1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Building ASYN on Windows
To: "John Dobbins" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Mon, 10 Aug 2009 12:05:54 -0500
John,
The error you get with the VC++ compiler is:
"Installing created file ../../../bin/win32-x86/genApps.exe"
../../../bin/win32-x86/genApps.exe ../O.Common/gddApps.h
make[3]: *** [../O.Common/gddApps.h] Error -1073741819
Does O.Common/gddApps.h exist?
What happens if you go the O.win32-x86 directory being built there and
just manually type the same command:
Do you get an error?
The error code you are getting is -1073741819, which is 0xC0000005.
That is an access violation on Windows.
I don't think this is your problem, but are you running the version of
GNU make that works with EPICS 3.14.x?  The version that comes with
Cygwin does not work, even though it also has the version number 3.81.
The 3.14.10 release notes discuss this under the section on Cygwin
builds:
"The cygwin make version 3.81-1 does not handle MS-DOS path names and
thus does not work for EPICS builds with RELEASE file definitions. From
the discussion on the cygwin mailing list it looks like this will be
fixed in make version 3.82. In the meantime make version 3.80 or a fixed
make can be downloaded from this website."
-----Original Message-----
[mailto:[email protected]] On Behalf Of John Dobbins
Sent: Monday, August 10, 2009 11:40 AM
To: EPICS Tech-Talk
All,
I wrote previously:
I tried to build 3.14.10 base on WindowsXP Professional 2002 SP 3 with
SHARED_LIBRARIES=NO and STATIC_BUILD=YES
but get an error. I am able to build 3.14.9 with these options and the
same tools.
link -nologo  /LTCG /incremental:no /opt:ref /release /version:3.14
-out:genApps.exe   genApps.obj gdd.obj gddTest.obj gddAppTable.obj
gddNewDel.obj gddAppDefs.obj aitTypes.obj aitConvert.obj aitHelpers.obj
gddArray.obj gddContainer.obj gddErrorCodes.obj gddUtils.obj
gddEnumStringTable.obj    ../../../lib/win32-x86/Com.lib ws2_32.lib
ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Generating code
Finished generating code
make[3]: Leaving directory
`W:/winDev/epics/R3.14.10/support/base/src/gdd/O.win3
2-x86'
make[2]: *** [install.win32-x86] Error 2
make[2]: Leaving directory
`W:/winDev/epics/R3.14.10/support/base/src/gdd' make[1]: ***
[gdd.install] Error 2
make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/base/src'
make: *** [src.install] Error 2
Since then I have built R3.14.10 with
on two of my home computers, Windows XP Home Edition 2002 SP 3, in one
case using MinGW and in the other case Microsoft Visual C++ 2008 Express
Edition, however I remain unable  to do this on our lab computers.
On our lab computers I have tried
Microsoft Visual C++ 2005, Perl 5.10, Gnu Make 3.81
and
MinGW, Perl 5.10, Gnu Make 3.81
The R3.14.10 Visual C++ build fails when executing the created file
genApps.exe.
The MinGW build fails when executing the created file dBToMenuH.exe
I am including the full output from both builds below, which includes
some warnings.
Any advice on how to proceed from this point would be welcome.
My eventual goal is to run the latest version on areaDetector on Windows
hence the desire for R3.14.10. Mark Rivers has recommended the
STATIC_BUILD for ease of relocating executables.
John Dobbins
environment variables:
INCLUDE = C:\Program Files\Microsoft Visual Studio
8\VC\PlatformSDK\include;C:\Program Files\Microsoft Visual Studio
8\VC\include
LIB = C:\Program Files\Microsoft Visual Studio 8\VC\lib;C:\Program
Files\Microsoft Visual Studio 8\VC\PlatformSDK\Lib
      Visual C++ Build Output
make -C ./configure install
make[1]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/configure'
C:\perl\bin\perl.exe ../src/tools/makeMakefile.pl O.win32-x86 ../..
C:\perl\bin\perl.exe -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/configure/O.win32-x86'
make[2]: Nothing to be done for `install'.
make -C ./src install
make[1]: Entering directory `W:/winDev/epics/R3.14.10/base-3.14.10/src'
make -C ./tools install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/tools'
C:\perl\bin\perl.exe ../../src/tools/makeMakefile.pl O.win32-x86
../../.. C:\perl\bin\perl.exe -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/tools/O.win32-x86'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing script ../../../bin/win32-x86/convertRelease.pl"
mkdir ../../../bin
mkdir ../../../bin/win32-x86
"Installing script ../../../bin/win32-x86/cvsclean.pl"
"Installing script ../../../bin/win32-x86/dos2unix.pl"
"Installing script ../../../bin/win32-x86/expandVars.pl"
"Installing script ../../../bin/win32-x86/filterWarnings.pl"
"Installing script ../../../bin/win32-x86/fullPathName.pl"
"Installing script ../../../bin/win32-x86/installEpics.pl"
"Installing script ../../../bin/win32-x86/makeDbDepends.pl"
"Installing script ../../../bin/win32-x86/makeIncludeDbd.pl"
"Installing script ../../../bin/win32-x86/makeMakefile.pl"
"Installing script ../../../bin/win32-x86/makeTestfile.pl"
"Installing script ../../../bin/win32-x86/mkmf.pl"
"Installing script ../../../bin/win32-x86/munch.pl"
"Installing script ../../../bin/win32-x86/replaceVAR.pl"
"Installing script ../../../bin/win32-x86/useManifestTool.pl"
make -C ./makeBaseApp install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseApp'
C:\perl\bin\perl.exe ../../bin/win32-x86/makeMakefile.pl O.win32-x86
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseApp/O.win32-x86'
"Installing script ../../../bin/win32-x86/makeBaseApp.pl"
"Installing ../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../templates
mkdir ../../../templates/makeBaseApp
mkdir ../../../templates/makeBaseApp/top
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../templates/makeBaseApp/top/configure
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp
"Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/src
"Installing
../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp
"Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile" mkdir
"Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp/src
"Installing
../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/Db
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/userHost.substitutions"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/src
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleBoot
"Installing
../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing
../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing
../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocBoot
"Installing
../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing
../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make -C ./makeBaseExt install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseExt'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseExt/O.win32-x86'
"Installing script ../../../bin/win32-x86/makeBaseExt.pl"
"Installing ../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../templates/makeBaseExt
mkdir ../../../templates/makeBaseExt/top
"Installing ../../../templates/makeBaseExt/top/README"
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../templates/makeBaseExt/top/configure
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-3
86"
mkdir ../../../templates/makeBaseExt/top/configure/os
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland
.win32-x86-borland"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.
aix-ppc-gnu"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-
ppc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Commo
n"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.c
ygwin-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.d
arwin-ppc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx8
6.darwin-ppcx86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.d
arwin-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_
64.freebsd-x86_64"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-
gnu.hpux-parisc-gnu"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.
hpux-parisc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.
interix-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.li
nux-ppc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-bo
rland.linux-x86-borland"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-de
bug.linux-x86-debug"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.li
nux-athlon"
"Installing
nux-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64
-debug.linux-x86_64-debug"
"Installing
.linux-x86_64"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.osf-alpha.os
f-alpha"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-spar
c-debug.solaris-sparc-debug"
"Installing
c-gnu.solaris-sparc-gnu"
"Installing
c.solaris-sparc"
"Installing
c64-gnu.solaris-sparc64-gnu"
"Installing
c64.solaris-sparc64"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-
gnu.solaris-x86-gnu"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.
solaris-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-bo
rland.win32-x86-borland"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cy
gwin.win32-x86-cygwin"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-de
bug.win32-x86-debug"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mi
ngw.win32-x86-mingw"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.wi
n32-x86"
"Installing ../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../templates/makeBaseExt/top/src
"Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing
../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile" mkdir
make -C ./libCom install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/libCom'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/libCom/O.win32-x86'
C:\perl\bin\perl.exe ../../../src/libCom/misc/makeEpicsVersion.pl
../../../configure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.14.10
"Installing generated generic include file
../../../include/epicsVersion.h"
mkdir ../../../include
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
../../../include/ipAddrToAsciiAsynchronous.h"
../../../include/compilerDependencies.h" "Installing generic include
file ../../../include/epicsUnitTest.h" "Installing generic include file
../../../include/testMain.h"
../../../include/os/WIN32/osiFileName.h" mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing generic include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
"Installing os dependent include file
../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing generic include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing generic include file ../../../include/os/WIN32/osdEvent.h"
"Installing generic include file ../../../include/os/WIN32/epicsMath.h"
../../../include/os/WIN32/osdMessageQueue.h"
"Installing generic include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
../../../include/os/WIN32/osdPoolStatus.h"
"Installing generic include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing generic include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing generic include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
../../../include/os/WIN32/osdWireFormat.h"
../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsEndian.h"
../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
../../../include/os/WIN32/epicsGetopt.h" "Installing generic include
file ../../../include/devLib.h"
../../../include/os/WIN32/osdVME.h" "Installing generic include file
../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/tsDefs.h"
rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
-I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClient -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -I../../../include/os/WIN32
-I../../../include        -fo Com.res ../Com.rc
cl -c                /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /nologo /D__STDC__=0   /Ox /GL   /W3 /w44355
        /MT -DEPICS_DLL_NO   -I. -I..\\O.Common -I.
-I..\\..\\..\\src\\libCom\\osi\\os\\WIN32
-I..\\..\\..\\src\\libCom\\osi\\os\\default -I..
-I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring
-I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast
-I..\\..\\..\\src\\libCom\\cppStd
-I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf
  -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env
-I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr
-I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash
-I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient
-I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc
-I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd
-I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
bucketLib.c
cl /nologo /EHsc /GR -c                /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0   /Ox /GL   /W3 /w44355
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        /Tp
..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
..\\..\\..\\src\\libCom\\ring\\epicsRingBytes.c
epicsRingBytes.c
..\\..\\..\\src\\libCom\\calc\\postfix.c
postfix.c
C:\Program Files\Microsoft Visual Studio 8\VC\include\stdlib.h(885) :
warning C4005: 'max' : macro redefinition
          ..\..\..\src\libCom\misc\dbDefs.h(55) : see previous
definition
of 'max'
..\..\..\src\libCom\calc\postfix.c(207) : warning C4028: formal
parameter 2 different from declaration
..\\..\\..\\src\\libCom\\calc\\calcPerform.c
calcPerform.c
..\\..\\..\\src\\libCom\\cvtFast\\cvtFast.c
cvtFast.c
..\\..\\..\\src\\libCom\\cxxTemplates\\resourceLib.cpp
resourceLib.cpp
..\\..\\..\\src\\libCom\\cxxTemplates\\epicsOnce.cpp
epicsOnce.cpp
..\\..\\..\\src\\libCom\\cxxTemplates\\epicsSingletonMutex.cpp
..\\..\\..\\src\\libCom\\dbmf\\dbmf.c
dbmf.c
..\\..\\..\\src\\libCom\\ellLib\\ellLib.c
ellLib.c
..\\..\\..\\src\\libCom\\env\\envSubr.c
envSubr.c
C:\perl\bin\perl.exe ../../../src/libCom/env/bldEnvData.pl
../../../configure
Generating envData.c
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include         envData.c
envData.c
..\\..\\..\\src\\libCom\\error\\errlog.c
errlog.c
..\..\..\src\libCom\error\errlog.c(106) : warning C4018: '>=' :
signed/unsigned mismatch
..\\..\\..\\src\\libCom\\error\\errSymLib.c
errSymLib.c
C:\perl\bin\perl.exe ../../../src/libCom/error/makeStatTbl.pl
../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h
../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h
../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h
../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h
  ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h
cl -c
errSymTbl.c errSymTbl.c
..\\..\\..\\src\\libCom\\fdmgr\\fdmgr.cpp
fdmgr.cpp
..\\..\\..\\src\\libCom\\fdmgr\\fdManager.cpp
fdManager.cpp
..\\..\\..\\src\\libCom\\freeList\\freeListLib.c
freeListLib.c
..\\..\\..\\src\\libCom\\gpHash\\gpHashLib.c
gpHashLib.c
..\\..\\..\\src\\libCom\\iocsh\\iocsh.cpp
iocsh.cpp
..\\..\\..\\src\\libCom\\iocsh\\registry.c
registry.c
..\\..\\..\\src\\libCom\\iocsh\\libComRegister.c
libComRegister.c
..\\..\\..\\src\\libCom\\logClient\\iocLog.c
iocLog.c
..\\..\\..\\src\\libCom\\logClient\\logClient.c
logClient.c
..\\..\\..\\src\\libCom\\macLib\\macCore.c
macCore.c
..\\..\\..\\src\\libCom\\macLib\\macEnv.c
macEnv.c
..\\..\\..\\src\\libCom\\macLib\\macUtil.c
macUtil.c
..\..\..\src\libCom\macLib\macUtil.c(229) : warning C4090: 'function' :
  different 'const' qualifiers
..\..\..\src\libCom\macLib\macUtil.c(230) : warning C4090: 'function' :
..\..\..\src\libCom\macLib\macUtil.c(243) : warning C4090: 'function' :
..\..\..\src\libCom\macLib\macUtil.c(244) : warning C4090: 'function' :
..\\..\\..\\src\\libCom\\misc\\aToIPAddr.c
aToIPAddr.c
..\\..\\..\\src\\libCom\\misc\\adjustment.c
adjustment.c
..\\..\\..\\src\\libCom\\misc\\cantProceed.c
cantProceed.c
..\\..\\..\\src\\libCom\\misc\\epicsConvert.c
epicsConvert.c
..\\..\\..\\src\\libCom\\misc\\epicsExit.c
epicsExit.c
..\\..\\..\\src\\libCom\\misc\\epicsStdlib.c
epicsStdlib.c
..\..\..\src\libCom\misc\epicsStdlib.c(42) : warning C4244: '=' :
conversion from 'double' to 'float', possible loss of data
..\\..\\..\\src\\libCom\\misc\\epicsString.c
epicsString.c
..\\..\\..\\src\\libCom\\misc\\truncateFile.c
truncateFile.c
..\\..\\..\\src\\libCom\\misc\\ipAddrToAsciiAsynchronous.cpp
..\\..\\..\\src\\libCom\\misc\\epicsUnitTest.c
epicsUnitTest.c
..\\..\\..\\src\\libCom\\osi\\epicsThread.cpp
epicsThread.cpp
..\..\..\src\libCom\osi\epicsThread.cpp(83) : warning C4297:
'epicsThreadCallEntryPoint' : function assumed not to throw an exception
  but does
          The function is extern "C" and /EHc was specified
  but does
..\\..\\..\\src\\libCom\\osi\\epicsMutex.cpp
epicsMutex.cpp
..\\..\\..\\src\\libCom\\osi\\epicsEvent.cpp
epicsEvent.cpp
..\\..\\..\\src\\libCom\\osi\\epicsTime.cpp
epicsTime.cpp
..\..\..\src\libCom\osi\epicsTime.cpp(339) : warning C4244: '=' :
conversion from 'time_t' to 'long', possible loss of data
..\\..\\..\\src\\libCom\\osi\\epicsMessageQueue.cpp
..\\..\\..\\src\\libCom\\osi\\epicsGeneralTime.c
epicsGeneralTime.c
..\\..\\..\\src\\libCom\\osi\\osiClockTime.c
osiClockTime.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSock.c
osdSock.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSockAddrReuse.cpp
..\\..\\..\\src\\libCom\\osi\\osiSock.c
osiSock.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\systemCallIntMech.cpp
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsSocketConvertErrnoToString
.cpp
epicsSocketConvertErrnoToString.cpp
..\\..\\..\\src\\libCom\\osi\\os\\default\\osdAssert.c
osdAssert.c
..\\..\\..\\src\\libCom\\osi\\os\\default\\osdFindSymbol.c
osdFindSymbol.c
..\\..\\..\\src\\libCom\\osi\\os\\default\\osdInterrupt.c
osdInterrupt.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdPoolStatus.c
osdPoolStatus.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSignal.cpp
osdSignal.cpp
   -U__STDC__     /MT -DEPICS_DLL_NO   -I. -I..\\O.Common -I.
..\\..\\..\\src\\libCom\\osi\\os\\default\\osdEnv.c
cl : Command line warning D9025 : overriding '/D__STDC__=0' with
'/U__STDC__'
osdEnv.c
    -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS    /MT
..\\..\\..\\src\\libCom\\osi\\os\\default\\epicsReadline.c
epicsReadline.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsTempFile.cpp
epicsTempFile.cpp
..\\..\\..\\src\\libCom\\osi\\epicsStdio.c
epicsStdio.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdStdio.c
osdStdio.c
cl -c           -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING
/D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /nologo
/D__STDC__=0   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO   -I.
