1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA reconnection problem
From: "Shepherd, Emma (DLSLtd,RAL,DIA)" <[email protected]>
To: "Jeff Hill" <[email protected]>, "Rees, Nick (DLSLtd,RAL,DIA)" <[email protected]>, "Dirk Zimoch" <[email protected]>
Date: Tue, 11 Aug 2009 09:59:55 +0100
Hi all,
I've gone back through my notes as well to see what I can remember about this.  I think part of the problem is that we have had several different issues at Diamond with similar symptoms:
1) The CAC-TCP-recv task gets suspended - I don't know what causes it but things are well and truly broken when this happens and we have to reboot the IOC.  I haven't seen this in quite a while though.
2) A timerQueue task responsible for scheduling UDP requests gets suspended.  In one investigation the task trace showed that an exception had been thrown and not handled properly - Mantis entry 336 was created for this and I believe you committed a fix Jeff.
3) Some CA links not working but nothing obvious wrong, no suspended tasks.  Like in Dirk's case, the link is connecting through a gateway and re-writing the record name to the link can fix that particular link.
I hope that helps to explain our situation at the moment, let me know if there's any more investigation I can do here.
Emma
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Jeff Hill
> Sent: 11 August 2009 02:02
> To: Rees, Nick (DLSLtd,RAL,DIA); 'Dirk Zimoch'
> Cc: 'tech-talk'
> I had another look at this issue this evening and suspect now
> that the timer queue entries with negative delays reflect
> only the time spent (on the order of 20 seconds) holding the
> lock while dumping "dbcar" at high intrest levels to the slow
> 9600 baud serial port.
> So perhaps its best to step back a bit and look at what
> Diamond and SLS have in common. It seems that both sites have
> a db ca link connecting through the gateway when this occurs.
> Dirk mentioned that R3.13 CA links connect fine at SLS, but
> R3.14 ones don't. That can probably be explained by the fact
> that the R3.13 ca client library disconnects both the circuit
> and the application when a circuit is unresponsive. In
> contrast, the R3.14 ca client library disconnects only the
> application, and not the circuit when the circuit is
> unresponsive relying instead on TCP to disconnect broken circuits.
> So what probably is occurring is an issue with the gateway
> where PCAS isn't properly scheduling itself to interact with
> the R3.14 ca client's circuit, but the circuit remains
> connected at TCP's level. In Dirk's situation I seem to
> recall that a power outage was the precipitating event. A
> precipitating event at Diamond maybe isn't identified?
> There are an assortment of PCAS, and also gateway
> improvements, coming soon in R3.14.11 RC1 but I'm not certain
> that this one has been fixed. I will see if I can reproduce it.
> Jeff
> ______________________________________________________
> Jeffrey O. Hill           Email        [email protected]
> LANL MS H820              Voice        505 665 1831
> Los Alamos NM 87545 USA   FAX          505 665 5107
> Message content: TSPA
> > Sent: Monday, August 10, 2009 11:05 AM
> > To: 'Rees, NP (Nick)'; 'Dirk Zimoch'
> > Cc: 'tech-talk'
> > Nick, Dirk,
> > > I think this is possibly the same problem we described in the
> > > thread:
> > > "Inter-IOC link problems"
> > > http://www.aps.anl.gov/epics/tech-talk/2008/msg01103.php
> > I vaguely recall that there was a mantis entry for the
> above, but have
> > had no success finding it. I did find 164 which is somewhat
> close, but
> > probably not the same issue. Also 330 (which will probably soon be
> > assigned not-a- bug
> > status) might be of some interest if you are seeing
> unexpectedly long
> > reconnect times with R3.14.
> > Nevertheless, working only from my memory, it's not clear that Emma
> > Shepherd's and Dirk's issues have the same symptoms. In Dirk's
> > situation dbcar (at high interest levels) shows entries in the CA
> > client library's timer queue with negative expiration which, as I
> > recall, was not identified as a symptom with Emma Shepherd's
> > situation? The tech-talk thread does indicate some close
> examination
> > of the dbcar output occurred, which probably
> > would have immediately identified the negative expiration
> times on the
> > timer
> > queue as a problem?
