> So that's interesting, if you manually type the command it works, but if
> it is run as part of the "make" build process it fails?
> What version of "make" were you running, i.e. where did you get it?
> Mark
Sorry, I thought I had included that info.
I am using Make from GnuWin32, download from
http://gnuwin32.sourceforge.net/packages.html
John
> -----Original Message-----
> From: John Dobbins [mailto:[email protected]]
> Sent: Monday, August 10, 2009 2:20 PM
> To: Mark Rivers
> Cc: EPICS Tech-Talk
> Subject: RE: Building ASYN on Windows
>> John,
>> The error you get with the VC++ compiler is:
>> "Installing created file ../../../bin/win32-x86/genApps.exe"
>> ../../../bin/win32-x86/genApps.exe ../O.Common/gddApps.h
>> make[3]: *** [../O.Common/gddApps.h] Error -1073741819
>> Does O.Common/gddApps.h exist?
> No.
>> What happens if you go the O.win32-x86 directory being built there and
>> just manually type the same command:
> gddApps.h is create (appended a end of message)
>> Do you get an error?
> No
>> The error code you are getting is -1073741819, which is 0xC0000005.
>> That is an access violation on Windows.
>> I don't think this is your problem, but are you running the version of
>> GNU make that works with EPICS 3.14.x? The version that comes with
>> Cygwin does not work, even though it also has the version number 3.81.
>> The 3.14.10 release notes discuss this under the section on Cygwin
>> builds:
>> "The cygwin make version 3.81-1 does not handle MS-DOS path names and
>> thus does not work for EPICS builds with RELEASE file definitions.
> From
>> the discussion on the cygwin mailing list it looks like this will be
>> fixed in make version 3.82. In the meantime make version 3.80 or a
> fixed
>> make can be downloaded from this website."
> I can install Cygwyn and the modified version of Make.
>> From: [email protected]
>> [mailto:[email protected]] On Behalf Of John Dobbins
>> Sent: Monday, August 10, 2009 11:40 AM
>> To: EPICS Tech-Talk
>> All,
>> I wrote previously:
>> I tried to build 3.14.10 base on WindowsXP Professional 2002 SP 3 with
>> SHARED_LIBRARIES=NO and STATIC_BUILD=YES
>> but get an error. I am able to build 3.14.9 with these options and the
>> same tools.
>> link -nologo /LTCG /incremental:no /opt:ref /release /version:3.14
>> -out:genApps.exe genApps.obj gdd.obj gddTest.obj gddAppTable.obj
>> gddNewDel.obj gddAppDefs.obj aitTypes.obj aitConvert.obj
> aitHelpers.obj
>> gddArray.obj gddContainer.obj gddErrorCodes.obj gddUtils.obj
>> gddEnumStringTable.obj ../../../lib/win32-x86/Com.lib ws2_32.lib
>> ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
>> Generating code
>> Finished generating code
>> make[3]: Leaving directory
>> `W:/winDev/epics/R3.14.10/support/base/src/gdd/O.win3
>> 2-x86'
>> make[2]: *** [install.win32-x86] Error 2
>> make[2]: Leaving directory
>> `W:/winDev/epics/R3.14.10/support/base/src/gdd' make[1]: ***
>> [gdd.install] Error 2
>> make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/base/src'
>> make: *** [src.install] Error 2
>> Since then I have built R3.14.10 with
>> on two of my home computers, Windows XP Home Edition 2002 SP 3, in one
>> case using MinGW and in the other case Microsoft Visual C++ 2008
> Express
>> Edition, however I remain unable to do this on our lab computers.
>> On our lab computers I have tried
>> Microsoft Visual C++ 2005, Perl 5.10, Gnu Make 3.81
>> and
>> MinGW, Perl 5.10, Gnu Make 3.81
>> The R3.14.10 Visual C++ build fails when executing the created file
>> genApps.exe.
>> The MinGW build fails when executing the created file dBToMenuH.exe
>> I am including the full output from both builds below, which includes
>> some warnings.
>> Any advice on how to proceed from this point would be welcome.
>> My eventual goal is to run the latest version on areaDetector on
> Windows
>> hence the desire for R3.14.10. Mark Rivers has recommended the
>> STATIC_BUILD for ease of relocating executables.