-I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdThread.c
osdThread.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdMutex.c
osdMutex.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdEvent.c
osdEvent.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdTime.cpp
osdTime.cpp
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdProcess.c
osdProcess.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdNetIntf.c
osdNetIntf.c
..\\..\\..\\src\\libCom\\osi\\os\\default\\osdMessageQueue.cpp
osdMessageQueue.cpp
..\\..\\..\\src\\libCom\\osi\\devLib.c
devLib.c
..\\..\\..\\src\\libCom\\osi\\os\\default\\devLibOSD.c
devLibOSD.c
..\\..\\..\\src\\libCom\\taskwd\\taskwd.c
taskwd.c
..\\..\\..\\src\\libCom\\timer\\epicsTimer.cpp
epicsTimer.cpp
..\\..\\..\\src\\libCom\\timer\\timer.cpp
timer.cpp
..\\..\\..\\src\\libCom\\timer\\timerQueue.cpp
timerQueue.cpp
..\\..\\..\\src\\libCom\\timer\\timerQueueActive.cpp
..\\..\\..\\src\\libCom\\timer\\timerQueueActiveMgr.cpp
..\\..\\..\\src\\libCom\\timer\\timerQueuePassive.cpp
..\\..\\..\\src\\libCom\\tsDefs\\tsDefs.c
tsDefs.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsGetopt.c
epicsGetopt.c
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\setThreadName.cpp
setThreadName.cpp
..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\forceBadAllocException.cpp
lib /nologo /verbose /out:Com.lib        bucketLib.obj
epicsRingPointer.obj epicsRingBytes.obj postfix.obj calcPerform.obj
cvtFast.obj resourceLib.obj epicsOnce.obj epicsSingletonMutex.obj
dbmf.obj ellLib.obj envSubr.obj envData.obj errlog.obj errSymLib.obj
errSymTbl.obj fdmgr.obj fdManager.obj freeListLib.obj gpHashLib.obj
iocsh.obj registry.obj libComRegister.obj iocLog.obj logClient.obj
macCore.obj macEnv.obj macUtil.obj aToIPAddr.obj adjustment.obj
cantProceed.obj epicsConvert.obj epicsExit.obj epicsStdlib.obj
epicsString.obj truncateFile.obj ipAddrToAsciiAsynchronous.obj
epicsUnitTest.obj epicsThread.obj epicsMutex.obj epicsEvent.obj
epicsTime.obj epicsMessageQueue.obj epicsGeneralTime.obj
osiClockTime.obj osdSock.obj osdSockAddrReuse.obj osiSock.obj
systemCallIntMech.obj epicsSocketConvertErrnoToString.obj osdAssert.obj
  osdFindSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj
osdEnv.obj epicsReadline.obj epicsTempFile.obj epicsStdio.obj
osdStdio.obj osdThread.obj osdMutex.obj osdEvent.obj osdTime.obj
osdProcess.obj osdNetIntf.obj osdMessageQueue.obj devLib.obj
devLibOSD.obj taskwd.obj epicsTimer.obj timer.obj timerQueue.obj
timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj
tsDefs.obj epicsGetopt.obj setThreadName.obj forceBadAllocException.obj
forceBadAllocException.obj : MSIL .netmodule or module compiled with /GL
  found; restarting link with /LTCG; add /LTCG to the link command line
to  improve linker performance
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:Com.lib" "bucketLib.obj"
"epicsRingPointer.obj" "epicsRingBytes.obj" "postfix.obj"
"calcPerform.obj" "cvtFast.obj" "resourceLib.obj" "epicsOnce.obj"
"epicsSingletonMutex.obj" "dbmf.obj" "ellLib.obj" "envSubr.obj"
"envData.obj" "errlog.obj" "errSymLib.obj" "errSymTbl.obj" "fdmgr.obj"
"fdManager.obj" "freeListLib.obj" "gpHashLib.obj" "iocsh.obj"
"registry.obj" "libComRegister.obj" "iocLog.obj" "logClient.obj"
"macCore.obj" "macEnv.obj" "macUtil.obj" "aToIPAddr.obj"
"adjustment.obj" "cantProceed.obj" "epicsConvert.obj" "epicsExit.obj"
"epicsStdlib.obj" "epicsString.obj" "truncateFile.obj"
"ipAddrToAsciiAsynchronous.obj" "epicsUnitTest.obj" "epicsThread.obj"
"epicsMutex.obj" "epicsEvent.obj" "epicsTime.obj"
"epicsMessageQueue.obj" "epicsGeneralTime.obj" "osiClockTime.obj"
"osdSock.obj" "osdSockAddrReuse.obj" "osiSock.obj"
"systemCallIntMech.obj" "epicsSocketConvertErrnoToString.obj"
"osdAssert.obj" "osdFindSymbol.obj" "osdInterrupt.obj"
"osdPoolStatus.obj" "osdSignal.obj" "osdEnv.obj" "epicsReadline.obj"
"epicsTempFile.obj" "epicsStdio.obj" "osdStdio.obj" "osdThread.obj"
"osdMutex.obj" "osdEvent.obj" "osdTime.obj" "osdProcess.obj"
"osdNetIntf.obj" "osdMessageQueue.obj" "devLib.obj" "devLibOSD.obj"
"taskwd.obj" "epicsTimer.obj" "timer.obj" "timerQueue.obj"
"timerQueueActive.obj" "timerQueueActiveMgr.obj" "timerQueuePassive.obj"
  "tsDefs.obj" "epicsGetopt.obj" "setThreadName.obj"
"forceBadAllocException.obj"
   /LTCG
Appending forceBadAllocException.obj
Appending setThreadName.obj
Appending epicsGetopt.obj
Appending tsDefs.obj
Appending timerQueuePassive.obj
Appending timerQueueActiveMgr.obj
Appending timerQueueActive.obj
Appending timerQueue.obj
Appending timer.obj
Appending epicsTimer.obj
Appending taskwd.obj
Appending devLibOSD.obj
Appending devLib.obj
Appending osdMessageQueue.obj
Appending osdNetIntf.obj
Appending osdProcess.obj
Appending osdTime.obj
Appending osdEvent.obj
Appending osdMutex.obj
Appending osdThread.obj
Appending osdStdio.obj
Appending epicsStdio.obj
Appending epicsTempFile.obj
Appending epicsReadline.obj
Appending osdEnv.obj
Appending osdSignal.obj
Appending osdPoolStatus.obj
Appending osdInterrupt.obj
Appending osdFindSymbol.obj
Appending osdAssert.obj
Appending epicsSocketConvertErrnoToString.obj
Appending systemCallIntMech.obj
Appending osiSock.obj
Appending osdSockAddrReuse.obj
Appending osdSock.obj
Appending osiClockTime.obj
Appending epicsGeneralTime.obj
Appending epicsMessageQueue.obj
Appending epicsTime.obj
Appending epicsEvent.obj
Appending epicsMutex.obj
Appending epicsThread.obj
Appending epicsUnitTest.obj
Appending ipAddrToAsciiAsynchronous.obj
Appending truncateFile.obj
Appending epicsString.obj
Appending epicsStdlib.obj
Appending epicsExit.obj
Appending epicsConvert.obj
Appending cantProceed.obj
Appending adjustment.obj
Appending aToIPAddr.obj
Appending macUtil.obj
Appending macEnv.obj
Appending macCore.obj
Appending logClient.obj
Appending iocLog.obj
Appending libComRegister.obj
Appending registry.obj
Appending iocsh.obj
Appending gpHashLib.obj
Appending freeListLib.obj
Appending fdManager.obj
Appending fdmgr.obj
Appending errSymTbl.obj
Appending errSymLib.obj
Appending errlog.obj
Appending envData.obj
Appending envSubr.obj
Appending ellLib.obj
Appending dbmf.obj
Appending epicsSingletonMutex.obj
Appending epicsOnce.obj
Appending resourceLib.obj
Appending cvtFast.obj
Appending calcPerform.obj
Appending postfix.obj
Appending epicsRingBytes.obj
Appending epicsRingPointer.obj
Appending bucketLib.obj
"Installing library ../../../lib/win32-x86/Com.lib"
mkdir ../../../lib/win32-x86
"Installing html ../../../html//freeList/freeList.html"
mkdir ../../../html
mkdir ../../../html/freeList
"Installing html ../../../html//gpHash/gpHash.html"
mkdir ../../../html/gpHash
make -C ./toolsComm install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm'
make -C ./antelope install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/antelope'
C:\perl\bin\perl.exe ../../../bin/win32-x86/makeMakefile.pl O.win32-x86
make -C O.win32-x86 -f ../Makefile TOP=../../../.. T_A=win32-x86 install
make[4]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/antelope/O.win32-x8
6'
/D_CRT_NONSTDC_NO_DEPRECATE /nologo /D__STDC__=0   /Ox /GL   /W1
-D_NO_PROTO   /MT -DEPICS_DLL_NO   -I. -I..\\O.Common -I. -I..
-I..\\..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\..\\include
..\\closure.c
closure.c
..\\error.c
error.c
..\\lalr.c
lalr.c
..\\lr0.c
lr0.c
..\\main.c
main.c
..\\mkpar.c
mkpar.c
..\\output.c
output.c
..\\reader.c
reader.c
..\\skeleton.c
skeleton.c
..\\symtab.c
symtab.c
..\\verbose.c
verbose.c
..\\warshall.c
warshall.c
           -out:antelope.exe        closure.obj error.obj lalr.obj
lr0.obj main.obj mkpar.obj output.obj reader.obj skeleton.obj symtab.obj
  verbose.obj warshall.obj     ../../../../lib/win32-x86/Com.lib
Generating code
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\verbose.c(3
38)
: warning C4716: 'print_gotos' : must return a value
17)
: warning C4716: 'print_reductions' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\verbose.c(2
79)
: warning C4716: 'print_shifts' : must return a value
54)
: warning C4716: 'print_actions' : must return a value
27)
: warning C4716: 'print_nulls' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\verbose.c(1
83)
: warning C4716: 'print_core' : must return a value
47)
: warning C4716: 'print_conflicts' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\verbose.c(9
9)
: warning C4716: 'print_state' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\verbose.c(8
5)
: warning C4716: 'log_conflicts' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\verbose.c(5
7)
: warning C4716: 'log_unused' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(12
18)
: warning C4716: 'free_reductions' : must return a value
04)
: warning C4716: 'free_shifts' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(11
91)
: warning C4716: 'free_itemsets' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(10
83)
: warning C4716: 'output_stype' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(75
0)
: warning C4716: 'output_check' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(72
0)
: warning C4716: 'output_table' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(68
8)
: warning C4716: 'output_base' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(18
3)
: warning C4716: 'output_yydefred' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(15
6)
: warning C4716: 'output_rule_data' : must return a value
9)
: warning C4716: 'output_prefix' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\mkpar.c(303
  : warning C4716: 'total_conflicts' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\mkpar.c(176
  : warning C4716: 'find_final_state' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lr0.c(286)
  : warning C4716: 'new_itemsets' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(647)
  : warning C4716: 'traverse' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(563)
  : warning C4716: 'compute_lookaheads' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(133)
  : warning C4716: 'set_maxrhs' : must return a value
73)
: warning C4716: 'output_debug' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(83
3)
: warning C4716: 'output_defines' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\mkpar.c(208
  : warning C4716: 'unused_rules' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lr0.c(485)
  : warning C4716: 'save_reductions' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lr0.c(435)
  : warning C4716: 'save_shifts' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lr0.c(251)
  : warning C4716: 'initialize_states' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(589)
  : warning C4716: 'digraph' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(529)
  : warning C4716: 'compute_FOLLOWS' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(464)
  : warning C4716: 'add_lookback_edge' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(438)
  : warning C4716: 'build_relations' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(345)
  : warning C4716: 'initialize_F' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(237)
  : warning C4716: 'set_goto_map' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(171)
  : warning C4716: 'initialize_LA' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(105)
  : warning C4716: 'set_reduction_table' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(94)
  : warning C4716: 'set_shift_table' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(83)
  : warning C4716: 'set_accessing_symbol' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\lalr.c(72)
  : warning C4716: 'set_state_table' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\reader.c(11
06)
: warning C4716: 'start_rule' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\reader.c(27
7)
: warning C4715: 'keyword' : not all control paths return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(48
8)
: warning C4716: 'pack_table' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(44
2)
: warning C4716: 'sort_actions' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(32
8)
: warning C4716: 'goto_actions' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(29
6)
: warning C4716: 'token_actions' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\output.c(21
1)
: warning C4716: 'output_actions' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\mkpar.c(342
  : warning C4716: 'defreds' : must return a value
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\antelope\mkpar.c(283
  : warning C4716: 'remove_conflicts' : must return a value
85)
: warning C4715: 'add_symbol' : not all control paths return a value
"Installing created file ../../../../bin/win32-x86/antelope.exe"
make[4]: Leaving directory
6'
make -C ./flex install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/flex'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/flex/O.win32-x86'
"Installing generic include file ../../../../include/flex.skel.static"
cl -c            -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\""
  -DUSG    /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE
/nologo  /D__STDC__=0   /Ox /GL   /W1       /MT -DEPICS_DLL_NO   -I.
-I..\\O.Common -I. -I.. -I..\\..\\..\\..\\include\\os\\WIN32
-I..\\..\\..\\..\\include         ..\\ccl.c
ccl.c
-I..\\..\\..\\..\\include         ..\\dfa.c
dfa.c
-I..\\..\\..\\..\\include         ..\\ecs.c
ecs.c
-I..\\..\\..\\..\\include         ..\\gen.c
gen.c
-I..\\..\\..\\..\\include         ..\\misc.c
misc.c
-I..\\..\\..\\..\\include         ..\\nfa.c
nfa.c
-I..\\..\\..\\..\\include         ..\\sym.c
sym.c
-I..\\..\\..\\..\\include         ..\\tblcmp.c
tblcmp.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f parse.c y.tab.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f parse.h y.tab.h
..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.c parse.c
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.h parse.h
-I..\\..\\..\\..\\include         parse.c
parse.c
           -out:e_flex.exe        ccl.obj dfa.obj ecs.obj gen.obj
misc.obj nfa.obj sym.obj tblcmp.obj parse.obj
../../../../lib/win32-x86/Com.lib  ws2_32.lib advapi32.lib user32.lib
Generating code
w:\windev\epics\r3.14.10\base-3.14.10\src\toolscomm\flex\misc.c(702) :
warning C4715: 'myesc' : not all control paths return a value
"Installing created file ../../../../bin/win32-x86/e_flex.exe"
make -C ./ca install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/ca' C:\perl\bin\perl.exe
../../bin/win32-x86/makeMakefile.pl O.win32-x86  ../../..
