Dirk,
I was in electrical safety training this morning and I am headed out the
door soon to my son's bike race in Colorado. I will return to the office
Monday.
Nevertheless, after a really quick look at the output from dbcar it appears
that something is blocking the CA client library's timer queue - it's
probably wedged in a timer expire callback. In this particular output we
suspect this because of many timers pending with negative delays. A quick
guess is that the channels are wedged on the disconnectGovernorTimer object.
It looks like it needs an improved show diagnostic.
> I would send a stack trace of the CAC timer thread if I could find it.
> What's the name?
I did just make a change to the timer queue's show function so that it will
print the thread id. I need to look at also formatting issues in the
printout below. Lacking that, look for threads with the name timer queue
that are close to the same scheduling priority (in the vxWorks "i"
diagnostic) as the DBCA CA client threads. Also, look for any timer queue
thread that isn?t blocking most of the time on its event semaphore. Also,
look for a timer queue stack trace that?s executing in the CA client
library.
If there is a deadlock then, to get the issue fixed, we may need to look at
the other threads to find the one with the lock hierarchy inversion. That
may require a stack trace all of the threads in the CA context for DBCA.
They will be, all of them, running at close to the same scheduling priority
and should have either CA, DBCA, or timer queue in their names. The best
guess now is an unanticipated lock inversion between the CAC and DBCA
facilities.
EPICS threaded timer queue at 0x7bf6240
epicsTimerQueue with 15 items pending
11searchTimer, state = pending, delay = -19.894333 search timer delay
0.064000 0 channels with search request pending 0 channels with search
response pending 11searchTimer, state = pending, delay = -20.000999 search
timer delay 1.024000 0 channels with search request pending 0 channels with
search response pending 11searchTimer, state = pending, delay = -20.163666
search timer delay 0.128000 0 channels with search request pending 0
channels with search response pending 11searchTimer, state = pending, delay
= -20.235666 search timer delay 0.256000 0 channels with search request
pending 0 channels with search response pending 11searchTimer, state =
pending, delay = -20.296333 search timer delay 0.512000 0 channels with
search request pending 0 channels with search response pending
11searchTimer, state = pending, delay = -18.926999 search timer delay
2.048000 0 channels with search request pending 0 channels with search
response pending 11searchTimer, state = pending, delay = -17.095666 search
timer delay 4.096000 0 channels with search request pending 0 channels with
search response pending 23disconnectGovernorTimer, state = pending, delay =
-16.191666 disconnect governor timer:
11searchTimer, state = pending, delay = -13.316332 search timer delay
8.192000 0 channels with search request pending 0 channels with search
response pending 11searchTimer, state = pending, delay = -5.424332 search
timer delay 16.384000 0 channels with search request pending 0 channels with
search response pending 11searchTimer, state = pending, delay = -5.590332
search timer delay 32.768000 0 channels with search request pending 0
channels with search response pending 15tcpRecvWatchdog, state = pending,
delay = 1.191668 Receive virtual circuit watchdog at 0x7b96df0, period
30.000000
11searchTimer, state = pending, delay = 6.361002 search timer delay
65.536000 0 channels with search request pending 0 channels with search
response pending 11searchTimer, state = pending, delay = 51.530337 search
timer delay 131.072000 0 channels with search request pending 0 channels
with search response pending 11searchTimer, state = pending, delay =
236.852334 search timer delay 262.144000 0 channels with search request
pending 0 channels with search response pending reschedule event
Thanks for your help,
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
> -----Original Message-----
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: Thursday, August 06, 2009 3:22 AM
> To: Jeff Hill
> Cc: 'tech-talk'
> Subject: Re: CA reconnection problem
> Hi Jeff,
> Time advances normally on the IOC.
> Bug 299 is not related because I have no suspended tasks.
> Bug 330 is also not related because my channels never reconnect, even
> after days.
> The IOC connects to the gateway with normal broadcasts on the local
> network. I
> can see beacons from all IOCs and gateway and I can see the beacon anomaly
> when
> I start a softioc. Still the IOC does not send any search requests to
> reconnect
> the links. I can see the search requests from 3.13 IOCs, 3.14.8 medms and
> the
> gateway after a beacon anomaly, but not from 3.14.8 IOCs. It is definitely
> not
> the case that the 3.14.8 IOC never stops searching.
> I do not want to restart the gateway at the moment because we have user
> operation. I also think it's not necessary because I can see the channels
> through the gateway with caget. I doubt that it is a gateway problem at
> all.