> > In any case you now have a common symptom to look for with
> dbcar the
> > next time that it happens.
> > Stack traces from _all_ of the dbca, CA client library, and timer
> > threads involved will be the information I need to
> determine a cause.
> > When deciding on which threads traces to send, look at the threads
> > operating at close to the same scheduling priority as dbca in the
> > vxWorks "i" output. Emphasis on
> > all because if there is a deadlock issue they can be tricky
> to identify
> > w/o
> > clear understanding of the lock hierarchy interactions
> between the two or
> > more threads involved. Of course, if we have a deadlock
> situation, then
> > any
> > threads that are continuously blocking on a mutex are of particular
> > interest.
> > Thanks for your help,
> > Jeff
> > > From: Rees, NP (Nick) [mailto:[email protected]]
> > > Sent: Thursday, August 06, 2009 6:29 AM
> > > To: Dirk Zimoch; Jeff Hill
> > > Cc: tech-talk
> > > Hi Dirk, Jeff,
> > > thread:
> > > That thread seemed to peter out because we basically developed
> > > reboot workarounds that meant it didn't bother us as
> much. However,
> > > I don't think it was ever solved. I don't know whether there is a
> > > Mantis entry for it.
> > > Cheers,
> > > Nick Rees
> > > Principal Software Engineer           Phone: +44 (0)1235-778430
> > > Diamond Light Source                  Fax:   +44 (0)1235-446713
> > > > [mailto:[email protected]] On Behalf Of Dirk Zimoch
> > > > Sent: 06 August 2009 10:22
> > > > To: Jeff Hill
> > > > Cc: 'tech-talk'
> > > > Subject: Re: CA reconnection problem
> > > > Hi Jeff,
> > > > Time advances normally on the IOC.
> > > > Bug 299 is not related because I have no suspended
> tasks. Bug 330
> > > > is also not related because my channels never reconnect, even
> > > > after days.
> > > > The IOC connects to the gateway with normal broadcasts on the
> > > > local network. I can see beacons from all IOCs and
> gateway and I
> > > > can see the beacon anomaly when
> > > > I start a softioc. Still the IOC does not send any search
> > > > requests to reconnect
> > > > the links. I can see the search requests from 3.13 IOCs,
> > > > 3.14.8 medms and the
> > > > gateway after a beacon anomaly, but not from 3.14.8 IOCs. It
> > > > is definitely not
> > > > the case that the 3.14.8 IOC never stops searching.
> > > > I do not want to restart the gateway at the moment
> because we have
> > > > user operation. I also think it's not necessary because
> I can see
> > > > the channels
> > > > through the gateway with caget. I doubt that it is a gateway
> > > > problem at all.
> > > > Rebooting the IOC helps. Writing the record name to the
> link again
> > > > helps too, but only for this link. All other links on
> the same IOC
> > > > to the same target
> > > > record stay disconnected. I do not understand this.
> > > > UDP package size is not an issue because its only 8 broken CA
> > > > links to 2 records. So it should easily fit into one
> package. But
> > > > as I said, I see no
> > > > package at all (except when I rewnew the link).
> > > > I would send a stack trace of the CAC timer thread if I
> could find
> > > > it. What's the name?