`W:/winDev/epics/R3.14.10/base-3.14.10/src/ca/O.win32-x86'
"Installing generic include file ../../../include/cadef.h"
"Installing generic include file ../../../include/caerr.h"
"Installing generic include file ../../../include/caeventmask.h"
"Installing generic include file ../../../include/caProto.h"
"Installing generic include file ../../../include/db_access.h"
"Installing generic include file ../../../include/addrList.h"
"Installing generic include file ../../../include/cacIO.h"
"Installing generic include file ../../../include/caDiagnostics.h" rc -l
0x409 -I. -I../O.Common -I. -I.. -I../../../include/os/WIN32
-I../../../include        -fo ca.res ../ca.rc
..\\cac.cpp
cac.cpp
..\\cacChannel.cpp
cacChannel.cpp
..\\cacChannelNotify.cpp
..\\cacContextNotify.cpp
..\\cacReadNotify.cpp
cacReadNotify.cpp
..\\cacWriteNotify.cpp
cacWriteNotify.cpp
..\\cacStateNotify.cpp
cacStateNotify.cpp
..\\access.cpp
access.cpp
..\\iocinf.cpp
iocinf.cpp
..\\convert.cpp
convert.cpp
..\\test_event.cpp
test_event.cpp
..\\repeater.cpp
repeater.cpp
..\\searchTimer.cpp
searchTimer.cpp
..\\disconnectGovernorTimer.cpp
..\\repeaterSubscribeTimer.cpp
..\\baseNMIU.cpp
baseNMIU.cpp
..\\nciu.cpp
nciu.cpp
..\\netiiu.cpp
netiiu.cpp
..\\udpiiu.cpp
udpiiu.cpp
..\\tcpiiu.cpp
tcpiiu.cpp
..\\noopiiu.cpp
noopiiu.cpp
..\\netReadNotifyIO.cpp
netReadNotifyIO.cpp
..\\netWriteNotifyIO.cpp
..\\netSubscription.cpp
netSubscription.cpp
..\\tcpSendWatchdog.cpp
tcpSendWatchdog.cpp
..\\tcpRecvWatchdog.cpp
tcpRecvWatchdog.cpp
..\\bhe.cpp
bhe.cpp
..\\ca_client_context.cpp
..\\oldChannelNotify.cpp
..\\oldSubscription.cpp
oldSubscription.cpp
..\\getCallback.cpp
getCallback.cpp
..\\getCopy.cpp
getCopy.cpp
..\\putCallback.cpp
putCallback.cpp
..\\syncgrp.cpp
syncgrp.cpp
..\\CASG.cpp
CASG.cpp
..\\syncGroupNotify.cpp
syncGroupNotify.cpp
..\\syncGroupReadNotify.cpp
..\\syncGroupWriteNotify.cpp
..\\localHostName.cpp
localHostName.cpp
..\\comQueRecv.cpp
comQueRecv.cpp
..\\comQueSend.cpp
comQueSend.cpp
..\\comBuf.cpp
comBuf.cpp
..\\hostNameCache.cpp
hostNameCache.cpp
..\\msgForMultiplyDefinedPV.cpp
lib /nologo /verbose /out:ca.lib        cac.obj cacChannel.obj
cacChannelNotify.obj cacContextNotify.obj cacReadNotify.obj
cacWriteNotify.obj cacStateNotify.obj access.obj iocinf.obj convert.obj
  test_event.obj repeater.obj searchTimer.obj
disconnectGovernorTimer.obj  repeaterSubscribeTimer.obj baseNMIU.obj
nciu.obj netiiu.obj udpiiu.obj  tcpiiu.obj noopiiu.obj
netReadNotifyIO.obj netWriteNotifyIO.obj
netSubscription.obj tcpSendWatchdog.obj tcpRecvWatchdog.obj bhe.obj
ca_client_context.obj oldChannelNotify.obj oldSubscription.obj
getCallback.obj getCopy.obj putCallback.obj syncgrp.obj CASG.obj
syncGroupNotify.obj syncGroupReadNotify.obj syncGroupWriteNotify.obj
localHostName.obj comQueRecv.obj comQueSend.obj comBuf.obj
hostNameCache.obj msgForMultiplyDefinedPV.obj
msgForMultiplyDefinedPV.obj : MSIL .netmodule or module compiled with
/GL found; restarting link with /LTCG; add /LTCG to the link command
line to improve linker performance
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:ca.lib" "cac.obj" "cacChannel.obj"
"cacChannelNotify.obj" "cacContextNotify.obj" "cacReadNotify.obj"
"cacWriteNotify.obj" "cacStateNotify.obj" "access.obj" "iocinf.obj"
"convert.obj" "test_event.obj" "repeater.obj" "searchTimer.obj"
"disconnectGovernorTimer.obj" "repeaterSubscribeTimer.obj"
"baseNMIU.obj" "nciu.obj" "netiiu.obj" "udpiiu.obj" "tcpiiu.obj"
"noopiiu.obj" "netReadNotifyIO.obj" "netWriteNotifyIO.obj"
"netSubscription.obj" "tcpSendWatchdog.obj" "tcpRecvWatchdog.obj"
"bhe.obj" "ca_client_context.obj" "oldChannelNotify.obj"
"oldSubscription.obj" "getCallback.obj" "getCopy.obj" "putCallback.obj"
  "syncgrp.obj" "CASG.obj" "syncGroupNotify.obj"
"syncGroupReadNotify.obj"  "syncGroupWriteNotify.obj"
"localHostName.obj" "comQueRecv.obj"
"comQueSend.obj" "comBuf.obj" "hostNameCache.obj"
"msgForMultiplyDefinedPV.obj"
   /LTCG
Appending msgForMultiplyDefinedPV.obj
Appending hostNameCache.obj
Appending comBuf.obj
Appending comQueSend.obj
Appending comQueRecv.obj
Appending localHostName.obj
Appending syncGroupWriteNotify.obj
Appending syncGroupReadNotify.obj
Appending syncGroupNotify.obj
Appending CASG.obj
Appending syncgrp.obj
Appending putCallback.obj
Appending getCopy.obj
Appending getCallback.obj
Appending oldSubscription.obj
Appending oldChannelNotify.obj
Appending ca_client_context.obj
Appending bhe.obj
Appending tcpRecvWatchdog.obj
Appending tcpSendWatchdog.obj
Appending netSubscription.obj
Appending netWriteNotifyIO.obj
Appending netReadNotifyIO.obj
Appending noopiiu.obj
Appending tcpiiu.obj
Appending udpiiu.obj
Appending netiiu.obj
Appending nciu.obj
Appending baseNMIU.obj
Appending repeaterSubscribeTimer.obj
Appending disconnectGovernorTimer.obj
Appending searchTimer.obj
Appending repeater.obj
Appending test_event.obj
Appending convert.obj
Appending iocinf.obj
Appending access.obj
Appending cacStateNotify.obj
Appending cacWriteNotify.obj
Appending cacReadNotify.obj
Appending cacContextNotify.obj
Appending cacChannelNotify.obj
Appending cacChannel.obj
Appending cac.obj
"Installing library ../../../lib/win32-x86/ca.lib"
..\\caRepeater.cpp
caRepeater.cpp
           -out:caRepeater.exe       caRepeater.obj
../../../lib/win32-x86/ca.lib  ../../../lib/win32-x86/Com.lib ws2_32.lib
  advapi32.lib user32.lib ws2_32.lib advapi32.lib user32.lib
Generating code
..\\catimeMain.c
catimeMain.c
..\\catime.c
catime.c
           -out:catime.exe       catimeMain.obj catime.obj
Generating code
..\\acctstMain.c
acctstMain.c
..\\acctst.c
acctst.c
           -out:acctst.exe       acctstMain.obj acctst.obj
Generating code
..\\caConnTestMain.cpp
caConnTestMain.cpp
..\\caConnTest.cpp
caConnTest.cpp
           -out:caConnTest.exe       caConnTestMain.obj caConnTest.obj
ws2_32.lib advapi32.lib user32.lib ws2_32.lib advapi32.lib user32.lib
Generating code
..\\casw.cpp
casw.cpp
           -out:casw.exe       casw.obj
Generating code
..\\caEventRateMain.cpp
caEventRateMain.cpp
..\\caEventRate.cpp
caEventRate.cpp
           -out:caEventRate.exe       caEventRateMain.obj
caEventRate.obj
Generating code
"Installing created file ../../../bin/win32-x86/caRepeater.exe"
"Installing created file ../../../bin/win32-x86/catime.exe"
"Installing created file ../../../bin/win32-x86/acctst.exe"
"Installing created file ../../../bin/win32-x86/caConnTest.exe"
"Installing created file ../../../bin/win32-x86/casw.exe"
"Installing created file ../../../bin/win32-x86/caEventRate.exe"
"Installing html ../../../html//CAref.html"
`W:/winDev/epics/R3.14.10/base-3.14.10/src/ca' make -C ./dbStatic
install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dbStatic'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dbStatic/O.win32-x86'
"Installing generic include file ../../../include/alarm.h"
"Installing generic include file ../../../include/alarmString.h"
"Installing generic include file ../../../include/dbBase.h"
"Installing generic include file ../../../include/dbFldTypes.h"
"Installing generic include file ../../../include/dbStaticLib.h"
"Installing generic include file ../../../include/dbStaticPvt.h"
"Installing generic include file ../../../include/link.h"
"Installing generic include file ../../../include/special.h"
"Installing generic include file ../../../include/guigroup.h"
"Installing generic include file ../../../include/devSup.h"
"Installing generic include file ../../../include/drvSup.h"
"Installing generic include file ../../../include/recSup.h"
"Installing generic include file ../../../include/dbStaticIocRegister.h"
..\\dbStaticNoRun.c
dbStaticNoRun.c
rc -l 0x409 -I. -I../O.Common -I. -I.. -I../../../include/os/WIN32
-I../../../include        -fo dbStaticHost.res ../dbStaticHost.rc
..\\dbStaticLib.c
dbStaticLib.c
..\dbStaticLib.c(2315) : warning C4244: '=' : conversion from 'short' to
  'unsigned char', possible loss of data
..\dbStaticLib.c(2388) : warning C4018: '>=' : signed/unsigned mismatch
..\dbStaticLib.c(3212) : warning C4244: '=' : conversion from 'long' to
  'short', possible loss of data
..\dbStaticLib.c(3219) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3229) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3236) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3243) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3250) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3257) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3267) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3274) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3281) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3288) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3296) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3303) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3310) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3317) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3327) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3334) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3345) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3352) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3359) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3366) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3381) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3388) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3395) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3409) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3416) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3423) : warning C4244: '=' : conversion from 'long' to
..\dbStaticLib.c(3430) : warning C4244: '=' : conversion from 'long' to
..\\..\\..\\bin\\win32-x86\\e_flex.exe
-S../../../include/flex.skel.static -8 -I ../dbLex.l
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  lex.yy.c dbLex.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f dbYacc.c y.tab.c
..\\..\\..\\bin\\win32-x86\\antelope.exe  ../dbYacc.y
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.c dbYacc.c
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include         dbYacc.c
dbYacc.c
..\\dbPvdLib.c
dbPvdLib.c
..\dbPvdLib.c(112) : warning C4018: '>=' : signed/unsigned mismatch
..\dbPvdLib.c(113) : warning C4018: '<' : signed/unsigned mismatch lib
/nologo /verbose /out:dbStaticHost.lib       dbStaticNoRun.obj
dbStaticLib.obj dbYacc.obj dbPvdLib.obj
dbPvdLib.obj : MSIL .netmodule or module compiled with /GL found;
restarting link with /LTCG; add /LTCG to the link command line to
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:dbStaticHost.lib" "dbStaticNoRun.obj"
"dbStaticLib.obj" "dbYacc.obj" "dbPvdLib.obj"
   /LTCG
Appending dbPvdLib.obj
Appending dbYacc.obj
Appending dbStaticLib.obj
Appending dbStaticNoRun.obj
..\\dbStaticRun.c
dbStaticRun.c
          ..\..\..\include\dbDefs.h(55) : see previous definition of
'max'
..\dbStaticRun.c(78) : warning C4244: '=' : conversion from 'double' to
  'epicsInt32', possible loss of data
..\dbStaticRun.c(176) : warning C4018: '>=' : signed/unsigned mismatch
..\dbStaticRun.c(193) : warning C4018: '>=' : signed/unsigned mismatch
..\dbStaticRun.c(544) : warning C4244: '=' : conversion from 'long' to
'char', possible loss of data
..\dbStaticRun.c(545) : warning C4244: '=' : conversion from 'long' to
..\dbStaticRun.c(561) : warning C4244: '=' : conversion from 'unsigned
long' to 'unsigned char', possible loss of data
..\dbStaticRun.c(563) : warning C4244: '=' : conversion from 'unsigned
long' to 'unsigned short', possible loss of data
..\dbStaticRun.c(577) : warning C4244: '=' : conversion from 'double' to
..\\dbStaticIocRegister.c
-I../../../include        -fo dbStaticIoc.res ../dbStaticIoc.rc
lib /nologo /verbose /out:dbStaticIoc.lib       dbStaticRun.obj
dbStaticIocRegister.obj dbStaticLib.obj dbYacc.obj dbPvdLib.obj
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:dbStaticIoc.lib" "dbStaticRun.obj"
"dbStaticIocRegister.obj" "dbStaticLib.obj" "dbYacc.obj" "dbPvdLib.obj"
   /LTCG
Appending dbStaticIocRegister.obj
Appending dbStaticRun.obj
"Installing library ../../../lib/win32-x86/dbStaticHost.lib"
"Installing library ../../../lib/win32-x86/dbStaticIoc.lib"
..\\dbReadTest.c
dbReadTest.c
           -out:dbReadTest.exe       dbReadTest.obj
../../../lib/win32-x86/dbStaticHost.lib  ../../../lib/win32-x86/Com.lib
Generating code
"Installing created file ../../../bin/win32-x86/dbReadTest.exe"
..\\dbExpand.c
dbExpand.c
           -out:dbExpand.exe       dbExpand.obj
Generating code
"Installing created file ../../../bin/win32-x86/dbExpand.exe"
..\\dbToMenuH.c
dbToMenuH.c
           -out:dbToMenuH.exe       dbToMenuH.obj
Generating code
"Installing created file ../../../bin/win32-x86/dbToMenuH.exe"
..\\dbToRecordtypeH.c
dbToRecordtypeH.c
           -out:dbToRecordtypeH.exe       dbToRecordtypeH.obj
Generating code
"Installing created file ../../../bin/win32-x86/dbToRecordtypeH.exe"
make -C ./registry install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/registry'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/registry/O.win32-x86'
"Installing generic include file ../../../include/registryRecordType.h"
../../../include/registryDeviceSupport.h" "Installing generic include
file ../../../include/registryDriverSupport.h" "Installing generic
include file ../../../include/registryFunction.h" "Installing generic
include file ../../../include/registryCommon.h" "Installing generic
include file ../../../include/registryIocRegister.h" rc -l 0x409 -I.
-I../O.Common -I. -I.. -I../../../include/os/WIN32  -I../../../include
       -fo registryIoc.res ../registryIoc.rc
..\\registryRecordType.c
..\\registryDeviceSupport.c
..\\registryDriverSupport.c
..\\registryFunction.c
registryFunction.c
..\\registryCommon.c
registryCommon.c
..\\registryIocRegister.c
lib /nologo /verbose /out:registryIoc.lib        registryRecordType.obj
  registryDeviceSupport.obj registryDriverSupport.obj
registryFunction.obj  registryCommon.obj registryIocRegister.obj
registryIocRegister.obj : MSIL .netmodule or module compiled with /GL
found; restarting link with /LTCG; add /LTCG to the link command line to
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:registryIoc.lib"
"registryRecordType.obj" "registryDeviceSupport.obj"
"registryDriverSupport.obj" "registryFunction.obj" "registryCommon.obj"
  "registryIocRegister.obj"
   /LTCG
Appending registryIocRegister.obj
Appending registryCommon.obj
Appending registryFunction.obj
Appending registryDriverSupport.obj
Appending registryDeviceSupport.obj
Appending registryRecordType.obj
"Installing library ../../../lib/win32-x86/registryIoc.lib"
"Installing script ../../../bin/win32-x86/registerRecordDeviceDriver.pl"
make -C ./bpt install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/bpt'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/bpt/O.win32-x86'
..\\makeBpt.c
makeBpt.c
..\makeBpt.c(318) : warning C4244: '=' : conversion from 'double' to
'int', possible loss of data
           -out:makeBpt.exe       makeBpt.obj
Generating code
"Installing created file ../../../bin/win32-x86/makeBpt.exe"
..\\..\\..\\bin\\win32-x86\\makeBpt.exe ../bptTypeJdegC.data
../O.Common/bptTypeJdegC.dbd
..\\..\\..\\bin\\win32-x86\\makeBpt.exe ../bptTypeJdegF.data
../O.Common/bptTypeJdegF.dbd
..\\..\\..\\bin\\win32-x86\\makeBpt.exe ../bptTypeKdegC.data
../O.Common/bptTypeKdegC.dbd
..\\..\\..\\bin\\win32-x86\\makeBpt.exe ../bptTypeKdegF.data
../O.Common/bptTypeKdegF.dbd
"Installing dbd file ../../../dbd/menuConvert.dbd"
mkdir ../../../dbd
"Installing created dbd file ../../../dbd/bptTypeJdegC.dbd"
"Installing created dbd file ../../../dbd/bptTypeJdegF.dbd"
"Installing created dbd file ../../../dbd/bptTypeKdegC.dbd"
"Installing created dbd file ../../../dbd/bptTypeKdegF.dbd"
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuConvert.dbd
../O.Common/menuConvert.h
"Installing generic include file ../../../include/cvtTable.h"
../../../include/menuConvert.h" make[3]: Leaving directory
make[2]: Leaving directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/bpt' make -C ./db install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/db' C:\perl\bin\perl.exe
`W:/winDev/epics/R3.14.10/base-3.14.10/src/db/O.win32-x86'
"Installing dbd file ../../../dbd/dbCommon.dbd"
"Installing dbd file ../../../dbd/menuGlobal.dbd"
"Installing dbd file ../../../dbd/menuAlarmSevr.dbd"
"Installing dbd file ../../../dbd/menuAlarmStat.dbd"
"Installing dbd file ../../../dbd/menuCompress.dbd"
"Installing dbd file ../../../dbd/menuFtype.dbd"
"Installing dbd file ../../../dbd/menuIvoa.dbd"
"Installing dbd file ../../../dbd/menuOmsl.dbd"
"Installing dbd file ../../../dbd/menuPriority.dbd"
"Installing dbd file ../../../dbd/menuScan.dbd"
"Installing dbd file ../../../dbd/menuYesNo.dbd"
"Installing dbd file ../../../dbd/menuSimm.dbd"
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f ../O.Common/dbCommon.h
..\\..\\..\\bin\\win32-x86\\dbToRecordtypeH.exe -I ..