>> Thanks,
>> John Dobbins
>> environment variables:
>> INCLUDE = C:\Program Files\Microsoft Visual Studio
>> 8\VC\PlatformSDK\include;C:\Program Files\Microsoft Visual Studio
>> 8\VC\include
>> LIB = C:\Program Files\Microsoft Visual Studio 8\VC\lib;C:\Program
>> Files\Microsoft Visual Studio 8\VC\PlatformSDK\Lib
> gddApps.h
> #define gddAppType_status 1
> #define gddAppType_severity 2
> #define gddAppType_timeStamp 3
> #define gddAppType_name 4
> #define gddAppType_class 5
> #define gddAppType_precision 6
> #define gddAppType_graphicHigh 7
> #define gddAppType_graphicLow 8
> #define gddAppType_controlHigh 9
> #define gddAppType_controlLow 10
> #define gddAppType_alarmHigh 11
> #define gddAppType_alarmLow 12
> #define gddAppType_alarmHighWarning 13
> #define gddAppType_alarmLowWarning 14
> #define gddAppType_maxElements 15
> #define gddAppType_value 16
> #define gddAppType_enums 17
> #define gddAppType_units 18
> #define gddAppTypeIndex_units 0
> #define gddAppType_ackt 19
> #define gddAppType_acks 20
> #define gddAppType_attributes 21
> #define gddAppTypeIndex_attributes 0
> #define gddAppTypeIndex_attributes_maxElements 1
> #define gddAppTypeIndex_attributes_units 2
> #define gddAppTypeIndex_attributes_alarmLowWarning 3
> #define gddAppTypeIndex_attributes_alarmHighWarning 4
> #define gddAppTypeIndex_attributes_alarmLow 5
> #define gddAppTypeIndex_attributes_alarmHigh 6
> #define gddAppTypeIndex_attributes_controlLow 7
> #define gddAppTypeIndex_attributes_controlHigh 8
> #define gddAppTypeIndex_attributes_graphicLow 9
> #define gddAppTypeIndex_attributes_graphicHigh 10
> #define gddAppTypeIndex_attributes_precision 11
> #define gddAppType_all 22
> #define gddAppTypeIndex_all 0
> #define gddAppTypeIndex_all_value 1
> #define gddAppTypeIndex_all_units 2
> #define gddAppTypeIndex_all_alarmLowWarning 3
> #define gddAppTypeIndex_all_alarmHighWarning 4
> #define gddAppTypeIndex_all_alarmLow 5
> #define gddAppTypeIndex_all_alarmHigh 6
> #define gddAppTypeIndex_all_controlLow 7
> #define gddAppTypeIndex_all_controlHigh 8
> #define gddAppTypeIndex_all_graphicLow 9
> #define gddAppTypeIndex_all_graphicHigh 10
> #define gddAppTypeIndex_all_precision 11
> #define gddAppType_dbr_gr_short 23
> #define gddAppTypeIndex_dbr_gr_short 0
> #define gddAppTypeIndex_dbr_gr_short_units 1
> #define gddAppTypeIndex_dbr_gr_short_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_short_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_short_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_short_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_short_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_short_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_short_value 8
> #define gddAppType_dbr_gr_float 24
> #define gddAppTypeIndex_dbr_gr_float 0
> #define gddAppTypeIndex_dbr_gr_float_units 1
> #define gddAppTypeIndex_dbr_gr_float_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_float_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_float_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_float_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_float_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_float_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_float_precision 8
> #define gddAppTypeIndex_dbr_gr_float_value 9
> #define gddAppType_dbr_gr_enum 25
> #define gddAppTypeIndex_dbr_gr_enum 0
> #define gddAppTypeIndex_dbr_gr_enum_value 1
> #define gddAppTypeIndex_dbr_gr_enum_enums 2
> #define gddAppType_dbr_gr_char 26
> #define gddAppTypeIndex_dbr_gr_char 0
> #define gddAppTypeIndex_dbr_gr_char_units 1
> #define gddAppTypeIndex_dbr_gr_char_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_char_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_char_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_char_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_char_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_char_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_char_value 8
> #define gddAppType_dbr_gr_long 27
> #define gddAppTypeIndex_dbr_gr_long 0
> #define gddAppTypeIndex_dbr_gr_long_units 1
> #define gddAppTypeIndex_dbr_gr_long_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_long_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_long_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_long_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_long_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_long_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_long_value 8
> #define gddAppType_dbr_gr_double 28