> > > > Here is the full dbcar output, mybe it helps:
> > > > X04SA-VME-ID2 > dbcar "",100
> > > >      connected X04SA-VME-ID2 X04SA-ID-LMD:PMD.INPB
> > > > X04SA-ID-LMD:SCALER.S3
> > > >      connected X04SA-VME-ID2 X04SA-ID-LMD:PMD-INJ.INPB
> > > > X04SA-ID-LMD:PMD
> > > >      connected X04SA-VME-ID2 X04SA-ID-LMD:PMD-NOINJ.INPB
> > > > X04SA-ID-LMD:PMD
> > > >      connected X04SA-VME-ID2 X04SA-ID-LMD:PMU.INPB
> > > > X04SA-ID-LMD:SCALER.S2
> > > >      connected X04SA-VME-ID2 X04SA-ID-LMU:PMD.INPB
> > > > X04SA-ID-LMU:SCALER.S3
> > > >      connected X04SA-VME-ID2 X04SA-ID-LMU:PMU.INPB
> > > > X04SA-ID-LMU:SCALER.S2
> > > >      connected 129.129.104.31:5064 X04SA-ID-FBPMD:ALARM.INPD
> > > > X04SA-ID-GAP:ISOPEN not_connected X04SA-ID-FBPMD:X-COMP.INPE
> > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMD:X-COMP.INPI
> > > > ARIDI-PCT:CURRENT not_connected X04SA-ID-FBPMD:Y-COMP.INPE
> > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMD:Y-COMP.INPI
> > > > ARIDI-PCT:CURRENT
> > > >      connected 129.129.104.31:5064 X04SA-ID-FBPMU:ALARM.INPD
> > > > X04SA-ID-GAP:ISOPEN not_connected X04SA-ID-FBPMU:X-COMP.INPE
> > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMU:X-COMP.INPI
> > > > ARIDI-PCT:CURRENT not_connected X04SA-ID-FBPMU:Y-COMP.INPE
> > > > ACOAU-ACCU:OP-MODE not_connected X04SA-ID-FBPMU:Y-COMP.INPI
> > > > ARIDI-PCT:CURRENT
> > > >      connected 129.129.104.31:5064 X04SA-ID:FBPM-ILK.OUT
> > > > X04SA-ID:ILK-BITS.B1
> > > >      connected X04SA-VME-ID2 X04SA-VME-ID2:HBTSYNC.INPA
> > > > X04SA-VME-ID2:HBT.VAL
> > > >      connected X04SA-VME-ID2 X04SA-VME-ID2:MEMALLOC.INPA
> > > > X04SA-VME-ID2:MEMALLOCRA W
> > > >      connected X04SA-VME-ID2 X04SA-VME-ID2:MEMFREE.INPA
> > > > X04SA-VME-ID2:MEMFREE-RAW
> > > >      connected X04SA-VME-ID2 X04SA-VME-ID2:MEMMAX.INPA
> > > > X04SA-VME-ID2:MEMMAX-RAW
> > > > ncalinks 21 not connected 8 no_read_access 0 no_write_access 0
> > > >   nDisconnect 0 nNoWrite 0
> > > > ca_client_context at 0x7ca6c90 pndRecvCnt=0 ioSeqNo=0
> > > > dbContext at 0x7ca6a80
> > > >          event call back cache location 0x7bac130, and
> its size 24
> > > > dbContextReadNotifyCache
> > > > dbContextReadNotifyCacheAlocator
> > > >          count 1 and size 88
> > > > epicsMutexId 0x7ca6c20 source
> > > > ../../../src/libCom/osi/epicsMutex.cpp line 197
> > > > Semaphore Id        : 0x7ca6c50
> > > > Semaphore Type      : MUTEX
> > > > Task Queuing        : PRIORITY
> > > > Pended Tasks        : 3
> > > > Owner               : 0x7a331e0    (tShell)
> > > > Options             : 0xd       SEM_Q_PRIORITY
> > > >                                  SEM_DELETE_SAFE
> > > >                                  SEM_INVERSION_SAFE
> > > > VxWorks Events
> > > > Registered Task     : NONE
> > > > Event(s) to Send    : N/A
> > > > Options             : N/A
> > > > Pended Tasks
> > > >     NAME      TID    PRI TIMEOUT
> > > > timerQueue  7bf5d20 148       0
> > > > CAC-event   7bb5a90 148       0
> > > > CAC-TCP-recv 7a5e3b0 150       0
> > > > Channel Access Client Context at 0x7bf8cc0 for user ioc
> > > >          revision "@(#) EPICS 3.14.8.2, CA Client
> Library Nov 29
> > > > 2006" Hash table with 512 buckets and 2 items of type 6tcpiiu
> > > > installed Virtual circuit to "129.129.104.31:5064" at
> version V4.8 state 1
> > > >          current data cache pointer = 0x7b88c20 current
> data cache
> > > > size = 16384
> > > >          contiguous receive message count=0, busy
> detect bool=0,
> > > > flow control boo l=0
> > > > eceive thread is busy=0
> > > >          virtual circuit socket identifier 20
> > > >          send thread flush signal:
> > > > Semaphore Id        : 0x7b88bc0
> > > > Semaphore Type      : BINARY
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 1
> > > > State               : EMPTY
> > > > Options             : 0x0       SEM_Q_FIFO
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Pended Tasks
> > > > CAC-TCP-send 7b8fba0 148       0
> > > >          send thread:
> > > >          recv thread:
> > > >          echo pending bool = 0
> > > > IO identifier hash table:
> > > > Connected channels
> > > > Channel "X04SA-ID-GAP:ISOPEN", connected to server
> > > > 129.129.104.31:5064, native t ype DBF_ENUM, native