../dbCommonRecord.dbd ../O.Common/dbCommon.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuAlarmSevr.dbd
../O.Common/menuAlarmSevr.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuAlarmStat.dbd
../O.Common/menuAlarmStat.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuCompress.dbd
../O.Common/menuCompress.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuFtype.dbd
../O.Common/menuFtype.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuIvoa.dbd
../O.Common/menuIvoa.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuOmsl.dbd
../O.Common/menuOmsl.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuPriority.dbd
../O.Common/menuPriority.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuScan.dbd
../O.Common/menuScan.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuYesNo.dbd
../O.Common/menuYesNo.h
..\\..\\..\\bin\\win32-x86\\dbToMenuH.exe ../menuSimm.dbd
../O.Common/menuSimm.h
"Installing generic include file ../../../include/callback.h"
"Installing generic include file ../../../include/dbAccess.h"
"Installing generic include file ../../../include/dbAccessDefs.h"
"Installing generic include file ../../../include/dbCa.h"
"Installing generic include file ../../../include/dbAddr.h"
"Installing generic include file ../../../include/dbBkpt.h"
"Installing generic include file ../../../include/dbConvert.h"
"Installing generic include file ../../../include/dbConvertFast.h"
"Installing generic include file ../../../include/dbEvent.h"
"Installing generic include file ../../../include/dbLock.h"
"Installing generic include file ../../../include/dbNotify.h"
"Installing generic include file ../../../include/dbScan.h"
"Installing generic include file ../../../include/dbTest.h"
"Installing generic include file ../../../include/dbCaTest.h"
"Installing generic include file ../../../include/db_test.h"
"Installing generic include file ../../../include/db_field_log.h"
"Installing generic include file ../../../include/initHooks.h"
"Installing generic include file ../../../include/recGbl.h"
"Installing generic include file ../../../include/dbIocRegister.h"
"Installing generic include file ../../../include/db_access_routines.h"
"Installing generic include file ../../../include/db_convert.h"
"Installing generated generic include file ../../../include/dbCommon.h"
../../../include/menuAlarmSevr.h"
../../../include/menuAlarmStat.h"
../../../include/menuCompress.h"
"Installing generated generic include file ../../../include/menuFtype.h"
"Installing generated generic include file ../../../include/menuIvoa.h"
"Installing generated generic include file ../../../include/menuOmsl.h"
../../../include/menuPriority.h"
"Installing generated generic include file ../../../include/menuScan.h"
"Installing generated generic include file ../../../include/menuYesNo.h"
"Installing generated generic include file ../../../include/menuSimm.h"
-I../../../include        -fo dbIoc.res ../dbIoc.rc
..\\dbLock.c
dbLock.c
..\\dbAccess.c
dbAccess.c
..\dbAccess.c(159) : warning C4018: '<' : signed/unsigned mismatch
..\dbAccess.c(162) : warning C4018: '<' : signed/unsigned mismatch
..\dbAccess.c(196) : warning C4244: '=' : conversion from 'epicsFloat64'
  to 'epicsInt32', possible loss of data
..\dbAccess.c(197) : warning C4244: '=' : conversion from 'epicsFloat64'
..\dbAccess.c(236) : warning C4244: '=' : conversion from 'epicsFloat64'
..\dbAccess.c(237) : warning C4244: '=' : conversion from 'epicsFloat64'
..\dbAccess.c(277) : warning C4244: '=' : conversion from 'epicsFloat64'
..\dbAccess.c(278) : warning C4244: '=' : conversion from 'epicsFloat64'
..\dbAccess.c(279) : warning C4244: '=' : conversion from 'epicsFloat64'
..\dbAccess.c(280) : warning C4244: '=' : conversion from 'epicsFloat64'
..\dbAccess.c(1447) : warning C4244: '=' : conversion from 'long' to
..\\dbBkpt.c
dbBkpt.c
..\\dbConvert.c
dbConvert.c
..\dbConvert.c(796) : warning C4244: '=' : conversion from 'short' to
..\dbConvert.c(801) : warning C4244: '=' : conversion from 'short' to
..\dbConvert.c(815) : warning C4244: '=' : conversion from 'short' to
..\dbConvert.c(820) : warning C4244: '=' : conversion from 'short' to
..\dbConvert.c(989) : warning C4244: '=' : conversion from 'unsigned
short' to 'char', possible loss of data
..\dbConvert.c(994) : warning C4244: '=' : conversion from 'unsigned
..\dbConvert.c(1008) : warning C4244: '=' : conversion from 'unsigned
short' to 'unsigned char', possible loss of data
..\dbConvert.c(1013) : warning C4244: '=' : conversion from 'unsigned
..\dbConvert.c(1296) : warning C4244: '=' : conversion from 'epicsInt32'
..\dbConvert.c(1301) : warning C4244: '=' : conversion from 'epicsInt32'
..\dbConvert.c(1490) : warning C4244: '=' : conversion from
'epicsUInt32' to 'float', possible loss of data
..\dbConvert.c(1495) : warning C4244: '=' : conversion from
..\dbConvert.c(1576) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1581) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1595) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1600) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1614) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1619) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1633) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1638) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1652) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1657) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1671) : warning C4244: '=' : conversion from 'float' to
'epicsUInt32', possible loss of data
..\dbConvert.c(1676) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1728) : warning C4244: '=' : conversion from 'float' to
'epicsEnum16', possible loss of data
..\dbConvert.c(1733) : warning C4244: '=' : conversion from 'float' to
..\dbConvert.c(1776) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1781) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1795) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1800) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1814) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1819) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1833) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1838) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1852) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1857) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1871) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1876) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1929) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1934) : warning C4244: '=' : conversion from 'double' to
..\dbConvert.c(1962) : warning C4244: '=' : conversion from
'epicsEnum16' to 'char', possible loss of data
..\dbConvert.c(1967) : warning C4244: '=' : conversion from
..\dbConvert.c(1981) : warning C4244: '=' : conversion from
'epicsEnum16' to 'unsigned char', possible loss of data
..\dbConvert.c(1986) : warning C4244: '=' : conversion from
..\dbConvert.c(2996) : warning C4244: '=' : conversion from 'const
.\dbConvert.c(3001) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3015) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3020) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3192) : warning C4244: '=' : conversion from 'const
unsigned short' to 'char', possible loss of data
..\dbConvert.c(3197) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3211) : warning C4244: '=' : conversion from 'const
unsigned short' to 'unsigned char', possible loss of data
..\dbConvert.c(3216) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3502) : warning C4244: '=' : conversion from 'const
epicsInt32' to 'float', possible loss of data
..\dbConvert.c(3507) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3698) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3703) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3785) : warning C4244: '=' : conversion from 'const
float' to 'char', possible loss of data
..\dbConvert.c(3790) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3804) : warning C4244: '=' : conversion from 'const
float' to 'unsigned char', possible loss of data
..\dbConvert.c(3809) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3823) : warning C4244: '=' : conversion from 'const
float' to 'short', possible loss of data
..\dbConvert.c(3828) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3842) : warning C4244: '=' : conversion from 'const
float' to 'unsigned short', possible loss of data
..\dbConvert.c(3847) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3861) : warning C4244: '=' : conversion from 'const
float' to 'epicsInt32', possible loss of data
..\dbConvert.c(3866) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3880) : warning C4244: '=' : conversion from 'const
float' to 'epicsUInt32', possible loss of data
..\dbConvert.c(3885) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3937) : warning C4244: '=' : conversion from 'const
float' to 'epicsEnum16', possible loss of data
..\dbConvert.c(3942) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(3986) : warning C4244: '=' : conversion from 'const
double' to 'char', possible loss of data
..\dbConvert.c(3991) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4005) : warning C4244: '=' : conversion from 'const
double' to 'unsigned char', possible loss of data
..\dbConvert.c(4010) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4024) : warning C4244: '=' : conversion from 'const
double' to 'short', possible loss of data
..\dbConvert.c(4029) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4043) : warning C4244: '=' : conversion from 'const
double' to 'unsigned short', possible loss of data
..\dbConvert.c(4048) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4062) : warning C4244: '=' : conversion from 'const
double' to 'epicsInt32', possible loss of data
..\dbConvert.c(4067) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4081) : warning C4244: '=' : conversion from 'const
double' to 'epicsUInt32', possible loss of data
..\dbConvert.c(4086) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4139) : warning C4244: '=' : conversion from 'const
double' to 'epicsEnum16', possible loss of data
..\dbConvert.c(4144) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4183) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4188) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4202) : warning C4244: '=' : conversion from 'const
..\dbConvert.c(4207) : warning C4244: '=' : conversion from 'const
..\\dbFastLinkConv.c
dbFastLinkConv.c
..\dbFastLinkConv.c(512) : warning C4244: '=' : conversion from
'epicsInt16' to 'epicsInt8', possible loss of data
..\dbFastLinkConv.c(519) : warning C4244: '=' : conversion from
'epicsInt16' to 'epicsUInt8', possible loss of data
..\dbFastLinkConv.c(582) : warning C4244: '=' : conversion from
'epicsUInt16' to 'epicsInt8', possible loss of data
..\dbFastLinkConv.c(589) : warning C4244: '=' : conversion from
'epicsUInt16' to 'epicsUInt8', possible loss of data
..\dbFastLinkConv.c(694) : warning C4244: '=' : conversion from
'epicsInt32' to 'epicsFloat32', possible loss of data
..\dbFastLinkConv.c(764) : warning C4244: '=' : conversion from
'epicsUInt32' to 'epicsFloat32', possible loss of data
..\dbFastLinkConv.c(794) : warning C4244: 'function' : conversion from
'long' to 'unsigned short', possible loss of data
..\dbFastLinkConv.c(803) : warning C4244: '=' : conversion from
'epicsFloat32' to 'epicsInt8', possible loss of data
..\dbFastLinkConv.c(810) : warning C4244: '=' : conversion from
'epicsFloat32' to 'epicsUInt8', possible loss of data
..\dbFastLinkConv.c(817) : warning C4244: '=' : conversion from
'epicsFloat32' to 'epicsInt16', possible loss of data
..\dbFastLinkConv.c(824) : warning C4244: '=' : conversion from
'epicsFloat32' to 'epicsUInt16', possible loss of data
..\dbFastLinkConv.c(831) : warning C4244: '=' : conversion from
'epicsFloat32' to 'epicsInt32', possible loss of data
..\dbFastLinkConv.c(838) : warning C4244: '=' : conversion from
'epicsFloat32' to 'epicsUInt32', possible loss of data
..\dbFastLinkConv.c(859) : warning C4244: '=' : conversion from
'epicsFloat32' to 'epicsEnum16', possible loss of data
..\dbFastLinkConv.c(875) : warning C4244: 'function' : conversion from
..\dbFastLinkConv.c(884) : warning C4244: '=' : conversion from
'epicsFloat64' to 'epicsInt8', possible loss of data
..\dbFastLinkConv.c(891) : warning C4244: '=' : conversion from
'epicsFloat64' to 'epicsUInt8', possible loss of data
..\dbFastLinkConv.c(898) : warning C4244: '=' : conversion from
'epicsFloat64' to 'epicsInt16', possible loss of data
..\dbFastLinkConv.c(905) : warning C4244: '=' : conversion from
'epicsFloat64' to 'epicsUInt16', possible loss of data
..\dbFastLinkConv.c(912) : warning C4244: '=' : conversion from
'epicsFloat64' to 'epicsInt32', possible loss of data
..\dbFastLinkConv.c(919) : warning C4244: '=' : conversion from
'epicsFloat64' to 'epicsUInt32', possible loss of data
..\dbFastLinkConv.c(940) : warning C4244: '=' : conversion from
'epicsFloat64' to 'epicsEnum16', possible loss of data
..\dbFastLinkConv.c(947) : warning C4244: '=' : conversion from
'epicsEnum16' to 'epicsInt8', possible loss of data
..\dbFastLinkConv.c(954) : warning C4244: '=' : conversion from
'epicsEnum16' to 'epicsUInt8', possible loss of data
..\\dbNotify.c
dbNotify.c
..\\dbScan.c
dbScan.c
..\\dbEvent.c
dbEvent.c
..\\dbTest.c
dbTest.c
..\dbTest.c(253) : warning C4018: '<' : signed/unsigned mismatch
..\dbTest.c(495) : warning C4244: '=' : conversion from 'long' to
..\dbTest.c(501) : warning C4244: '=' : conversion from 'unsigned long'
..\dbTest.c(527) : warning C4244: '=' : conversion from 'unsigned long'
..\dbTest.c(538) : warning C4018: '<' : signed/unsigned mismatch
..\dbTest.c(713) : warning C4018: '<' : signed/unsigned mismatch
..\\db_access.c
db_access.c
..\db_access.c(674) : warning C4244: '=' : conversion from 'long' to
'dbr_short_t', possible loss of data
..\db_access.c(774) : warning C4244: '=' : conversion from 'long' to
..\db_access.c(847) : warning C4244: '=' : conversion from 'long' to
..\db_access.c(988) : warning C4244: '=' : conversion from 'long' to
..\\db_test.c
db_test.c
..\db_test.c(59) : warning C4244: '=' : conversion from 'long' to
..\\recGbl.c
recGbl.c
..\recGbl.c(185) : warning C4244: '=' : conversion from 'short' to
..\recGbl.c(193) : warning C4244: '=' : conversion from 'unsigned short'
..\\callback.c
callback.c
..\\dbCa.c dbCa.c
..\dbCa.c(278) : warning C4113: 'long (__cdecl *)()' differs in
parameter lists from 'long (__cdecl *)(const void *,void *,dbAddr *)'
..\dbCa.c(295) : warning C4113: 'long (__cdecl *)()' differs in
..\dbCa.c(306) : warning C4018: '>' : signed/unsigned mismatch
..\dbCa.c(347) : warning C4113: 'long (__cdecl *)()' differs in
..\dbCa.c(363) : warning C4113: 'long (__cdecl *)()' differs in
parameter lists from 'long (__cdecl *)(const void *,void *,dbAddr *)' cl
..\\dbCaTest.c
dbCaTest.c
..\\initHooks.c
initHooks.c
..\\cvtBpt.c
cvtBpt.c
..\\dbContext.cpp
dbContext.cpp
..\\dbChannelIO.cpp
dbChannelIO.cpp
..\\dbSubscriptionIO.cpp
..\\dbPutNotifyBlocker.cpp
..\\dbContextReadNotifyCache.cpp
..\\templateInstances.cpp
..\\dbIocRegister.c
dbIocRegister.c
lib /nologo /verbose /out:dbIoc.lib        dbLock.obj dbAccess.obj
dbBkpt.obj dbConvert.obj dbFastLinkConv.obj dbNotify.obj dbScan.obj
dbEvent.obj dbTest.obj db_access.obj db_test.obj recGbl.obj callback.obj
  dbCa.obj dbCaTest.obj initHooks.obj cvtBpt.obj dbContext.obj
dbChannelIO.obj dbSubscriptionIO.obj dbPutNotifyBlocker.obj
dbContextReadNotifyCache.obj templateInstances.obj dbIocRegister.obj
dbIocRegister.obj : MSIL .netmodule or module compiled with /GL found;
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:dbIoc.lib" "dbLock.obj"
"dbAccess.obj"
"dbBkpt.obj" "dbConvert.obj" "dbFastLinkConv.obj" "dbNotify.obj"
"dbScan.obj" "dbEvent.obj" "dbTest.obj" "db_access.obj" "db_test.obj"
"recGbl.obj" "callback.obj" "dbCa.obj" "dbCaTest.obj" "initHooks.obj"
"cvtBpt.obj" "dbContext.obj" "dbChannelIO.obj" "dbSubscriptionIO.obj"
"dbPutNotifyBlocker.obj" "dbContextReadNotifyCache.obj"
"templateInstances.obj" "dbIocRegister.obj"
   /LTCG
Appending dbIocRegister.obj
Appending templateInstances.obj
Appending dbContextReadNotifyCache.obj
Appending dbPutNotifyBlocker.obj
Appending dbSubscriptionIO.obj
Appending dbChannelIO.obj
Appending dbContext.obj
Appending cvtBpt.obj
Appending initHooks.obj
Appending dbCaTest.obj
Appending dbCa.obj
Appending callback.obj
Appending recGbl.obj
Appending db_test.obj
Appending db_access.obj
Appending dbTest.obj
Appending dbEvent.obj
Appending dbScan.obj
Appending dbNotify.obj
Appending dbFastLinkConv.obj
Appending dbConvert.obj
Appending dbBkpt.obj
Appending dbAccess.obj
Appending dbLock.obj
"Installing library ../../../lib/win32-x86/dbIoc.lib"
`W:/winDev/epics/R3.14.10/base-3.14.10/src/db' make -C ./as install
make[2]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/as' C:\perl\bin\perl.exe
C:\perl\bin\perl.exe -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/as/O.win32-x86'
"Installing generic include file ../../../include/asLib.h"
"Installing generic include file ../../../include/asDbLib.h"
"Installing generic include file ../../../include/asCa.h"
"Installing generic include file ../../../include/asTrapWrite.h"
"Installing generic include file ../../../include/asIocRegister.h" rc -l
-I../../../include        -fo asHost.res ../asHost.rc
-S../../../include/flex.skel.static -8 -I ../asLib_lex.l
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  lex.yy.c asLib_lex.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f asLib.c y.tab.c