> Rebooting the IOC helps. Writing the record name to the link again helps
> too,
> but only for this link. All other links on the same IOC to the same target
> record stay disconnected. I do not understand this.
> UDP package size is not an issue because its only 8 broken CA links to 2
> records. So it should easily fit into one package. But as I said, I see no
> package at all (except when I rewnew the link).
> What's
> the name?
> Here is the full dbcar output, mybe it helps:
> X04SA-VME-ID2 > dbcar "",100
> connected X04SA-VME-ID2 X04SA-ID-LMD:PMD.INPB X04SA-ID-LMD:SCALER.S3
> connected X04SA-VME-ID2 X04SA-ID-LMD:PMD-INJ.INPB X04SA-ID-LMD:PMD
> connected X04SA-VME-ID2 X04SA-ID-LMD:PMD-NOINJ.INPB X04SA-ID-LMD:PMD
> connected X04SA-VME-ID2 X04SA-ID-LMD:PMU.INPB X04SA-ID-LMD:SCALER.S2
> connected X04SA-VME-ID2 X04SA-ID-LMU:PMD.INPB X04SA-ID-LMU:SCALER.S3
> connected X04SA-VME-ID2 X04SA-ID-LMU:PMU.INPB X04SA-ID-LMU:SCALER.S2
> connected 129.129.104.31:5064 X04SA-ID-FBPMD:ALARM.INPD X04SA-ID-
> GAP:ISOPEN
> not_connected X04SA-ID-FBPMD:X-COMP.INPE ACOAU-ACCU:OP-MODE
> not_connected X04SA-ID-FBPMD:X-COMP.INPI ARIDI-PCT:CURRENT
> not_connected X04SA-ID-FBPMD:Y-COMP.INPE ACOAU-ACCU:OP-MODE
> not_connected X04SA-ID-FBPMD:Y-COMP.INPI ARIDI-PCT:CURRENT
> connected 129.129.104.31:5064 X04SA-ID-FBPMU:ALARM.INPD X04SA-ID-
> GAP:ISOPEN
> not_connected X04SA-ID-FBPMU:X-COMP.INPE ACOAU-ACCU:OP-MODE
> not_connected X04SA-ID-FBPMU:X-COMP.INPI ARIDI-PCT:CURRENT
> not_connected X04SA-ID-FBPMU:Y-COMP.INPE ACOAU-ACCU:OP-MODE
> not_connected X04SA-ID-FBPMU:Y-COMP.INPI ARIDI-PCT:CURRENT
> connected 129.129.104.31:5064 X04SA-ID:FBPM-ILK.OUT X04SA-ID:ILK-
> BITS.B1
> connected X04SA-VME-ID2 X04SA-VME-ID2:HBTSYNC.INPA X04SA-VME-
> ID2:HBT.VAL
> connected X04SA-VME-ID2 X04SA-VME-ID2:MEMALLOC.INPA X04SA-VME-
> ID2:MEMALLOCRA
> W
> connected X04SA-VME-ID2 X04SA-VME-ID2:MEMFREE.INPA X04SA-VME-
> ID2:MEMFREE-RAW
> connected X04SA-VME-ID2 X04SA-VME-ID2:MEMMAX.INPA X04SA-VME-
> ID2:MEMMAX-RAW
> ncalinks 21 not connected 8 no_read_access 0 no_write_access 0
> nDisconnect 0 nNoWrite 0
> ca_client_context at 0x7ca6c90 pndRecvCnt=0 ioSeqNo=0
> dbContext at 0x7ca6a80
> event call back cache location 0x7bac130, and its size 24
> dbContextReadNotifyCache
> dbContextReadNotifyCacheAlocator
> count 1 and size 88
> epicsMutexId 0x7ca6c20 source ../../../src/libCom/osi/epicsMutex.cpp line
> 197
> Semaphore Id : 0x7ca6c50
> Semaphore Type : MUTEX
> Task Queuing : PRIORITY
> Pended Tasks : 3
> Owner : 0x7a331e0 (tShell)
> Options : 0xd SEM_Q_PRIORITY
> SEM_DELETE_SAFE
> SEM_INVERSION_SAFE
> VxWorks Events
> Registered Task : NONE
> Event(s) to Send : N/A
> Options : N/A
> Pended Tasks
> NAME TID PRI TIMEOUT
> timerQueue 7bf5d20 148 0
> CAC-event 7bb5a90 148 0
> CAC-TCP-recv 7a5e3b0 150 0
> Channel Access Client Context at 0x7bf8cc0 for user ioc
> revision "@(#) EPICS 3.14.8.2, CA Client Library Nov 29 2006"
> Hash table with 512 buckets and 2 items of type 6tcpiiu installed
> Virtual circuit to "129.129.104.31:5064" at version V4.8 state 1
> current data cache pointer = 0x7b88c20 current data cache size =
> 16384
> contiguous receive message count=0, busy detect bool=0, flow
> control boo
> l=0
> eceive thread is busy=0
> virtual circuit socket identifier 20
> send thread flush signal:
> Semaphore Id : 0x7b88bc0
> Semaphore Type : BINARY
> Task Queuing : FIFO
> Pended Tasks : 1
> State : EMPTY
> Options : 0x0 SEM_Q_FIFO
> VxWorks Events
> Options : N/A
> Pended Tasks
> CAC-TCP-send 7b8fba0 148 0
> send thread:
> recv thread:
> echo pending bool = 0
> IO identifier hash table:
> Connected channels
> Channel "X04SA-ID-GAP:ISOPEN", connected to server 129.129.104.31:5064,