> element count
> > > > 1, read access, write access
> > > >          network IO pointer = 0x7b96cd0
> > > >          server identifier 392
> > > >          search retry number=1
> > > >          name length=20
> element count
> > > >          server identifier 393
> > > >          name length=20
> > > > Channel "X04SA-ID:ILK-BITS.B1", connected to server
> > > > 129.129.104.31:5064, native type DBF_CHAR, native
> element count 1,
> > > >          server identifier 394
> > > >          name length=21
> > > > Virtual circuit to "129.129.104.14:5064" at version
> V4.11 state 1
> > > >          current data cache pointer = 0x7af62b0 current
> data cache
> > > > size = 16384
> detect bool=0,
> > > >          virtual circuit socket identifier 22
> > > > Semaphore Id        : 0x7a1f670
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 1
> > > > State               : EMPTY
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Pended Tasks
> > > > CAC-TCP-send 7a61590 148       0
> > > >          send thread:
> > > >          recv thread:
> > > > Unresponsive circuit channels
> > > > Channel "ARIDI-PCT:CURRENT" is disconnected
> > > >          network IO pointer = 0x7b96f58
> > > >          server identifier 1
> > > >          name length=18
> > > >          server identifier 2
> > > >          name length=18
> > > >          server identifier 3
> > > >          name length=18
> > > >          server identifier 4
> > > >          name length=18
> > > > Channel "ACOAU-ACCU:OP-MODE" is disconnected
> > > >          server identifier 5
> > > >          name length=19
> > > >          server identifier 6
> > > >          name length=19
> > > >          server identifier 7
> > > >          name length=19
> > > >          server identifier 8
> > > >          name length=19
> > > > Virtual circuit to "129.129.104.31:5064" at version V4.8 state 1
> data cache
> > > > size = 16384
> detect bool=0,
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 1
> > > > State               : EMPTY
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Pended Tasks
> > > >          send thread:
> > > >          recv thread:
> > > > Connected channels
> element count
> > > >          name length=20
> element count
> > > >          name length=20
> element count 1,
> > > >          name length=21
> V4.11 state 1
> data cache
> > > > size = 16384
> detect bool=0,
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 1
> > > > State               : EMPTY
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Pended Tasks
> > > >          send thread:
> > > >          recv thread:
> > > >          server identifier 1
> > > >          name length=18
> > > >          server identifier 2
> > > >          name length=18
> > > >          server identifier 3
> > > >          name length=18
> > > >          server identifier 4
> > > >          name length=18
> > > >          server identifier 5
> > > >          name length=19
> > > >          server identifier 6
> > > >          name length=19
> > > >          server identifier 7
> > > >          name length=19
> > > >          server identifier 8
> > > >          name length=19
> > > > entries per bucket: mean = 0.003906 std dev = 0.062378 max = 1
> > > >          connection time out watchdog period 30.000000
> Datagram IO
> > > > circuit (and disconnected channel repository)
> > > >          repeater port 5065
> > > >          default server port 5064
> > > > Channel Access Address List
> > > > 129.129.104.255:5064
> > > >          socket identifier 18
> > > >          bytes in xmit buffer 16
> > > >          shut down command bool 0
> > > >          recv thread exit signal:
> > > > repeater subscribe timer: attempts=2 registered=1 once=0
> > > > disconnect governor timer: search timer delay 0.032000
> > > > 0 channels with search request pending
> > > > 0 channels with search response pending
> > > > search timer delay 0.064000
> > > > search timer delay 0.128000
> > > > search timer delay 0.256000
> > > > search timer delay 0.512000
> > > > search timer delay 1.024000
> > > > search timer delay 2.048000
> > > > search timer delay 4.096000
> > > > search timer delay 8.192000
> > > > search timer delay 16.384000