..\\..\\..\\bin\\win32-x86\\antelope.exe  ../asLib.y
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.c asLib.c
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include         asLib.c
asLib.c
..\\asTrapWrite.c
asTrapWrite.c
lib /nologo /verbose /out:asHost.lib        asLib.obj asTrapWrite.obj
asTrapWrite.obj : MSIL .netmodule or module compiled with /GL found;
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:asHost.lib" "asLib.obj"
"asTrapWrite.obj"
   /LTCG
Appending asTrapWrite.obj
Appending asLib.obj
..\\asDbLib.c
asDbLib.c
..\\asCa.c asCa.c
..\\asIocRegister.c
asIocRegister.c
-I../../../include        -fo asIoc.res ../asIoc.rc
lib /nologo /verbose /out:asIoc.lib       asDbLib.obj asCa.obj
asIocRegister.obj asLib.obj asTrapWrite.obj
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:asIoc.lib" "asDbLib.obj" "asCa.obj"
"asIocRegister.obj" "asLib.obj" "asTrapWrite.obj"
   /LTCG
Appending asLib.obj
Appending asIocRegister.obj
Appending asCa.obj
Appending asDbLib.obj
"Installing library ../../../lib/win32-x86/asHost.lib"
"Installing library ../../../lib/win32-x86/asIoc.lib"
..\\ascheck.c
ascheck.c
link -nologo  /LTCG /incremental:no /opt:ref /release /version:3.14
           -out:ascheck.exe       ascheck.obj
../../../lib/win32-x86/dbStaticHost.lib  ../../../lib/win32-x86/ca.lib
kernel32.lib winmm.lib
Generating code
Finished generating code
"Installing created file ../../../bin/win32-x86/ascheck.exe"
`W:/winDev/epics/R3.14.10/base-3.14.10/src/as' make -C ./util install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/util'
C:\perl\bin\perl.exe ../../bin/win32-x86/makeMakefile.pl O.win32-x86
`W:/winDev/epics/R3.14.10/base-3.14.10/src/util/O.win32-x86'
..\\ca_test_main.c
ca_test_main.c
..\\ca_test.c
ca_test.c
           -out:ca_test.exe       ca_test_main.obj ca_test.obj
Generating code
..\\iocLogServer.c
iocLogServer.c
           -out:iocLogServer.exe       iocLogServer.obj
Generating code
"Installing created file ../../../bin/win32-x86/ca_test.exe"
"Installing created file ../../../bin/win32-x86/iocLogServer.exe"
make -C ./dbtools install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dbtools'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dbtools/O.win32-x86'
"Installing generic include file ../../../include/dbLoadTemplate.h"
"Installing generic include file ../../../include/dbtoolsIocRegister.h"
-I../../../include        -fo dbtoolsIoc.res ../dbtoolsIoc.rc
-S../../../include/flex.skel.static -8 -I ../dbLoadTemplate_lex.l
dbLoadTemplate_lex.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f dbLoadTemplate.c
y.tab.c ..\\..\\..\\bin\\win32-x86\\antelope.exe  ../dbLoadTemplate.y
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.c dbLoadTemplate.c
cl -c                /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /nologo /D__STDC__=0   /Ox /GL   /W3 /w44355
dbLoadTemplate.c
dbLoadTemplate.c
../dbLoadTemplate_lex.l(223) : warning C4013: 'read' undefined; assuming
  extern returning int
..\\dbtoolsIocRegister.c
lib /nologo /verbose /out:dbtoolsIoc.lib        dbLoadTemplate.obj
dbtoolsIocRegister.obj
dbtoolsIocRegister.obj : MSIL .netmodule or module compiled with /GL
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:dbtoolsIoc.lib" "dbLoadTemplate.obj"
"dbtoolsIocRegister.obj"
   /LTCG
Appending dbtoolsIocRegister.obj
Appending dbLoadTemplate.obj
"Installing library ../../../lib/win32-x86/dbtoolsIoc.lib"
"Installing html ../../../html//dbLoadTemplate.html"
make -C ./catools install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/catools'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/catools/O.win32-x86'
..\\tool_lib.c
tool_lib.c
..\tool_lib.c(472) : warning C4018: '<' : signed/unsigned mismatch
..\tool_lib.c(475) : warning C4018: '<' : signed/unsigned mismatch
..\tool_lib.c(478) : warning C4018: '<' : signed/unsigned mismatch
..\tool_lib.c(481) : warning C4018: '<' : signed/unsigned mismatch
..\tool_lib.c(484) : warning C4018: '<' : signed/unsigned mismatch
..\tool_lib.c(487) : warning C4018: '<' : signed/unsigned mismatch
..\tool_lib.c(490) : warning C4018: '<' : signed/unsigned mismatch lib
/nologo /verbose /out:catools.lib       tool_lib.obj
tool_lib.obj : MSIL .netmodule or module compiled with /GL found;
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:catools.lib" "tool_lib.obj"
   /LTCG
Appending tool_lib.obj
..\\caget.c caget.c
           -out:caget.exe       caget.obj      ./catools.lib
ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Generating code
..\\camonitor.c
camonitor.c
           -out:camonitor.exe       camonitor.obj      ./catools.lib
Generating code
..\\cainfo.c
cainfo.c
           -out:cainfo.exe       cainfo.obj      ./catools.lib
Generating code
..\\caput.c caput.c
           -out:caput.exe       caput.obj      ./catools.lib
Generating code
"Installing created file ../../../bin/win32-x86/caget.exe"
"Installing created file ../../../bin/win32-x86/camonitor.exe"
"Installing created file ../../../bin/win32-x86/cainfo.exe"
"Installing created file ../../../bin/win32-x86/caput.exe"
make -C ./rsrv install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/rsrv'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/rsrv/O.win32-x86'
"Installing generic include file ../../../include/rsrv.h"
"Installing generic include file ../../../include/rsrvIocRegister.h" rc
-I../../../include     -I../../ca   -fo rsrvIoc.res ../rsrvIoc.rc
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include     -I..\\..\\ca
     ..\\caserverio.c
caserverio.c
     ..\\caservertask.c
caservertask.c
     ..\\camsgtask.c
camsgtask.c
     ..\\camessage.c
camessage.c
     ..\\cast_server.c
cast_server.c
     ..\\online_notify.c
online_notify.c
     ..\\rsrvIocRegister.c
rsrvIocRegister.c
lib /nologo /verbose /out:rsrvIoc.lib        caserverio.obj
caservertask.obj camsgtask.obj camessage.obj cast_server.obj
online_notify.obj rsrvIocRegister.obj
rsrvIocRegister.obj : MSIL .netmodule or module compiled with /GL found;
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:rsrvIoc.lib" "caserverio.obj"
"caservertask.obj" "camsgtask.obj" "camessage.obj" "cast_server.obj"
"online_notify.obj" "rsrvIocRegister.obj"
   /LTCG
Appending rsrvIocRegister.obj
Appending online_notify.obj
Appending cast_server.obj
Appending camessage.obj
Appending camsgtask.obj
Appending caservertask.obj
Appending caserverio.obj
"Installing library ../../../lib/win32-x86/rsrvIoc.lib"
make -C ./rec install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/rec'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/rec/O.win32-x86'
"Installing dbd file ../../../dbd/aaiRecord.dbd"
"Installing dbd file ../../../dbd/aaoRecord.dbd"
"Installing dbd file ../../../dbd/aiRecord.dbd"
"Installing dbd file ../../../dbd/aoRecord.dbd"
"Installing dbd file ../../../dbd/aSubRecord.dbd"
"Installing dbd file ../../../dbd/biRecord.dbd"
"Installing dbd file ../../../dbd/boRecord.dbd"
"Installing dbd file ../../../dbd/calcRecord.dbd"
"Installing dbd file ../../../dbd/calcoutRecord.dbd"
"Installing dbd file ../../../dbd/compressRecord.dbd"
"Installing dbd file ../../../dbd/dfanoutRecord.dbd"
"Installing dbd file ../../../dbd/eventRecord.dbd"
"Installing dbd file ../../../dbd/fanoutRecord.dbd"
"Installing dbd file ../../../dbd/histogramRecord.dbd"
"Installing dbd file ../../../dbd/longinRecord.dbd"
"Installing dbd file ../../../dbd/longoutRecord.dbd"
"Installing dbd file ../../../dbd/mbbiRecord.dbd"
"Installing dbd file ../../../dbd/mbbiDirectRecord.dbd"
"Installing dbd file ../../../dbd/mbboRecord.dbd"
"Installing dbd file ../../../dbd/mbboDirectRecord.dbd"
"Installing dbd file ../../../dbd/permissiveRecord.dbd"
"Installing dbd file ../../../dbd/selRecord.dbd"
"Installing dbd file ../../../dbd/seqRecord.dbd"
"Installing dbd file ../../../dbd/stateRecord.dbd"
"Installing dbd file ../../../dbd/stringinRecord.dbd"
"Installing dbd file ../../../dbd/stringoutRecord.dbd"
"Installing dbd file ../../../dbd/subRecord.dbd"
"Installing dbd file ../../../dbd/subArrayRecord.dbd"
"Installing dbd file ../../../dbd/waveformRecord.dbd"
..\\..\\..\\bin\\win32-x86\\dbToRecordtypeH.exe  -I . -I .. -I
../../../dbd   ../aaiRecord.dbd ../O.Common/aaiRecord.h
../../../dbd   ../aaoRecord.dbd ../O.Common/aaoRecord.h
../../../dbd   ../aiRecord.dbd ../O.Common/aiRecord.h
../../../dbd   ../aoRecord.dbd ../O.Common/aoRecord.h
../../../dbd   ../aSubRecord.dbd ../O.Common/aSubRecord.h
../../../dbd   ../biRecord.dbd ../O.Common/biRecord.h
../../../dbd   ../boRecord.dbd ../O.Common/boRecord.h
../../../dbd   ../calcRecord.dbd ../O.Common/calcRecord.h
../../../dbd   ../calcoutRecord.dbd ../O.Common/calcoutRecord.h
../../../dbd   ../compressRecord.dbd ../O.Common/compressRecord.h
../../../dbd   ../dfanoutRecord.dbd ../O.Common/dfanoutRecord.h
../../../dbd   ../eventRecord.dbd ../O.Common/eventRecord.h
../../../dbd   ../fanoutRecord.dbd ../O.Common/fanoutRecord.h
../../../dbd   ../histogramRecord.dbd ../O.Common/histogramRecord.h
../../../dbd   ../longinRecord.dbd ../O.Common/longinRecord.h
../../../dbd   ../longoutRecord.dbd ../O.Common/longoutRecord.h
../../../dbd   ../mbbiRecord.dbd ../O.Common/mbbiRecord.h
../../../dbd   ../mbbiDirectRecord.dbd ../O.Common/mbbiDirectRecord.h
../../../dbd   ../mbboRecord.dbd ../O.Common/mbboRecord.h
../../../dbd   ../mbboDirectRecord.dbd ../O.Common/mbboDirectRecord.h
../../../dbd   ../permissiveRecord.dbd ../O.Common/permissiveRecord.h
../../../dbd   ../selRecord.dbd ../O.Common/selRecord.h
../../../dbd   ../seqRecord.dbd ../O.Common/seqRecord.h
../../../dbd   ../stateRecord.dbd ../O.Common/stateRecord.h
../../../dbd   ../stringinRecord.dbd ../O.Common/stringinRecord.h
../../../dbd   ../stringoutRecord.dbd ../O.Common/stringoutRecord.h
../../../dbd   ../subRecord.dbd ../O.Common/subRecord.h
../../../dbd   ../subArrayRecord.dbd ../O.Common/subArrayRecord.h
../../../dbd   ../waveformRecord.dbd ../O.Common/waveformRecord.h
"Installing generated generic include file ../../../include/aaiRecord.h"
"Installing generated generic include file ../../../include/aaoRecord.h"
"Installing generated generic include file ../../../include/aiRecord.h"
"Installing generated generic include file ../../../include/aoRecord.h"
../../../include/aSubRecord.h" "Installing generated generic include
file ../../../include/biRecord.h" "Installing generated generic include
file ../../../include/boRecord.h" "Installing generated generic include
file ../../../include/calcRecord.h" "Installing generated generic
include file
../../../include/calcoutRecord.h"
../../../include/compressRecord.h"
../../../include/dfanoutRecord.h"
../../../include/eventRecord.h" "Installing generated generic include
file
../../../include/fanoutRecord.h"
../../../include/histogramRecord.h"
../../../include/longinRecord.h"
../../../include/longoutRecord.h"
../../../include/mbbiRecord.h" "Installing generated generic include
file
../../../include/mbbiDirectRecord.h"
../../../include/mbboRecord.h" "Installing generated generic include
file
../../../include/mbboDirectRecord.h"
../../../include/permissiveRecord.h"
"Installing generated generic include file ../../../include/selRecord.h"
"Installing generated generic include file ../../../include/seqRecord.h"
../../../include/stateRecord.h" "Installing generated generic include
file
../../../include/stringinRecord.h"
../../../include/stringoutRecord.h"
"Installing generated generic include file ../../../include/subRecord.h"
../../../include/subArrayRecord.h"
../../../include/waveformRecord.h"
-I../../../include        -fo recIoc.res ../recIoc.rc
..\\aaiRecord.c
aaiRecord.c
..\aaiRecord.c(171) : warning C4244: '=' : conversion from 'long' to
..\\aaoRecord.c
aaoRecord.c
..\aaoRecord.c(168) : warning C4244: '=' : conversion from 'long' to
..\\aiRecord.c
aiRecord.c
..\\aoRecord.c
aoRecord.c
..\aoRecord.c(407) : warning C4244: '=' : conversion from 'short' to
..\aoRecord.c(460) : warning C4244: '=' : conversion from 'double' to
..\aoRecord.c(461) : warning C4244: '=' : conversion from 'double' to
..\\aSubRecord.c
aSubRecord.c
..\aSubRecord.c(432) : warning C4244: '=' : conversion from 'long' to
..\\biRecord.c
biRecord.c
..\\boRecord.c
boRecord.c
..\\calcRecord.c
calcRecord.c
..\\calcoutRecord.c
calcoutRecord.c
..\\compressRecord.c
compressRecord.c
..\compressRecord.c(274) : warning C4018: '>=' : signed/unsigned
mismatch ..\compressRecord.c(279) : warning C4018: '>=' :
signed/unsigned mismatch cl -c                /D_CRT_SECURE_NO_DEPRECATE
..\\dfanoutRecord.c
dfanoutRecord.c
..\\eventRecord.c
eventRecord.c
..\\fanoutRecord.c
fanoutRecord.c
..\\histogramRecord.c
histogramRecord.c
..\histogramRecord.c(333) : warning C4244: '=' : conversion from
'double' to 'epicsUInt32', possible loss of data
..\histogramRecord.c(345) : warning C4244: '=' : conversion from
..\\longinRecord.c
longinRecord.c
..\\longoutRecord.c
longoutRecord.c
..\\mbbiRecord.c
mbbiRecord.c
..\\mbbiDirectRecord.c
mbbiDirectRecord.c
..\\mbboRecord.c
mbboRecord.c
..\\mbboDirectRecord.c
mbboDirectRecord.c
..\\permissiveRecord.c
permissiveRecord.c
..\\selRecord.c
selRecord.c
..\\seqRecord.c
seqRecord.c
..\\stateRecord.c
stateRecord.c
..\\stringinRecord.c
stringinRecord.c
..\\stringoutRecord.c
stringoutRecord.c
..\\subRecord.c
subRecord.c
..\\subArrayRecord.c
subArrayRecord.c
..\subArrayRecord.c(171) : warning C4244: '=' : conversion from 'long'
..\subArrayRecord.c(194) : warning C4018: '>' : signed/unsigned mismatch
..\\waveformRecord.c
waveformRecord.c
..\waveformRecord.c(165) : warning C4244: '=' : conversion from 'long'
lib /nologo /verbose /out:recIoc.lib        aaiRecord.obj aaoRecord.obj
  aiRecord.obj aoRecord.obj aSubRecord.obj biRecord.obj boRecord.obj
calcRecord.obj calcoutRecord.obj compressRecord.obj dfanoutRecord.obj
eventRecord.obj fanoutRecord.obj histogramRecord.obj longinRecord.obj
longoutRecord.obj mbbiRecord.obj mbbiDirectRecord.obj mbboRecord.obj
mbboDirectRecord.obj permissiveRecord.obj selRecord.obj seqRecord.obj
stateRecord.obj stringinRecord.obj stringoutRecord.obj subRecord.obj
subArrayRecord.obj waveformRecord.obj
waveformRecord.obj : MSIL .netmodule or module compiled with /GL found;
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:recIoc.lib" "aaiRecord.obj"
"aaoRecord.obj" "aiRecord.obj" "aoRecord.obj" "aSubRecord.obj"
"biRecord.obj" "boRecord.obj" "calcRecord.obj" "calcoutRecord.obj"
"compressRecord.obj" "dfanoutRecord.obj" "eventRecord.obj"
"fanoutRecord.obj" "histogramRecord.obj" "longinRecord.obj"
"longoutRecord.obj" "mbbiRecord.obj" "mbbiDirectRecord.obj"
"mbboRecord.obj" "mbboDirectRecord.obj" "permissiveRecord.obj"
"selRecord.obj" "seqRecord.obj" "stateRecord.obj" "stringinRecord.obj"
"stringoutRecord.obj" "subRecord.obj" "subArrayRecord.obj"
"waveformRecord.obj"
   /LTCG
Appending waveformRecord.obj
Appending subArrayRecord.obj
Appending subRecord.obj
Appending stringoutRecord.obj
Appending stringinRecord.obj
Appending stateRecord.obj
Appending seqRecord.obj
Appending selRecord.obj
Appending permissiveRecord.obj
Appending mbboDirectRecord.obj
Appending mbboRecord.obj
Appending mbbiDirectRecord.obj
Appending mbbiRecord.obj
Appending longoutRecord.obj
Appending longinRecord.obj
Appending histogramRecord.obj
Appending fanoutRecord.obj
Appending eventRecord.obj
Appending dfanoutRecord.obj
Appending compressRecord.obj
Appending calcoutRecord.obj
Appending calcRecord.obj
Appending boRecord.obj
Appending biRecord.obj
Appending aSubRecord.obj
Appending aoRecord.obj
Appending aiRecord.obj
Appending aaoRecord.obj
Appending aaiRecord.obj
"Installing library ../../../lib/win32-x86/recIoc.lib"
`W:/winDev/epics/R3.14.10/base-3.14.10/src/rec' make -C ./misc install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/misc'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/misc/O.win32-x86'
"Installing dbd file ../../../dbd/base.dbd"
"Installing dbd file ../../../dbd/system.dbd"
"Installing generic include file ../../../include/epicsRelease.h"
"Installing generic include file ../../../include/iocInit.h"
"Installing generic include file ../../../include/miscIocRegister.h"
"Installing generic include file ../../../include/iocshRegisterCommon.h"
-I../../../include        -fo miscIoc.res ../miscIoc.rc
..\\epicsRelease.c
epicsRelease.c
..\\iocInit.c
iocInit.c
..\\asSubRecordFunctions.c
..\\miscIocRegister.c
miscIocRegister.c
..\\iocshRegisterCommon.c
lib /nologo /verbose /out:miscIoc.lib        epicsRelease.obj
iocInit.obj asSubRecordFunctions.obj miscIocRegister.obj
iocshRegisterCommon.obj
iocshRegisterCommon.obj : MSIL .netmodule or module compiled with /GL
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:miscIoc.lib" "epicsRelease.obj"
"iocInit.obj" "asSubRecordFunctions.obj" "miscIocRegister.obj"
"iocshRegisterCommon.obj"
   /LTCG
Appending iocshRegisterCommon.obj
Appending miscIocRegister.obj
Appending asSubRecordFunctions.obj
Appending iocInit.obj
Appending epicsRelease.obj
"Installing library ../../../lib/win32-x86/miscIoc.lib"
make -C ./dev install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dev'
make -C ./softDev install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dev/softDev'
C:\perl\bin\perl.exe ../../../bin/win32-x86/makeMakefile.pl O.win32-x86
make -C O.win32-x86 -f ../Makefile TOP=../../../.. T_A=win32-x86 install
make[4]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dev/softDev/O.win32-x86'
"Installing dbd file ../../../../dbd/devSoft.dbd"
rc -l 0x409 -I. -I../O.Common -I. -I.. -I../../../../include/os/WIN32
-I../../../../include        -fo softDevIoc.res ../softDevIoc.rc
        /MT -DEPICS_DLL_NO   -I. -I..\\O.Common -I. -I..
