1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Building ASYN on Windows
To: "John Dobbins" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Mon, 10 Aug 2009 14:34:27 -0500
John,
> I tried to pretend nothing was wrong, I ran makeBaseApp.pl for example
app
> and built it successfully, but when I run it I get:
> W:\tmp\example\iocBoot\iocmyExample>..\..\bin\win32-x86\myExample.exe
st.cmd
> epicsThread: Unknown C++ exception in thread "timerQueue" at Mon Aug
10
> 2009 15:03:39.518960139
That error does not have anything to do with your build errors, that is
a known bug in base 3.14.10 on win32-x86.
In the Known Problems file for 3.14.10
(http://www.aps.anl.gov/epics/base/R3-14/10-docs/KnownProblems.html)
you will see this item:
"IOCs or other EPICS programs running on a Win32 system with multiple
CPUs may die at startup. This patch applied to the
base/src/libCom/osi/os/WIN32/osdTime.cpp file solves an issue with time
provider registration on Windows."
Apply that patch to base and it should fix your problem.
-----Original Message-----
[mailto:[email protected]] On Behalf Of John Dobbins
Sent: Monday, August 10, 2009 2:31 PM
To: Andrew Johnson
Subject: Re: Building ASYN on Windows
> Hi John
> On Monday 10 August 2009 11:39:47 John Dobbins wrote:
>> The R3.14.10 Visual C++ build fails when executing the created file
>> genApps.exe.
>> The MinGW build fails when executing the created file dBToMenuH.exe
> Both of those failures were in programs that were built earlier in the
> process.  What is strange though is that those aren't the first
programs
> to
> be run that we built earlier; that honor goes to e_flex.exe and
> antelope.exe
> which are both used when compiling in the base/src/dbStatic directory
and
> which run quite happily on your builds.  Indeed for your Visual C++
build
> all
> of the code that you actually need to build IOCs and Mark's
areaDetector
> application have successfully been built by that stage, so you could
> ignore
> the gdd build failure (which is only needed for non-IOC CA servers)
and
> continue on to compile your other modules at this point.
> Question: What was your PATH set to when you were building these?  You
> didn't
> have the bin directory from another release of Base or from the EPICS
> Win32
> extensions in the path did you?  I would guess not, but I'd like to be
> sure
> of that.
PATH =
C:\Perl\site\bin;C:\Perl\bin;C:\Xilinx\10.1\ISE\bin\nt;C:\Xilinx\10.1\IS
E\lib\nt;C:\Xilinx\10.1\ISE\smartmodel\nt\installed_nt\lib\pcnt.lib;C:\W
INDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;C:\Program
Files\Hummingbird\Connectivity\11.00\Accessories\;c:\program
files\microsoft sql server\90\tools\binn\;C:\Program
Files\MATLAB\R2006a\bin\win32;C:\Program
Files\Sudowin\Clients\Console;C:\Program
Files\TortoiseSVN\bin;C:\strawberry\c\bin;C:\strawberry\perl\bin;C:\Prog
ram
Files\Agilent\IO Libraries Suite\bin;C:\Program Files\IVI
Foundation\IVI\bin;C:\Program Files\IVI
Foundation\VISA\WinNT\Bin\;C:\Program Files\IVI
Foundation\VISA\winnt\agvisa;C:\Program Files\Microsoft Visual Studio
8\VC\bin;C:\Program Files\Microsoft Visual Studio
8\Common7\IDE;C:\Program
Files\GnuWin32\bin;W:\winDev\epics\R3.14.10\base-3.14.10\bin\win32-x86
>> I am including the full output from both builds below, which includes
>> some warnings.
> At a brief glance through I recognize many of those warnings, which
are
> not
> something that could have caused this problem.
> The interesting thing is that in both cases the same error code
occurs,
> which
> Mark Rivers points out to mean access violation (I'm taking his word
> there).
>> Any advice on how to proceed from this point would be welcome.
> If you still have or can repeat the VC++ build, just use that and
ignore
> the
> build failure in gdd, the parts of Base you need have already built
> correctly
> by then so you can continue to build the other modules.  It would be
good
> to
> get to the bottom of this though.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold
Welte
app
st.cmd
epicsThread: Unknown C++ exception in thread "timerQueue" at Mon Aug 10
2009 15:
03:39.518960139
#!../../bin/win32-x86/myExample
## You may have to change myExample to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","win32-x86")
epicsEnvSet("IOC","iocmyExample")
epicsEnvSet("TOP","W:/tmp/example")
epicsEnvSet("EPICS_BASE","W:/winDev/epics/R3.14.10/base-3.14.10")
cd W:/tmp/example
dbLoadDatabase "dbd/myExample.dbd"
myExample_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/userHost.substitutions"
dbLoadRecords "db/dbSubExample.db", "user=erpoprHost"
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
cd W:/tmp/example/iocBoot/iocmyExample
iocInit
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Aug 10 2009
This application has requested the Runtime to terminate it in an unusual
way. Please contact the application's support team for more information.
## Start any sequence programs
#seq sncExample, "user=erpoprHost"
epics>
At which point I get a Windows dialog to choose debug/send/don't_send
error report.
John
RE: Building ASYN on Windows John Dobbins
RE: Building ASYN on Windows Mark Rivers
Re: Building ASYN on Windows Andrew Johnson
Re: Building ASYN on Windows John Dobbins
Prev: RE: Building ASYN on Windows John Dobbins
Next: RE: Building ASYN on Windows John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Building ASYN on Windows John Dobbins
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