> > > > search timer delay 32.768000
> > > > search timer delay 65.536000
> > > > search timer delay 131.072000
> > > > search timer delay 262.144000
> > > > Program begin time:
> > > > epicsTime: MON MAY 11 2009 16:53:29.047623310
> > > > epicsTime: revision "@(#) EPICS 3.14.8.2, Common Utilities
> > > > Library Nov 29 2006"
> > > > Channel identifier hash table:
> > > > Hash table with 512 buckets and 11 items of type 4nciu installed
> > > > ype DBF_ENUM, native element count 1, read access, write access
> > > >          name length=20
> > > >          server identifier 5
> > > >          name length=19
> > > >          server identifier 1
> > > >          name length=18
> > > >          server identifier 6
> > > >          name length=19
> > > >          server identifier 2
> > > >          name length=18
> > > >          name length=20
> > > >          server identifier 7
> > > >          name length=19
> > > >          server identifier 3
> > > >          name length=18
> > > >          server identifier 8
> > > >          name length=19
> > > >          server identifier 4
> > > >          name length=18
> > > > type DBF_CHAR, native element count 1, read access, write access
> > > >          name length=21
> > > >          name length=20
> > > >          server identifier 5
> > > >          name length=19
> > > >          server identifier 1
> > > >          name length=18
> > > >          server identifier 6
> > > >          name length=19
> > > >          server identifier 2
> > > >          name length=18
> > > >          name length=20
> > > >          server identifier 7
> > > >          name length=19
> > > >          server identifier 3
> > > >          name length=18
> > > >          server identifier 8
> > > >          name length=19
> > > >          server identifier 4
> > > >          name length=18
> > > >          name length=21
> > > > entries per bucket: mean = 0.021484 std dev = 0.144992 max = 1
> > > > Hash table with 512 buckets and 10 items of type
> 8baseNMIU installed
> > > > event subscription IO at 0x7ae2ef0, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae2f1c, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae2f48, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae2f74, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae2fa0, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae2fcc, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae2ff8, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae3024, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae3050, type DBF_invalid, element
> > > > count 1, mask 5
> > > > event subscription IO at 0x7ae307c, type DBF_invalid, element
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > count 1, mask 5
> > > > entries per bucket: mean = 0.019531 std dev = 0.138383 max = 1
> > > > Beacon source identifier hash table:
> > > > Hash table with 512 buckets and 11 items of type 3bhe installed
> > > > CA beacon hash entry for 129.129.104.13:32771 with period
> > > > estimate 15.049622
> > > >          beacon number 718291, on MON JUN 29 2009 13:59:03
> > > > CA beacon hash entry for 129.129.104.33:5064 with period
> > > > estimate 14.849221
> > > >          beacon number 0, on THU AUG 06 2009 10:56:40
> > > > CA beacon hash entry for 129.129.104.34:5064 with period
> > > > estimate 14.891577
> > > >          beacon number 0, on THU AUG 06 2009 10:56:30
> > > > CA beacon hash entry for 129.129.104.36:5064 with period
> > > > estimate 14.936137
> > > >          beacon number 0, on THU AUG 06 2009 10:56:36
> > > > CA beacon hash entry for 129.129.104.37:5064 with period
> > > > estimate 14.915017
> > > >          beacon number 26678, on THU AUG 06 2009 10:56:33
> > > > CA beacon hash entry for 129.129.104.39:5064 with period
> > > > estimate 14.838267
> > > >          beacon number 0, on THU AUG 06 2009 10:56:39
> > > > CA beacon hash entry for 129.129.104.13:5064 with period
> > > > estimate 20.991435
> > > >          beacon number 51, on THU AUG 06 2009 10:56:33
> > > > CA beacon hash entry for 129.129.104.14:5064 with period
> > > > estimate 14.935088
> > > >          beacon number 218331, on THU AUG 06 2009 10:56:37
> > > > CA beacon hash entry for 129.129.104.15:5064 with period