-I..\\..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\..\\include
..\\devAiSoft.c
devAiSoft.c
..\\devAiSoftRaw.c
devAiSoftRaw.c
..\\devAoSoft.c
devAoSoft.c
..\\devAoSoftRaw.c
devAoSoftRaw.c
..\\devBiSoft.c
devBiSoft.c
..\\devBiSoftRaw.c
devBiSoftRaw.c
..\\devBoSoft.c
devBoSoft.c
..\\devBoSoftRaw.c
devBoSoftRaw.c
..\\devCalcoutSoft.c
devCalcoutSoft.c
..\\devEventSoft.c
devEventSoft.c
..\\devHistogramSoft.c
devHistogramSoft.c
..\\devLiSoft.c
devLiSoft.c
..\\devLoSoft.c
devLoSoft.c
..\\devMbbiDirectSoft.c
devMbbiDirectSoft.c
..\\devMbbiDirectSoftRaw.c
..\\devMbbiSoft.c
devMbbiSoft.c
..\\devMbbiSoftRaw.c
devMbbiSoftRaw.c
..\\devMbboDirectSoft.c
devMbboDirectSoft.c
..\\devMbboDirectSoftRaw.c
..\\devMbboSoft.c
devMbboSoft.c
..\\devMbboSoftRaw.c
devMbboSoftRaw.c
..\\devSASoft.c
devSASoft.c
..\devSASoft.c(73) : warning C4018: '>' : signed/unsigned mismatch
..\devSASoft.c(79) : warning C4018: '>' : signed/unsigned mismatch cl -c
..\\devSiSoft.c
devSiSoft.c
..\\devSoSoft.c
devSoSoft.c
..\\devWfSoft.c
devWfSoft.c
..\\devGeneralTime.c
devGeneralTime.c
..\\devAoSoftCallback.c
devAoSoftCallback.c
..\\devBoSoftCallback.c
devBoSoftCallback.c
..\\devCalcoutSoftCallback.c
..\\devLoSoftCallback.c
devLoSoftCallback.c
..\\devMbboSoftCallback.c
..\\devMbboDirectSoftCallback.c
..\\devSoSoftCallback.c
devSoSoftCallback.c
..\\devTimestamp.c
devTimestamp.c
..\\devSoStdio.c
devSoStdio.c
lib /nologo /verbose /out:softDevIoc.lib        devAiSoft.obj
devAiSoftRaw.obj devAoSoft.obj devAoSoftRaw.obj devBiSoft.obj
devBiSoftRaw.obj devBoSoft.obj devBoSoftRaw.obj devCalcoutSoft.obj
devEventSoft.obj devHistogramSoft.obj devLiSoft.obj devLoSoft.obj
devMbbiDirectSoft.obj devMbbiDirectSoftRaw.obj devMbbiSoft.obj
devMbbiSoftRaw.obj devMbboDirectSoft.obj devMbboDirectSoftRaw.obj
devMbboSoft.obj devMbboSoftRaw.obj devSASoft.obj devSiSoft.obj
devSoSoft.obj devWfSoft.obj devGeneralTime.obj devAoSoftCallback.obj
devBoSoftCallback.obj devCalcoutSoftCallback.obj devLoSoftCallback.obj
devMbboSoftCallback.obj devMbboDirectSoftCallback.obj
devSoSoftCallback.obj devTimestamp.obj devSoStdio.obj
devSoStdio.obj : MSIL .netmodule or module compiled with /GL found;
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:softDevIoc.lib" "devAiSoft.obj"
"devAiSoftRaw.obj" "devAoSoft.obj" "devAoSoftRaw.obj" "devBiSoft.obj"
"devBiSoftRaw.obj" "devBoSoft.obj" "devBoSoftRaw.obj"
"devCalcoutSoft.obj" "devEventSoft.obj" "devHistogramSoft.obj"
"devLiSoft.obj" "devLoSoft.obj" "devMbbiDirectSoft.obj"
"devMbbiDirectSoftRaw.obj" "devMbbiSoft.obj" "devMbbiSoftRaw.obj"
"devMbboDirectSoft.obj" "devMbboDirectSoftRaw.obj" "devMbboSoft.obj"
"devMbboSoftRaw.obj" "devSASoft.obj" "devSiSoft.obj" "devSoSoft.obj"
"devWfSoft.obj" "devGeneralTime.obj" "devAoSoftCallback.obj"
"devBoSoftCallback.obj" "devCalcoutSoftCallback.obj"
"devLoSoftCallback.obj" "devMbboSoftCallback.obj"
"devMbboDirectSoftCallback.obj" "devSoSoftCallback.obj"
"devTimestamp.obj" "devSoStdio.obj"
   /LTCG
Appending devSoStdio.obj
Appending devTimestamp.obj
Appending devSoSoftCallback.obj
Appending devMbboDirectSoftCallback.obj
Appending devMbboSoftCallback.obj
Appending devLoSoftCallback.obj
Appending devCalcoutSoftCallback.obj
Appending devBoSoftCallback.obj
Appending devAoSoftCallback.obj
Appending devGeneralTime.obj
Appending devWfSoft.obj
Appending devSoSoft.obj
Appending devSiSoft.obj
Appending devSASoft.obj
Appending devMbboSoftRaw.obj
Appending devMbboSoft.obj
Appending devMbboDirectSoftRaw.obj
Appending devMbboDirectSoft.obj
Appending devMbbiSoftRaw.obj
Appending devMbbiSoft.obj
Appending devMbbiDirectSoftRaw.obj
Appending devMbbiDirectSoft.obj
Appending devLoSoft.obj
Appending devLiSoft.obj
Appending devHistogramSoft.obj
Appending devEventSoft.obj
Appending devCalcoutSoft.obj
Appending devBoSoftRaw.obj
Appending devBoSoft.obj
Appending devBiSoftRaw.obj
Appending devBiSoft.obj
Appending devAoSoftRaw.obj
Appending devAoSoft.obj
Appending devAiSoftRaw.obj
Appending devAiSoft.obj
"Installing library ../../../../lib/win32-x86/softDevIoc.lib"
make -C ./testDev install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dev/testDev'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dev/testDev/O.win32-x86'
"Installing dbd file ../../../../dbd/devTestAsyn.dbd"
-I../../../../include        -fo testDevIoc.res ../testDevIoc.rc
..\\devAiTestAsyn.c
devAiTestAsyn.c
..\\devAoTestAsyn.c
devAoTestAsyn.c
..\\devBiTestAsyn.c
devBiTestAsyn.c
..\\devBoTestAsyn.c
devBoTestAsyn.c
..\\devEventTestIoEvent.c
..\\devHistogramTestAsyn.c
..\\devLoTestAsyn.c
devLoTestAsyn.c
..\\devMbbiTestAsyn.c
devMbbiTestAsyn.c
..\\devMbboTestAsyn.c
devMbboTestAsyn.c
..\\devMbboDirectTestAsyn.c
..\\devSiTestAsyn.c
devSiTestAsyn.c
..\\devSoTestAsyn.c
devSoTestAsyn.c
..\\devWfTestAsyn.c
devWfTestAsyn.c
lib /nologo /verbose /out:testDevIoc.lib        devAiTestAsyn.obj
devAoTestAsyn.obj devBiTestAsyn.obj devBoTestAsyn.obj
devEventTestIoEvent.obj devHistogramTestAsyn.obj devLoTestAsyn.obj
devMbbiTestAsyn.obj devMbboTestAsyn.obj devMbboDirectTestAsyn.obj
devSiTestAsyn.obj devSoTestAsyn.obj devWfTestAsyn.obj
devWfTestAsyn.obj : MSIL .netmodule or module compiled with /GL found;
Invoking LINK.EXE:
   /LIB "/nologo" "/verbose" "/out:testDevIoc.lib" "devAiTestAsyn.obj"
"devAoTestAsyn.obj" "devBiTestAsyn.obj" "devBoTestAsyn.obj"
"devEventTestIoEvent.obj" "devHistogramTestAsyn.obj" "devLoTestAsyn.obj"
  "devMbbiTestAsyn.obj" "devMbboTestAsyn.obj"
"devMbboDirectTestAsyn.obj"  "devSiTestAsyn.obj" "devSoTestAsyn.obj"
"devWfTestAsyn.obj"
   /LTCG
Appending devWfTestAsyn.obj
Appending devSoTestAsyn.obj
Appending devSiTestAsyn.obj
Appending devMbboDirectTestAsyn.obj
Appending devMbboTestAsyn.obj
Appending devMbbiTestAsyn.obj
Appending devLoTestAsyn.obj
Appending devHistogramTestAsyn.obj
Appending devEventTestIoEvent.obj
Appending devBoTestAsyn.obj
Appending devBiTestAsyn.obj
Appending devAoTestAsyn.obj
Appending devAiTestAsyn.obj
"Installing library ../../../../lib/win32-x86/testDevIoc.lib"
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dev' make -C ./vxWorks
install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/vxWorks'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/vxWorks/O.win32-x86'
make[3]: Nothing to be done for `install'.