> native t
> ype DBF_ENUM, native element count 1, read access, write access
> network IO pointer = 0x7b96cd0
> server identifier 392
> search retry number=1
> name length=20
> native t
> server identifier 393
> name length=20
> Channel "X04SA-ID:ILK-BITS.B1", connected to server 129.129.104.31:5064,
> native
> type DBF_CHAR, native element count 1, read access, write access
> server identifier 394
> name length=21
> Virtual circuit to "129.129.104.14:5064" at version V4.11 state 1
> current data cache pointer = 0x7af62b0 current data cache size =
> 16384
> control boo
> l=0
> virtual circuit socket identifier 22
> Semaphore Id : 0x7a1f670
> Task Queuing : FIFO
> Pended Tasks : 1
> State : EMPTY
> VxWorks Events
> Options : N/A
> Pended Tasks
> CAC-TCP-send 7a61590 148 0
> send thread:
> recv thread:
> Unresponsive circuit channels
> Channel "ARIDI-PCT:CURRENT" is disconnected
> network IO pointer = 0x7b96f58
> server identifier 1
> name length=18
> server identifier 2
> name length=18
> server identifier 3
> name length=18
> server identifier 4
> name length=18
> Channel "ACOAU-ACCU:OP-MODE" is disconnected
> server identifier 5
> name length=19
> server identifier 6
> name length=19
> server identifier 7
> name length=19
> server identifier 8
> name length=19
> 16384
> control boo
> l=0
> Task Queuing : FIFO
> Pended Tasks : 1
> State : EMPTY
> VxWorks Events
> Options : N/A
> Pended Tasks
> send thread:
> recv thread:
> Connected channels
> native t
> name length=20
> native t
> name length=20
> native
> name length=21
> 16384
> control boo
> l=0
> Task Queuing : FIFO
> Pended Tasks : 1
> State : EMPTY
> VxWorks Events
> Options : N/A
> Pended Tasks
> send thread:
> recv thread:
> server identifier 1
> name length=18
> server identifier 2
> name length=18
> server identifier 3
> name length=18
> server identifier 4
> name length=18
> server identifier 5
> name length=19
> server identifier 6
> name length=19
> server identifier 7
> name length=19
> server identifier 8
> name length=19
> entries per bucket: mean = 0.003906 std dev = 0.062378 max = 1
> connection time out watchdog period 30.000000
> Datagram IO circuit (and disconnected channel repository)
> repeater port 5065
> default server port 5064
> Channel Access Address List
> 129.129.104.255:5064
> socket identifier 18
> bytes in xmit buffer 16
> shut down command bool 0
> recv thread exit signal:
> repeater subscribe timer: attempts=2 registered=1 once=0
> search timer delay 0.032000
> search timer delay 0.064000
> search timer delay 1.024000
> search timer delay 2.048000
> search timer delay 4.096000
> search timer delay 8.192000
> search timer delay 16.384000
> search timer delay 65.536000
> search timer delay 131.072000
> Program begin time:
> epicsTime: MON MAY 11 2009 16:53:29.047623310
> epicsTime: revision "@(#) EPICS 3.14.8.2, Common Utilities Library Nov 29
> 2006"
> Channel identifier hash table:
> Hash table with 512 buckets and 11 items of type 4nciu installed
> native t
> name length=20
> server identifier 5
> name length=19
> server identifier 1
> name length=18
> server identifier 6
> name length=19
> server identifier 2
> name length=18
> native t
> name length=20
> server identifier 7
> name length=19
> server identifier 3
> name length=18
> server identifier 8
> name length=19
> server identifier 4
> name length=18
> native
> name length=21
> native t
> name length=20
> server identifier 5
> name length=19
> server identifier 1
> name length=18
> server identifier 6
> name length=19
> server identifier 2
> name length=18
> native t
> name length=20
> server identifier 7
> name length=19
> server identifier 3