> > > > estimate 14.881638
> > > >          beacon number 218058, on THU AUG 06 2009 10:56:29
> > > > CA beacon hash entry for 129.129.104.30:5064 with period
> > > > estimate 14.953183
> > > > CA beacon hash entry for 129.129.104.31:5064 with period
> > > > estimate 14.925085
> > > >          beacon number 0, on THU AUG 06 2009 10:56:34
> > > > estimate 15.049622
> > > > estimate 14.849221
> > > > estimate 14.891577
> > > > estimate 14.936137
> > > > estimate 14.915017
> > > > estimate 14.838267
> > > > estimate 20.991435
> > > > estimate 14.935088
> > > > estimate 14.881638
> > > > estimate 14.953183
> > > > estimate 14.925085
> > > > Timer queue:
> > > > EPICS threaded timer queue at 0x7bf6240
> > > > epicsTimerQueue with 15 items pending
> > > > 11searchTimer, state = pending, delay = -19.894333
> > > > 11searchTimer, state = pending, delay = -20.000999
> > > > 11searchTimer, state = pending, delay = -20.163666
> > > > 11searchTimer, state = pending, delay = -20.235666
> > > > 11searchTimer, state = pending, delay = -20.296333
> > > > 11searchTimer, state = pending, delay = -18.926999
> > > > 11searchTimer, state = pending, delay = -17.095666
> > > > 23disconnectGovernorTimer, state = pending, delay = -16.191666
> > > > 11searchTimer, state = pending, delay = -13.316332
> > > > 11searchTimer, state = pending, delay = -5.424332
> > > > 11searchTimer, state = pending, delay = -5.590332
> > > > 15tcpRecvWatchdog, state = pending, delay = 1.191668
> > > > Receive virtual circuit watchdog at 0x7b96df0, period 30.000000
> > > > 11searchTimer, state = pending, delay = 6.361002
> > > > 11searchTimer, state = pending, delay = 51.530337
> > > > 11searchTimer, state = pending, delay = 236.852334
> > > > reschedule event
> > > > Semaphore Id        : 0x7bf6070
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 0
> > > > State               : EMPTY
> > > > VxWorks Events
> > > > Options             : N/A
> > > > exit event
> > > > Semaphore Id        : 0x7bf6030
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 0
> > > > State               : EMPTY
> > > > VxWorks Events
> > > > Options             : N/A
> > > > exitFlag = F, terminateFlag = F
> > > > IP address to name conversion engine:
> > > > ipAddrToAsciiEngine at 0x7bf86c0 with 0 requests pending
> > > > mutex:
> > > > epicsMutexId 0x7bf8650 source
> > > > Semaphore Id        : 0x7bf8680
> > > > Pended Tasks        : 0
> > > >                                  SEM_DELETE_SAFE
> > > >                                  SEM_INVERSION_SAFE
> > > > VxWorks Events
> > > > Options             : N/A
> > > > laborEvent:
> > > > Semaphore Id        : 0x7bf8610
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 1
> > > > State               : EMPTY
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Pended Tasks
> > > > ipToAsciiProxy 7bf82c0 189       0
> > > > exitFlag  boolean = 0
> > > > exit event:
> > > > Default mutex:
> > > > Pended Tasks        : 5
> > > >                                  SEM_DELETE_SAFE
> > > >                                  SEM_INVERSION_SAFE
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Pended Tasks
> > > > scan10      7c2d530 136       0
> > > > CAC-UDP     7be23d0 147       0
> > > > mutex:
> > > > Pended Tasks        : 5
> > > >                                  SEM_DELETE_SAFE
> > > >                                  SEM_INVERSION_SAFE
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Pended Tasks
> > > >          preemptive callback is enabled
> > > >          there are 0 unsatisfied IO operations blocking
> ca_pend_io()
> > > >          the current io sequence number is 0
> > > > IO done event:
> > > > Semaphore Id        : 0x7ca6b70
> > > > Task Queuing        : FIFO
> > > > Pended Tasks        : 0
> > > > State               : EMPTY
> > > > VxWorks Events
> > > > Options             : N/A
> > > > Synchronous group identifier hash table:
> > > > Hash table with 0 buckets and 0 items of type 4CASG installed
> > > > value = 0 = 0x0 X04SA-VME-ID2 >
> > > > Jeff Hill wrote:
> > > > > Dirk,
> > > > > The R3.14 design is more conservative from a perspective of
> > > > > avoiding positive congestion feedback. Here are the primary
> > > > > differences.