make -C ./RTEMS install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/RTEMS'
make -C ./base install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/RTEMS/base'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/RTEMS/base/O.win32-x86'
../../../../include/epicsRtemsInitHooks.h"
make[4]: Leaving directory
make -C libCom/test install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/libCom/test'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/libCom/test/O.win32-x86' cl
-c
..\\epicsUnitTestTest.c
epicsUnitTestTest.c
           -out:epicsUnitTestTest.exe       epicsUnitTestTest.obj
Generating code
cl /nologo /EHsc /GR -c                /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /D__STDC__=0   /Ox /GL   /W3 /w44355
/Tp ..\\epicsCalcTest.cpp
epicsCalcTest.cpp
..\epicsCalcTest.cpp(58) : warning C4800: 'int' : forcing value to bool
  'true' or 'false' (performance warning)
..\epicsCalcTest.cpp(445) : warning C4806: '!=' : unsafe operation: no
value of type 'bool' promoted to type 'int' can equal the given constant
..\epicsCalcTest.cpp(465) : warning C4806: '!=' : unsafe operation: no
..\epicsCalcTest.cpp(558) : warning C4804: '<' : unsafe use of type
'bool' in operation
..\epicsCalcTest.cpp(581) : warning C4804: '<=' : unsafe use of type
'bool' in operation
..\epicsCalcTest.cpp(626) : warning C4804: '>' : unsafe use of type
'bool' in operation
..\epicsCalcTest.cpp(646) : warning C4804: '>=' : unsafe use of type
'bool' in operation
..\epicsCalcTest.cpp(754) : warning C4554: '|' : check operator
precedence for possible error; use parentheses to clarify precedence
..\epicsCalcTest.cpp(755) : warning C4554: '|' : check operator
..\epicsCalcTest.cpp(756) : warning C4554: '^' : check operator
..\epicsCalcTest.cpp(764) : warning C4554: '&' : check operator
..\epicsCalcTest.cpp(765) : warning C4554: '&' : check operator
..\epicsCalcTest.cpp(766) : warning C4804: '<<' : unsafe use of type
'bool' in operation
..\epicsCalcTest.cpp(767) : warning C4804: '>>' : unsafe use of type
'bool' in operation
           -out:epicsCalcTest.exe       epicsCalcTest.obj
../../../../lib/win32-x86/Com.lib  ws2_32.lib advapi32.lib user32.lib
Generating code
w:\windev\epics\r3.14.10\base-3.14.10\src\libcom\calc\calcperform.c(137)
  : warning C4723: potential divide by 0
w:\windev\epics\r3.14.10\base-3.14.10\src\libcom\test\epicscalctest.cpp(
26)
46)
200)
201)
/Tp ..\\epicsAlgorithmTest.cpp
..\epicsAlgorithmTest.cpp(23) : warning C4244: 'initializing' :
conversion from 'double' to 'float', possible loss of data
..\epicsAlgorithmTest.cpp(24) : warning C4244: 'initializing' :
           -out:epicsAlgorithmTest.exe       epicsAlgorithmTest.obj
Generating code
w:\windev\epics\r3.14.10\base-3.14.10\src\libcom\test\epicsalgorithmtest
.cpp(23)
.cpp(24)
..\\epicsMathTest.c
epicsMathTest.c
           -out:epicsMathTest.exe       epicsMathTest.obj
Generating code
w:\windev\epics\r3.14.10\base-3.14.10\src\libcom\test\epicsmathtest.c(53
  : warning C4756: overflow in constant arithmetic
w:\windev\epics\r3.14.10\base-3.14.10\src\libcom\test\epicsmathtest.c(60
w:\windev\epics\r3.14.10\base-3.14.10\src\libcom\test\epicsmathtest.c(33
w:\windev\epics\r3.14.10\base-3.14.10\src\libcom\test\epicsmathtest.c(43
..\\epicsStdioTest.c
epicsStdioTest.c
..\epicsStdioTest.c(47) : warning C4018: '<' : signed/unsigned mismatch
           -out:epicsStdioTest.exe       epicsStdioTest.obj
Generating code
..\\epicsStringTest.c
epicsStringTest.c
           -out:epicsStringTest.exe       epicsStringTest.obj
Generating code
/Tp ..\\epicsTimeTest.cpp
epicsTimeTest.cpp
           -out:epicsTimeTest.exe       epicsTimeTest.obj
Generating code
/Tp ..\\epicsThreadTest.cpp
epicsThreadTest.cpp
           -out:epicsThreadTest.exe       epicsThreadTest.obj
Generating code
/Tp ..\\epicsThreadPriorityTest.cpp
           -out:epicsThreadPriorityTest.exe
epicsThreadPriorityTest.obj      ../../../../lib/win32-x86/Com.lib
Generating code
/Tp ..\\epicsThreadPrivateTest.cpp
           -out:epicsThreadPrivateTest.exe
epicsThreadPrivateTest.obj      ../../../../lib/win32-x86/Com.lib
Generating code
..\\epicsExitTest.c
epicsExitTest.c
           -out:epicsExitTest.exe       epicsExitTest.obj
Generating code
/Tp ..\\epicsTimerTest.cpp
epicsTimerTest.cpp
           -out:epicsTimerTest.exe       epicsTimerTest.obj
Generating code
..\\ringPointerTest.c
ringPointerTest.c
           -out:ringPointerTest.exe       ringPointerTest.obj
Generating code
..\\ringBytesTest.c
ringBytesTest.c
           -out:ringBytesTest.exe       ringBytesTest.obj
Generating code
/Tp ..\\epicsEventTest.cpp
epicsEventTest.cpp
           -out:epicsEventTest.exe       epicsEventTest.obj
Generating code
/Tp ..\\epicsMutexTest.cpp
epicsMutexTest.cpp
           -out:epicsMutexTest.exe       epicsMutexTest.obj
Generating code
/Tp ..\\epicsExceptionTest.cpp
           -out:epicsExceptionTest.exe       epicsExceptionTest.obj
Generating code
/Tp ..\\epicsMessageQueueTest.cpp
           -out:epicsMessageQueueTest.exe
epicsMessageQueueTest.obj
Generating code
..\\macEnvExpandTest.c
macEnvExpandTest.c
           -out:macEnvExpandTest.exe       macEnvExpandTest.obj
Generating code
..\\macLibTest.c
macLibTest.c
           -out:macLibTest.exe       macLibTest.obj
Generating code
..\\taskwdTest.c
taskwdTest.c
           -out:taskwdTest.exe       taskwdTest.obj
Generating code
/Tp ..\\blockingSockTest.cpp
           -out:blockingSockTest.exe       blockingSockTest.obj
Generating code
/Tp ..\\epicsThreadPerform.cpp
           -out:epicsThreadPerform.exe       epicsThreadPerform.obj
Generating code
..\\epicsMaxThreads.c
epicsMaxThreads.c
           -out:epicsMaxThreads.exe       epicsMaxThreads.obj
Generating code
..\\buckTest.c
buckTest.c
..\buckTest.c(47) : warning C4018: '<' : signed/unsigned mismatch
           -out:buckTest.exe       buckTest.obj
Generating code
make -C db/test install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/db/test'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/db/test/O.win32-x86'
..\\callbackTest.c
callbackTest.c
           -out:callbackTest.exe       callbackTest.obj
../../../../lib/win32-x86/dbIoc.lib
../../../../lib/win32-x86/dbStaticHost.lib
../../../../lib/win32-x86/ca.lib  ../../../../lib/win32-x86/Com.lib
Generating code
make -C ./softIoc install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/softIoc'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/softIoc/O.win32-x86'
C:\perl\bin\perl.exe ../../../bin/win32-x86/makeIncludeDbd.pl base.dbd
system.dbd ../O.Common/softIocInclude.dbd
"Expanding dbd"
..\\..\\..\\bin\\win32-x86\\dbExpand.exe  -I . -I .. -I ../../../dbd  -o
  ../O.Common/softIoc.dbd ../O.Common/softIocInclude.dbd
"Installing created dbd file ../../../dbd/softIoc.dbd"
"Installing db file ../../../db/softIocExit.db"
mkdir ../../../db
../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver > temp.cpp
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  temp.cpp
softIoc_registerRecordDeviceDriver.cpp
-DEPICS_BASE=W:\winDev\epics\R3.14.10\base-3.14.10   /MT -DEPICS_DLL_NO
    -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32
-I..\\..\\..\\include        /Tp softIoc_registerRecordDeviceDriver.cpp
-I..\\..\\..\\include        /Tp ..\\softMain.cpp
softMain.cpp
..\softMain.cpp(81) : warning C4129: 'w' : unrecognized character escape
  sequence
..\softMain.cpp(81) : warning C4129: 'e' : unrecognized character escape
  sequence
..\softMain.cpp(81) : warning C4129: 'R' : unrecognized character escape
  sequence
..\softMain.cpp(82) : warning C4129: 'w' : unrecognized character escape
  sequence
..\softMain.cpp(82) : warning C4129: 'e' : unrecognized character escape
  sequence
..\softMain.cpp(82) : warning C4129: 'R' : unrecognized character escape
  sequence
           -out:softIoc.exe       softIoc_registerRecordDeviceDriver.obj
softMain.obj     ../../../lib/win32-x86/recIoc.lib
../../../lib/win32-x86/miscIoc.lib  ../../../lib/win32-x86/rsrvIoc.lib
../../../lib/win32-x86/dbtoolsIoc.lib  ../../../lib/win32-x86/asIoc.lib
../../../lib/win32-x86/dbStaticIoc.lib  ../../../lib/win32-x86/ca.lib
Generating code
w:\windev\epics\r3.14.10\base-3.14.10\src\rec\selrecord.c(101) : warning
w:\windev\epics\r3.14.10\base-3.14.10\src\rec\selrecord.c(102) : warning
"Installing created file ../../../bin/win32-x86/softIoc.exe"
make -C ./gdd install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/gdd'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/gdd/O.win32-x86'
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        /Tp
..\\genApps.cc
genApps.cc
..\\gdd.cc
gdd.cc
..\\gddTest.cc
gddTest.cc
..\\gddAppTable.cc
gddAppTable.cc
..\\gddNewDel.cc
gddNewDel.cc
..\\gddAppDefs.cc
gddAppDefs.cc
..\\aitTypes.c
aitTypes.c
..\\aitGen.c
aitGen.c
           -out:aitGen.exe       aitTypes.obj aitGen.obj
Generating code
"Installing created file ../../../bin/win32-x86/aitGen.exe"
../../../bin/win32-x86/aitGen.exe ../O.Common/aitConvertGenerated.cc cl
..\\aitConvert.cc
aitConvert.cc
..\\aitHelpers.cc
aitHelpers.cc
..\\gddArray.cc
gddArray.cc
..\\gddContainer.cc
gddContainer.cc
..\\gddErrorCodes.cc
gddErrorCodes.cc
..\\gddUtils.cc
gddUtils.cc
..\\gddEnumStringTable.cc
           -out:genApps.exe       genApps.obj gdd.obj gddTest.obj
gddAppTable.obj gddNewDel.obj gddAppDefs.obj aitTypes.obj aitConvert.obj
  aitHelpers.obj gddArray.obj gddContainer.obj gddErrorCodes.obj
gddUtils.obj gddEnumStringTable.obj      ../../../lib/win32-x86/Com.lib
  ws2_32.lib ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
Generating code
"Installing created file ../../../bin/win32-x86/genApps.exe"
../../../bin/win32-x86/genApps.exe ../O.Common/gddApps.h
make[3]: *** [../O.Common/gddApps.h] Error -1073741819
make[2]: *** [install.win32-x86] Error 2
`W:/winDev/epics/R3.14.10/base-3.14.10/src/gdd' make[1]: ***
[gdd.install] Error 2
make[1]: Leaving directory `W:/winDev/epics/R3.14.10/base-3.14.10/src'
make: *** [src.install] Error 2
      MinGW Build Output
make -C ./configure install
make[1]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/configure'
C:\perl\bin\perl.exe ../src/tools/makeMakefile.pl O.win32-x86-mingw
make -C O.win32-x86-mingw -f ../Makefile TOP=../.. T_A=win32-x86-mingw
install
`W:/winDev/epics/R3.14.10/base-3.14.10/configure/O.win32-x86-mingw'
make[2]: Nothing to be done for `install'.
make -C ./src install
make[1]: Entering directory `W:/winDev/epics/R3.14.10/base-3.14.10/src'
make -C ./tools install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/tools'
C:\perl\bin\perl.exe ../../src/tools/makeMakefile.pl O.win32-x86-mingw
make -C O.win32-x86-mingw -f ../Makefile TOP=../../..
T_A=win32-x86-mingw install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/tools/O.win32-x86-mingw'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing script ../../../bin/win32-x86-mingw/convertRelease.pl"
mkdir ../../../bin
mkdir ../../../bin/win32-x86-mingw
"Installing script ../../../bin/win32-x86-mingw/cvsclean.pl"
"Installing script ../../../bin/win32-x86-mingw/dos2unix.pl"
"Installing script ../../../bin/win32-x86-mingw/expandVars.pl"
"Installing script ../../../bin/win32-x86-mingw/filterWarnings.pl"
"Installing script ../../../bin/win32-x86-mingw/fullPathName.pl"
"Installing script ../../../bin/win32-x86-mingw/installEpics.pl"
"Installing script ../../../bin/win32-x86-mingw/makeDbDepends.pl"
"Installing script ../../../bin/win32-x86-mingw/makeIncludeDbd.pl"
"Installing script ../../../bin/win32-x86-mingw/makeMakefile.pl"
"Installing script ../../../bin/win32-x86-mingw/makeTestfile.pl"
"Installing script ../../../bin/win32-x86-mingw/mkmf.pl"
"Installing script ../../../bin/win32-x86-mingw/munch.pl"
"Installing script ../../../bin/win32-x86-mingw/replaceVAR.pl"
"Installing script ../../../bin/win32-x86-mingw/useManifestTool.pl"
make -C ./makeBaseApp install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseApp'
C:\perl\bin\perl.exe ../../bin/win32-x86-mingw/makeMakefile.pl
O.win32-x86-mingw ../../..
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseApp/O.win32-x86-mingw
"Installing script ../../../bin/win32-x86-mingw/makeBaseApp.pl"
"Installing ../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../templates
mkdir ../../../templates/makeBaseApp
mkdir ../../../templates/makeBaseApp/top
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../templates/makeBaseApp/top/configure
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp
"Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/src
"Installing
../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp
"Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp/Db
"Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp/src
"Installing
../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/Db
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing
../../../templates/makeBaseApp/top/exampleApp/Db/userHost.substitutions"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/src
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing
../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleBoot
"Installing
../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing
../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing
../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing
../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocBoot
"Installing
../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing
../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing
../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make[3]: Leaving directory
make[2]: Leaving directory
make -C ./makeBaseExt install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseExt'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/makeBaseExt/O.win32-x86-mingw
"Installing script ../../../bin/win32-x86-mingw/makeBaseExt.pl"
"Installing ../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../templates/makeBaseExt
mkdir ../../../templates/makeBaseExt/top
"Installing ../../../templates/makeBaseExt/top/README"
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../templates/makeBaseExt/top/configure
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-3
86"
mkdir ../../../templates/makeBaseExt/top/configure/os
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland
.win32-x86-borland"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.
aix-ppc-gnu"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-
ppc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Commo
n"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.c
ygwin-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.d
arwin-ppc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx8
6.darwin-ppcx86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.d
arwin-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_
64.freebsd-x86_64"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-
gnu.hpux-parisc-gnu"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.
hpux-parisc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.
interix-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.li
nux-ppc"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-bo
rland.linux-x86-borland"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-de
bug.linux-x86-debug"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.li
nux-athlon"
"Installing
nux-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64
-debug.linux-x86_64-debug"
"Installing
.linux-x86_64"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.osf-alpha.os
f-alpha"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-spar
c-debug.solaris-sparc-debug"
"Installing
c-gnu.solaris-sparc-gnu"
"Installing
c.solaris-sparc"
"Installing
c64-gnu.solaris-sparc64-gnu"
"Installing
c64.solaris-sparc64"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-
gnu.solaris-x86-gnu"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.
solaris-x86"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-bo
rland.win32-x86-borland"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cy
gwin.win32-x86-cygwin"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-de
bug.win32-x86-debug"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mi
ngw.win32-x86-mingw"
"Installing
../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.wi
n32-x86"
"Installing ../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../templates/makeBaseExt/top/src
"Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing
../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../templates/makeBaseExt/top/simpleExt
make -C ./libCom install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/libCom'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/libCom/O.win32-x86-mingw'
C:\perl\bin\perl.exe ../../../src/libCom/misc/makeEpicsVersion.pl
../../../configure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.14.10
../../../include/epicsVersion.h"
mkdir ../../../include
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
../../../include/ipAddrToAsciiAsynchronous.h"
../../../include/compilerDependencies.h"
"Installing generic include file ../../../include/epicsUnitTest.h"
"Installing generic include file ../../../include/testMain.h"
../../../include/os/WIN32/osiFileName.h"
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing generic include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
"Installing os dependent include file
../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing generic include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing generic include file ../../../include/os/WIN32/osdEvent.h"
"Installing generic include file ../../../include/os/WIN32/epicsMath.h"
../../../include/os/WIN32/osdMessageQueue.h"
"Installing generic include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
../../../include/os/WIN32/osdPoolStatus.h"
"Installing generic include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing generic include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing generic include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
../../../include/os/WIN32/osdWireFormat.h"
../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsEndian.h"
../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../include/devLib.h"
../../../include/os/WIN32/osdVME.h"
"Installing generic include file ../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/tsDefs.h"
windres -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
-I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default
-I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClient -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -I../../../include/os/WIN32
-I../../../include        ../Com.rc Com.coff
gcc -c              -D_MINGW      -O3   -Wall      -m32   -DEPICS_DLL_NO
-I../../../include         ../../../src/libCom/bucketLib/bucketLib.c
g++ -c              -D_MINGW      -O3   -Wall      -m32   -DEPICS_DLL_NO
-I../../../include         ../../../src/libCom/ring/epicsRingPointer.cpp
-I../../../include         ../../../src/libCom/ring/epicsRingBytes.c
-I../../../include         ../../../src/libCom/calc/postfix.c
-I../../../include         ../../../src/libCom/calc/calcPerform.c
-I../../../include         ../../../src/libCom/cvtFast/cvtFast.c
-I../../../include
../../../src/libCom/cxxTemplates/resourceLib.cpp
-I../../../include
../../../src/libCom/cxxTemplates/epicsOnce.cpp
-I../../../include
../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
-I../../../include         ../../../src/libCom/dbmf/dbmf.c
-I../../../include         ../../../src/libCom/ellLib/ellLib.c
-I../../../include         ../../../src/libCom/env/envSubr.c
C:\perl\bin\perl.exe ../../../src/libCom/env/bldEnvData.pl
../../../configure
Generating envData.c
-I../../../include         envData.c
-I../../../include         ../../../src/libCom/error/errlog.c
-I../../../include         ../../../src/libCom/error/errSymLib.c
C:\perl\bin\perl.exe ../../../src/libCom/error/makeStatTbl.pl
../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h
../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h
../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h
../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h
../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h
-I../../../include         errSymTbl.c
-I../../../include         ../../../src/libCom/fdmgr/fdmgr.cpp
-I../../../include         ../../../src/libCom/fdmgr/fdManager.cpp
-I../../../include         ../../../src/libCom/freeList/freeListLib.c
-I../../../include         ../../../src/libCom/gpHash/gpHashLib.c
-I../../../include         ../../../src/libCom/iocsh/iocsh.cpp
-I../../../include         ../../../src/libCom/iocsh/registry.c
-I../../../include         ../../../src/libCom/iocsh/libComRegister.c
-I../../../include         ../../../src/libCom/logClient/iocLog.c
-I../../../include         ../../../src/libCom/logClient/logClient.c
-I../../../include         ../../../src/libCom/macLib/macCore.c
-I../../../include         ../../../src/libCom/macLib/macEnv.c
-I../../../include         ../../../src/libCom/macLib/macUtil.c
-I../../../include         ../../../src/libCom/misc/aToIPAddr.c
-I../../../include         ../../../src/libCom/misc/adjustment.c
-I../../../include         ../../../src/libCom/misc/cantProceed.c
-I../../../include         ../../../src/libCom/misc/epicsConvert.c
-I../../../include         ../../../src/libCom/misc/epicsExit.c
-I../../../include         ../../../src/libCom/misc/epicsStdlib.c
-I../../../include         ../../../src/libCom/misc/epicsString.c
-I../../../include         ../../../src/libCom/misc/truncateFile.c
-I../../../include
../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
-I../../../include         ../../../src/libCom/misc/epicsUnitTest.c
-I../../../include         ../../../src/libCom/osi/epicsThread.cpp
-I../../../include         ../../../src/libCom/osi/epicsMutex.cpp
-I../../../include         ../../../src/libCom/osi/epicsEvent.cpp
-I../../../include         ../../../src/libCom/osi/epicsTime.cpp
-I../../../include         ../../../src/libCom/osi/epicsMessageQueue.cpp
-I../../../include         ../../../src/libCom/osi/epicsGeneralTime.c
-I../../../include         ../../../src/libCom/osi/osiClockTime.c
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdSock.c
-I../../../include
../../../src/libCom/osi/os/WIN32/osdSockAddrReuse.cpp
-I../../../include         ../../../src/libCom/osi/osiSock.c
-I../../../include
../../../src/libCom/osi/os/WIN32/systemCallIntMech.cpp
-I../../../include
../../../src/libCom/osi/os/WIN32/epicsSocketConvertErrnoToString.cpp
-I../../../include
../../../src/libCom/osi/os/default/osdAssert.c
-I../../../include
../../../src/libCom/osi/os/default/osdFindSymbol.c
-I../../../include
../../../src/libCom/osi/os/default/osdInterrupt.c
-I../../../include
../../../src/libCom/osi/os/WIN32/osdPoolStatus.c
-I../../../include
../../../src/libCom/osi/os/WIN32/osdSignal.cpp
gcc -c              -D_MINGW      -O3   -Wall  -U__STDC__    -m32
-DEPICS_DLL_NO   -I. -I../O.Common -I.