> #define gddAppTypeIndex_dbr_gr_double 0
> #define gddAppTypeIndex_dbr_gr_double_units 1
> #define gddAppTypeIndex_dbr_gr_double_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_gr_double_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_gr_double_alarmLow 4
> #define gddAppTypeIndex_dbr_gr_double_alarmHigh 5
> #define gddAppTypeIndex_dbr_gr_double_graphicLow 6
> #define gddAppTypeIndex_dbr_gr_double_graphicHigh 7
> #define gddAppTypeIndex_dbr_gr_double_precision 8
> #define gddAppTypeIndex_dbr_gr_double_value 9
> #define gddAppType_dbr_ctrl_short 29
> #define gddAppTypeIndex_dbr_ctrl_short 0
> #define gddAppTypeIndex_dbr_ctrl_short_units 1
> #define gddAppTypeIndex_dbr_ctrl_short_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_short_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_short_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_short_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_short_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_short_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_short_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_short_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_short_value 10
> #define gddAppType_dbr_ctrl_float 30
> #define gddAppTypeIndex_dbr_ctrl_float 0
> #define gddAppTypeIndex_dbr_ctrl_float_units 1
> #define gddAppTypeIndex_dbr_ctrl_float_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_float_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_float_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_float_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_float_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_float_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_float_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_float_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_float_precision 10
> #define gddAppTypeIndex_dbr_ctrl_float_value 11
> #define gddAppType_dbr_ctrl_enum 31
> #define gddAppTypeIndex_dbr_ctrl_enum 0
> #define gddAppTypeIndex_dbr_ctrl_enum_value 1
> #define gddAppTypeIndex_dbr_ctrl_enum_enums 2
> #define gddAppType_dbr_ctrl_char 32
> #define gddAppTypeIndex_dbr_ctrl_char 0
> #define gddAppTypeIndex_dbr_ctrl_char_units 1
> #define gddAppTypeIndex_dbr_ctrl_char_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_char_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_char_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_char_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_char_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_char_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_char_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_char_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_char_value 10
> #define gddAppType_dbr_ctrl_long 33
> #define gddAppTypeIndex_dbr_ctrl_long 0
> #define gddAppTypeIndex_dbr_ctrl_long_units 1
> #define gddAppTypeIndex_dbr_ctrl_long_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_long_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_long_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_long_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_long_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_long_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_long_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_long_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_long_value 10
> #define gddAppType_dbr_ctrl_double 34
> #define gddAppTypeIndex_dbr_ctrl_double 0
> #define gddAppTypeIndex_dbr_ctrl_double_units 1
> #define gddAppTypeIndex_dbr_ctrl_double_alarmLowWarning 2
> #define gddAppTypeIndex_dbr_ctrl_double_alarmHighWarning 3
> #define gddAppTypeIndex_dbr_ctrl_double_alarmLow 4
> #define gddAppTypeIndex_dbr_ctrl_double_alarmHigh 5
> #define gddAppTypeIndex_dbr_ctrl_double_controlLow 6
> #define gddAppTypeIndex_dbr_ctrl_double_controlHigh 7
> #define gddAppTypeIndex_dbr_ctrl_double_graphicLow 8
> #define gddAppTypeIndex_dbr_ctrl_double_graphicHigh 9
> #define gddAppTypeIndex_dbr_ctrl_double_precision 10
> #define gddAppTypeIndex_dbr_ctrl_double_value 11
> #define gddAppType_dbr_stsack_string 35
> #define gddAppTypeIndex_dbr_stsack_string 0
> #define gddAppTypeIndex_dbr_stsack_string_ackt 1
> #define gddAppTypeIndex_dbr_stsack_string_acks 2
> #define gddAppTypeIndex_dbr_stsack_string_value 3
- Re: Building ASYN on Windows Andrew Johnson
- Building ASYN on Windows John Dobbins
- RE: Building ASYN on Windows Mark Rivers
- RE: Building ASYN on Windows John Dobbins
Re: Building ASYN on Windows John Dobbins
<2009>
<2009>