> > > > > O When a circuit times out the CAC library disconnects the
> > > > application, but
> > > > > not the circuit. We rely on TCP to decide when to give up
> > > > on a circuit, and
> > > > > disconnect it.
> > > > > O When the CAC library sees a beacon anomaly the search
> > > > rate receives a
> > > > > boost, but this boost is only to once every 5 seconds. In
> > > > contrast, newly
> > > > > created channels are initially searched for at a rate which
> > > > is closer to the
> > > > > average measured round trip time. The CAC library sends
> > > > multiple search
> > > > > requests per UDP frame, and depending on past success rates
> > > > also multiple
> > > > > UDP frames per periodic search attempt (that part isn't
> > > > different between
> > > > > R3.14 and R3.15). Nevertheless, if there many channels it
> > > > can take a little
> > > > > while to connect all of them if the IOC (or GW in this
> > > > situation has been
> > > > > off for a long time).
> > > > > O In R3.14 the CAC library never stops searching for
> > > > disconnected channels,
> > > > > but the maximum search rate is adjustable with an
> > > > environment variable.
> > > > >> I cannot see any search requests from that IOC.
> > > > > That doesn't sound right, but bear in mind that if the IOC
> > > > is sending
> > > > > unicasts, and not broadcasts, to the gateway on a switched
> > > > network then the
> > > > > network sniffer may or may not see them if it isn't
> > > > listening at the source
> > > > > or the destination cables. Directed broadcasts may also not
> > > > be seen by the
> > > > > network sniffer if it isn't sniffing directly on the
> > > > directed broadcast's
> > > > > destination subnet.
> > > > > The output from dbcar when its interest level argument is
> > > > set very high (say
> > > > > to 100) will show many things about the internals of the
> > > > CAC library. Also,
> > > > > there is a timer thread created by the CAC library that is
> > > > scheduling the
> > > > > search requests, and you might send a stack trace (if it
> > > > isn't simply
> > > > > waiting on its time delay event flag).
> > > > > Another possibility is that something is amiss in the GW.
> > > > Does restarting
> > > > > the GW improve the situation?
> > > > > Jeff ______________________________________________________
> > > > >> Sent: Wednesday, August 05, 2009 8:09 AM
> > > > >> To: tech-talk
> > > > >> Subject: CA reconnection problem
> > > > >> Hi all (Jeff in particular)
> > > > >> I have seen a problem with some of our IOCs today. Several
> > > > beamline IOCs
> > > > >> running
> > > > >> 3.14.8 have disconnected CA input links to a central IOC
> > > > (3.13.10) even
> > > > >> though
> > > > >> the channels are there. The beamline IOCs run behind ca
> > > > gateways. It may
> > > > >> be that
> > > > >> the gateways or the central IOC had been offline for more
> > > > than some hours
> > > > >> recently in the last shutdown.
> > > > >> Even though the channels are back and I can read them from
> > > > the beamline
> > > > >> network
> > > > >> with caget the IOCs don't reconnect.
> > > > >> I have started a softioc in the beamline network to
> > > > generate a beacon
> > > > >> anomaly
> > > > >> but even then the links do not reconnect. I cannot see any
> > > > search requests
> > > > >> from
> > > > >> that IOC.
> > > > >> Only 3.14.8 systems show this problem. 3.13. systems
> > > > don't. Is there a bug
> > > > >> in
> > > > >> the 3.14.8 implementation of CAC I should know of?
> > > > >> Dirk
> > > > >> Dr. Dirk Zimoch
> > > > >> Paul Scherrer Institut, WBGB/006
> > > > >> 5232 Villigen PSI, Switzerland
> > > > >> Phone +41 56 310 5182
> > > > Dr. Dirk Zimoch
> > > Scanned by iCritical.
RE: CA reconnection problem Jeff Hill
Prev: RE: CA reconnection problem Jeff Hill
Next: Re: Building ASYN on Windows - osdTime.cpp - Peace and Love John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: CA reconnection problem Jeff Hill
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