-I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix
-I../../../src/libCom/osi/os/default -I..
-I../../../include         ../../../src/libCom/osi/os/default/osdEnv.c
<command line>:2:1: warning: undefining "__STDC__"
-DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS   -m32
-I../../../include
../../../src/libCom/osi/os/default/epicsReadline.c
-I../../../include
../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
-I../../../include         ../../../src/libCom/osi/epicsStdio.c
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdStdio.c
gcc -c           -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING   -D_MINGW
      -O3   -Wall      -m32   -DEPICS_DLL_NO   -I. -I../O.Common -I.
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdThread.c
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdMutex.c
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdEvent.c
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdTime.cpp
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdProcess.c
-I../../../include         ../../../src/libCom/osi/os/WIN32/osdNetIntf.c
-I../../../include
../../../src/libCom/osi/os/default/osdMessageQueue.cpp
-I../../../include         ../../../src/libCom/osi/devLib.c
-I../../../include
../../../src/libCom/osi/os/default/devLibOSD.c
-I../../../include         ../../../src/libCom/taskwd/taskwd.c
-I../../../include         ../../../src/libCom/timer/epicsTimer.cpp
-I../../../include         ../../../src/libCom/timer/timer.cpp
-I../../../include         ../../../src/libCom/timer/timerQueue.cpp
-I../../../include
../../../src/libCom/timer/timerQueueActive.cpp
-I../../../include
../../../src/libCom/timer/timerQueueActiveMgr.cpp
-I../../../include
../../../src/libCom/timer/timerQueuePassive.cpp
-I../../../include         ../../../src/libCom/tsDefs/tsDefs.c
-I../../../include
../../../src/libCom/osi/os/WIN32/epicsGetopt.c
-I../../../include
../../../src/libCom/osi/os/WIN32/setThreadName.cpp
-I../../../include
../../../src/libCom/osi/os/WIN32/forceBadAllocException.cpp
ar -rc   Com.lib         bucketLib.o epicsRingPointer.o epicsRingBytes.o
postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o
epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o
errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o
iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o
macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o
epicsExit.o epicsStdlib.o epicsString.o truncateFile.o
ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o
epicsEvent.o epicsTime.o epicsMessageQueue.o epicsGeneralTime.o
osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o
systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o
osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o
epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o
osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o
osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epicsTimer.o timer.o
timerQueue.o timerQueueActive.o timerQueueActiveMgr.o
timerQueuePassive.o tsDefs.o epicsGetopt.o setThreadName.o
forceBadAllocException.o
ranlib Com.lib
"Installing library ../../../lib/win32-x86-mingw/Com.lib"
mkdir ../../../lib/win32-x86-mingw
"Installing html ../../../html//freeList/freeList.html"
mkdir ../../../html
mkdir ../../../html/freeList
"Installing html ../../../html//gpHash/gpHash.html"
mkdir ../../../html/gpHash
make -C ./toolsComm install
make[2]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm'
make -C ./antelope install
make[3]: Entering directory
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/antelope'
C:\perl\bin\perl.exe ../../../bin/win32-x86-mingw/makeMakefile.pl
O.win32-x86-mingw ../../../..
C:\perl\bin\perl.exe -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86-mingw -f ../Makefile TOP=../../../..
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/antelope/O.win32-x8
6-mingw'
gcc -c              -D_MINGW      -O3   -w    -D_NO_PROTO  -m32
-DEPICS_DLL_NO   -I. -I../O.Common -I. -I..
-I../../../../include/os/WIN32 -I../../../../include
../closure.c
-I../../../../include/os/WIN32 -I../../../../include         ../error.c
-I../../../../include/os/WIN32 -I../../../../include         ../lalr.c
-I../../../../include/os/WIN32 -I../../../../include         ../lr0.c
-I../../../../include/os/WIN32 -I../../../../include         ../main.c
-I../../../../include/os/WIN32 -I../../../../include         ../mkpar.c
-I../../../../include/os/WIN32 -I../../../../include         ../output.c
-I../../../../include/os/WIN32 -I../../../../include         ../reader.c
../skeleton.c
-I../../../../include/os/WIN32 -I../../../../include         ../symtab.c
../verbose.c
../warshall.c
g++ -o antelope.exe -static
-LW:\winDev\epics\R3.14.10\base-3.14.10\lib\win32-x86-mingw       -m32
               closure.o error.o lalr.o lr0.o main.o mkpar.o output.o
reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom -lws2_32
-lws2_32
"Installing created file ../../../../bin/win32-x86-mingw/antelope.exe"
6-mingw'
make -C ./flex install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/flex'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/toolsComm/flex/O.win32-x86-mi
ngw'
"Installing generic include file ../../../../include/flex.skel.static"
gcc -c            -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\""
-DUSG  -D_MINGW      -O3   -w      -m32   -DEPICS_DLL_NO   -I.
-I../../../../include         ../ccl.c
-I../../../../include         ../dfa.c
-I../../../../include         ../ecs.c
-I../../../../include         ../gen.c
-I../../../../include         ../misc.c
-I../../../../include         ../nfa.c
-I../../../../include         ../sym.c
-I../../../../include         ../tblcmp.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f parse.c y.tab.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f parse.h y.tab.h
../../../../bin/win32-x86-mingw/antelope.exe -l -d ../parse.y
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.c parse.c
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.h parse.h
-I../../../../include         parse.c
g++ -o e_flex.exe -static
               ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o
parse.o   -lCom -lws2_32     -lws2_32
"Installing created file ../../../../bin/win32-x86-mingw/e_flex.exe"
ngw'
make -C ./ca install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/ca'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/ca/O.win32-x86-mingw'
"Installing generic include file ../../../include/cadef.h"
"Installing generic include file ../../../include/caerr.h"
"Installing generic include file ../../../include/caeventmask.h"
"Installing generic include file ../../../include/caProto.h"
"Installing generic include file ../../../include/db_access.h"
"Installing generic include file ../../../include/addrList.h"
"Installing generic include file ../../../include/cacIO.h"
"Installing generic include file ../../../include/caDiagnostics.h"
windres -I. -I../O.Common -I. -I.. -I../../../include/os/WIN32
-I../../../include        ../ca.rc ca.coff
-I../../../include         ../cac.cpp
-I../../../include         ../cacChannel.cpp
-I../../../include         ../cacChannelNotify.cpp
-I../../../include         ../cacContextNotify.cpp
-I../../../include         ../cacReadNotify.cpp
-I../../../include         ../cacWriteNotify.cpp
-I../../../include         ../cacStateNotify.cpp
-I../../../include         ../access.cpp
-I../../../include         ../iocinf.cpp
-I../../../include         ../convert.cpp
-I../../../include         ../test_event.cpp
-I../../../include         ../repeater.cpp
-I../../../include         ../searchTimer.cpp
-I../../../include         ../disconnectGovernorTimer.cpp
-I../../../include         ../repeaterSubscribeTimer.cpp
-I../../../include         ../baseNMIU.cpp
-I../../../include         ../nciu.cpp
-I../../../include         ../netiiu.cpp
-I../../../include         ../udpiiu.cpp
-I../../../include         ../tcpiiu.cpp
-I../../../include         ../noopiiu.cpp
-I../../../include         ../netReadNotifyIO.cpp
-I../../../include         ../netWriteNotifyIO.cpp
-I../../../include         ../netSubscription.cpp
-I../../../include         ../tcpSendWatchdog.cpp
-I../../../include         ../tcpRecvWatchdog.cpp
-I../../../include         ../bhe.cpp
-I../../../include         ../ca_client_context.cpp
-I../../../include         ../oldChannelNotify.cpp
-I../../../include         ../oldSubscription.cpp
-I../../../include         ../getCallback.cpp
-I../../../include         ../getCopy.cpp
-I../../../include         ../putCallback.cpp
-I../../../include         ../syncgrp.cpp
-I../../../include         ../CASG.cpp
-I../../../include         ../syncGroupNotify.cpp
-I../../../include         ../syncGroupReadNotify.cpp
-I../../../include         ../syncGroupWriteNotify.cpp
-I../../../include         ../localHostName.cpp
-I../../../include         ../comQueRecv.cpp
-I../../../include         ../comQueSend.cpp
-I../../../include         ../comBuf.cpp
-I../../../include         ../hostNameCache.cpp
-I../../../include         ../msgForMultiplyDefinedPV.cpp
ar -rc   ca.lib         cac.o cacChannel.o cacChannelNotify.o
cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o
access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o
disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o
netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o
netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o
bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o
getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o
syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o
comQueRecv.o comQueSend.o comBuf.o hostNameCache.o
msgForMultiplyDefinedPV.o
ranlib ca.lib
"Installing library ../../../lib/win32-x86-mingw/ca.lib"
-I../../../include         ../caRepeater.cpp
g++ -o caRepeater.exe -static
              caRepeater.o    -lca -lCom -lws2_32 -lws2_32 -ladvapi32
-luser32     -lws2_32
-I../../../include         ../catimeMain.c
-I../../../include         ../catime.c
g++ -o catime.exe -static
              catimeMain.o catime.o    -lca -lCom -lws2_32 -lws2_32
-ladvapi32 -luser32     -lws2_32
-I../../../include         ../acctstMain.c
-I../../../include         ../acctst.c
g++ -o acctst.exe -static
              acctstMain.o acctst.o    -lca -lCom -lws2_32 -lws2_32
-I../../../include         ../caConnTestMain.cpp
-I../../../include         ../caConnTest.cpp
g++ -o caConnTest.exe -static
              caConnTestMain.o caConnTest.o    -lca -lCom -lws2_32
-lws2_32 -ladvapi32 -luser32     -lws2_32
-I../../../include         ../casw.cpp
g++ -o casw.exe -static
              casw.o    -lca -lCom -lws2_32 -lws2_32 -ladvapi32 -luser32
     -lws2_32
-I../../../include         ../caEventRateMain.cpp
-I../../../include         ../caEventRate.cpp
g++ -o caEventRate.exe -static
              caEventRateMain.o caEventRate.o    -lca -lCom -lws2_32
"Installing created file ../../../bin/win32-x86-mingw/caRepeater.exe"
"Installing created file ../../../bin/win32-x86-mingw/catime.exe"
"Installing created file ../../../bin/win32-x86-mingw/acctst.exe"
"Installing created file ../../../bin/win32-x86-mingw/caConnTest.exe"
"Installing created file ../../../bin/win32-x86-mingw/casw.exe"
"Installing created file ../../../bin/win32-x86-mingw/caEventRate.exe"
"Installing html ../../../html//CAref.html"
make -C ./dbStatic install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dbStatic'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/dbStatic/O.win32-x86-mingw'
"Installing generic include file ../../../include/alarm.h"
"Installing generic include file ../../../include/alarmString.h"
"Installing generic include file ../../../include/dbBase.h"
"Installing generic include file ../../../include/dbFldTypes.h"
"Installing generic include file ../../../include/dbStaticLib.h"
"Installing generic include file ../../../include/dbStaticPvt.h"
"Installing generic include file ../../../include/link.h"
"Installing generic include file ../../../include/special.h"
"Installing generic include file ../../../include/guigroup.h"
"Installing generic include file ../../../include/devSup.h"
"Installing generic include file ../../../include/drvSup.h"
"Installing generic include file ../../../include/recSup.h"
"Installing generic include file ../../../include/dbStaticIocRegister.h"
-I../../../include         ../dbStaticNoRun.c
-I../../../include        ../dbStaticHost.rc dbStaticHost.coff
-I../../../include         ../dbStaticLib.c
-S../../../include/flex.skel.static -8 -I ../dbLex.l
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  lex.yy.c dbLex.c
C:\perl\bin\perl.exe -MExtUtils::Command -e rm_f dbYacc.c y.tab.c
../../../bin/win32-x86-mingw/antelope.exe  ../dbYacc.y
C:\perl\bin\perl.exe -MExtUtils::Command -e mv  y.tab.c dbYacc.c
-I../../../include         dbYacc.c
-I../../../include         ../dbPvdLib.c
ar -rc   dbStaticHost.lib        dbStaticNoRun.o dbStaticLib.o dbYacc.o
dbPvdLib.o
ranlib dbStaticHost.lib
-I../../../include         ../dbStaticRun.c
-I../../../include         ../dbStaticIocRegister.c
-I../../../include        ../dbStaticIoc.rc dbStaticIoc.coff
ar -rc   dbStaticIoc.lib        dbStaticRun.o dbStaticIocRegister.o
dbStaticLib.o dbYacc.o dbPvdLib.o
ranlib dbStaticIoc.lib
"Installing library ../../../lib/win32-x86-mingw/dbStaticHost.lib"
"Installing library ../../../lib/win32-x86-mingw/dbStaticIoc.lib"
-I../../../include         ../dbReadTest.c
g++ -o dbReadTest.exe -static
              dbReadTest.o    -ldbStaticHost -lCom -lws2_32     -lws2_32
"Installing created file ../../../bin/win32-x86-mingw/dbReadTest.exe"
-I../../../include         ../dbExpand.c
g++ -o dbExpand.exe -static
              dbExpand.o    -ldbStaticHost -lCom -lws2_32     -lws2_32
"Installing created file ../../../bin/win32-x86-mingw/dbExpand.exe"
-I../../../include         ../dbToMenuH.c
g++ -o dbToMenuH.exe -static
              dbToMenuH.o    -ldbStaticHost -lCom -lws2_32     -lws2_32
"Installing created file ../../../bin/win32-x86-mingw/dbToMenuH.exe"
-I../../../include         ../dbToRecordtypeH.c
g++ -o dbToRecordtypeH.exe -static
              dbToRecordtypeH.o    -ldbStaticHost -lCom -lws2_32
-lws2_32
../../../bin/win32-x86-mingw/dbToRecordtypeH.exe"
make -C ./registry install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/registry'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/registry/O.win32-x86-mingw'
"Installing generic include file ../../../include/registryRecordType.h"
../../../include/registryDeviceSupport.h"
../../../include/registryDriverSupport.h"
"Installing generic include file ../../../include/registryFunction.h"
"Installing generic include file ../../../include/registryCommon.h"
"Installing generic include file ../../../include/registryIocRegister.h"
-I../../../include        ../registryIoc.rc registryIoc.coff
-I../../../include         ../registryRecordType.c
-I../../../include         ../registryDeviceSupport.c
-I../../../include         ../registryDriverSupport.c
-I../../../include         ../registryFunction.c
-I../../../include         ../registryCommon.c
-I../../../include         ../registryIocRegister.c
ar -rc   registryIoc.lib         registryRecordType.o
registryDeviceSupport.o registryDriverSupport.o registryFunction.o
registryCommon.o registryIocRegister.o
ranlib registryIoc.lib
"Installing library ../../../lib/win32-x86-mingw/registryIoc.lib"
"Installing script
../../../bin/win32-x86-mingw/registerRecordDeviceDriver.pl"
make -C ./bpt install
`W:/winDev/epics/R3.14.10/base-3.14.10/src/bpt'
`W:/winDev/epics/R3.14.10/base-3.14.10/src/bpt/O.win32-x86-mingw'
-I../../../include         ../makeBpt.c
g++ -o makeBpt.exe -static
              makeBpt.o    -lCom -lws2_32     -lws2_32
"Installing created file ../../../bin/win32-x86-mingw/makeBpt.exe"
../../../bin/win32-x86-mingw/makeBpt.exe ../bptTypeJdegC.data
../O.Common/bptTypeJdegC.dbd
../../../bin/win32-x86-mingw/makeBpt.exe ../bptTypeJdegF.data
../O.Common/bptTypeJdegF.dbd
../../../bin/win32-x86-mingw/makeBpt.exe ../bptTypeKdegC.data
../O.Common/bptTypeKdegC.dbd
../../../bin/win32-x86-mingw/makeBpt.exe ../bptTypeKdegF.data
../O.Common/bptTypeKdegF.dbd
"Installing dbd file ../../../dbd/menuConvert.dbd"
mkdir ../../../dbd
"Installing created dbd file ../../../dbd/bptTypeJdegC.dbd"
"Installing created dbd file ../../../dbd/bptTypeJdegF.dbd"
"Installing created dbd file ../../../dbd/bptTypeKdegC.dbd"
"Installing created dbd file ../../../dbd/bptTypeKdegF.dbd"
../../../bin/win32-x86-mingw/dbToMenuH.exe ../menuConvert.dbd
../O.Common/menuConvert.h
make[3]: *** [../O.Common/menuConvert.h] Error -1073741819
make[2]: *** [install.win32-x86-mingw] Error 2
make[1]: *** [bpt.install] Error 2
RE: Building ASYN on Windows John Dobbins
RE: Building ASYN on Windows Mark Rivers
Prev: RE: CA reconnection problem Jeff Hill
Next: Re: Building ASYN on Windows Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Building ASYN on Windows John Dobbins
Next: RE: Building ASYN on Windows John Dobbins
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
