out the CAC library disconnects the
> > > > > application, but
> > > > > > not the circuit. We rely on TCP to decide when to give up
> > > > > on a circuit, and
> > > > > > disconnect it.
> > > > > > O When the CAC library sees a beacon anomaly the search
> > > > > rate receives a
> > > > > > boost, but this boost is only to once every 5 seconds. In
> > > > > contrast, newly
> > > > > > created channels are initially searched for at a rate which
> > > > > is closer to the
> > > > > > average measured round trip time. The CAC library sends
> > > > > multiple search
> > > > > > requests per UDP frame, and depending on past success rates
> > > > > also multiple
> > > > > > UDP frames per periodic search attempt (that part isn't
> > > > > different between
> > > > > > R3.14 and R3.15). Nevertheless, if there many channels it
> > > > > can take a little
> > > > > > while to connect all of them if the IOC (or GW in this
> > > > > situation has been
> > > > > > off for a long time).
> > > > > > O In R3.14 the CAC library never stops searching for
> > > > > disconnected channels,
> > > > > > but the maximum search rate is adjustable with an
> > > > > environment variable.
> > > > > >> I cannot see any search requests from that IOC.
> > > > > > That doesn't sound right, but bear in mind that if the IOC
> > > > > is sending
> > > > > > unicasts, and not broadcasts, to the gateway on a switched
> > > > > network then the
> > > > > > network sniffer may or may not see them if it isn't
> > > > > listening at the source
> > > > > > or the destination cables. Directed broadcasts may also not
> > > > > be seen by the
> > > > > > network sniffer if it isn't sniffing directly on the
> > > > > directed broadcast's
> > > > > > destination subnet.
> > > > > > The output from dbcar when its interest level argument is
> > > > > set very high (say
> > > > > > to 100) will show many things about the internals of the
> > > > > CAC library. Also,
> > > > > > there is a timer thread created by the CAC library that is
> > > > > scheduling the
> > > > > > search requests, and you might send a stack trace (if it
> > > > > isn't simply
> > > > > > waiting on its time delay event flag).
> > > > > > Another possibility is that something is amiss in the GW.
> > > > > Does restarting
> > > > > > the GW improve the situation?
> > > > > > Jeff ______________________________________________________
> > > > > >> Sent: Wednesday, August 05, 2009 8:09 AM
> > > > > >> To: tech-talk
> > > > > >> Subject: CA reconnection problem
> > > > > >> Hi all (Jeff in particular)
> > > > > >> I have seen a problem with some of our IOCs today. Several
> > > > > beamline IOCs
> > > > > >> running
> > > > > >> 3.14.8 have disconnected CA input links to a central IOC
> > > > > (3.13.10) even
> > > > > >> though
> > > > > >> the channels are there. The beamline IOCs run behind ca
> > > > > gateways. It may
> > > > > >> be that
> > > > > >> the gateways or the central IOC had been offline for more
> > > > > than some hours
> > > > > >> recently in the last shutdown.
> > > > > >> Even though the channels are back and I can read them from
> > > > > the beamline
> > > > > >> network
> > > > > >> with caget the IOCs don't reconnect.
> > > > > >> I have started a softioc in the beamline network to
> > > > > generate a beacon
> > > > > >> anomaly
> > > > > >> but even then the links do not reconnect. I cannot see any
> > > > > search requests
> > > > > >> from
> > > > > >> that IOC.
> > > > > >> Only 3.14.8 systems show this problem. 3.13. systems
> > > > > don't. Is there a bug
> > > > > >> in
> > > > > >> the 3.14.8 implementation of CAC I should know of?
> > > > > >> Dirk
> > > > > >> Dr. Dirk Zimoch
> > > > > >> Paul Scherrer Institut, WBGB/006
> > > > > >> 5232 Villigen PSI, Switzerland
> > > > > >> Phone +41 56 310 5182
> > > > > Dr. Dirk Zimoch
> > > > Scanned by iCritical.
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only.
> If you are not the intended addressee or an authorised recipient of the
> addressee please notify us of receipt by returning the e-mail and do not
> use, copy, retain, distribute or disclose the information in or attached
> to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and
> not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for any
> damage which you may sustain as a result of software viruses which may be
> transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
- Re: CA reconnection problem Dirk Zimoch
- RE: CA reconnection problem Jeff Hill
- RE: CA reconnection problem Shepherd, Emma (DLSLtd,RAL,DIA)
ASYN R4-12 Eric Norum
<2009>
<2009>