> name length=18
> server identifier 8
> name length=19
> server identifier 4
> name length=18
> native
> name length=21
> entries per bucket: mean = 0.021484 std dev = 0.144992 max = 1
> Hash table with 512 buckets and 10 items of type 8baseNMIU installed
> event subscription IO at 0x7ae2ef0, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae2f1c, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae2f48, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae2f74, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae2fa0, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae2fcc, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae2ff8, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae3024, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae3050, type DBF_invalid, element count 1,
> mask 5
> event subscription IO at 0x7ae307c, type DBF_invalid, element count 1,
> mask 5
> mask 5
> mask 5
> mask 5
> mask 5
> mask 5
> mask 5
> mask 5
> mask 5
> mask 5
> mask 5
> entries per bucket: mean = 0.019531 std dev = 0.138383 max = 1
> Beacon source identifier hash table:
> Hash table with 512 buckets and 11 items of type 3bhe installed
> CA beacon hash entry for 129.129.104.13:32771 with period estimate
> 15.049622
> beacon number 718291, on MON JUN 29 2009 13:59:03
> CA beacon hash entry for 129.129.104.33:5064 with period estimate
> 14.849221
> beacon number 0, on THU AUG 06 2009 10:56:40
> CA beacon hash entry for 129.129.104.34:5064 with period estimate
> 14.891577
> beacon number 0, on THU AUG 06 2009 10:56:30
> CA beacon hash entry for 129.129.104.36:5064 with period estimate
> 14.936137
> beacon number 0, on THU AUG 06 2009 10:56:36
> CA beacon hash entry for 129.129.104.37:5064 with period estimate
> 14.915017
> beacon number 26678, on THU AUG 06 2009 10:56:33
> CA beacon hash entry for 129.129.104.39:5064 with period estimate
> 14.838267
> beacon number 0, on THU AUG 06 2009 10:56:39
> CA beacon hash entry for 129.129.104.13:5064 with period estimate
> 20.991435
> beacon number 51, on THU AUG 06 2009 10:56:33
> CA beacon hash entry for 129.129.104.14:5064 with period estimate
> 14.935088
> beacon number 218331, on THU AUG 06 2009 10:56:37
> CA beacon hash entry for 129.129.104.15:5064 with period estimate
> 14.881638
> beacon number 218058, on THU AUG 06 2009 10:56:29
> CA beacon hash entry for 129.129.104.30:5064 with period estimate
> 14.953183
> CA beacon hash entry for 129.129.104.31:5064 with period estimate
> 14.925085
> beacon number 0, on THU AUG 06 2009 10:56:34
> 15.049622
> 14.849221
> 14.891577
> 14.936137
> 14.915017
> 14.838267
> 20.991435
> 14.935088
> 14.881638
> 14.953183
> 14.925085
> Timer queue:
> 11searchTimer, state = pending, delay = -20.235666
> 11searchTimer, state = pending, delay = -20.296333
> 23disconnectGovernorTimer, state = pending, delay = -16.191666
> 15tcpRecvWatchdog, state = pending, delay = 1.191668
> Receive virtual circuit watchdog at 0x7b96df0, period 30.000000
> 11searchTimer, state = pending, delay = 236.852334
> reschedule event
> Semaphore Id : 0x7bf6070
> Task Queuing : FIFO
> Pended Tasks : 0
> State : EMPTY
> VxWorks Events
> Options : N/A
> exit event
> Semaphore Id : 0x7bf6030
> Task Queuing : FIFO
> Pended Tasks : 0
> State : EMPTY
> VxWorks Events
> Options : N/A
> exitFlag = F, terminateFlag = F
> IP address to name conversion engine:
> ipAddrToAsciiEngine at 0x7bf86c0 with 0 requests pending
> mutex:
> epicsMutexId 0x7bf8650 source ../../../src/libCom/osi/epicsMutex.cpp line
> 197
> Semaphore Id : 0x7bf8680
> Pended Tasks : 0
> SEM_DELETE_SAFE
> SEM_INVERSION_SAFE
> VxWorks Events
> Options : N/A
> laborEvent:
> Semaphore Id : 0x7bf8610
> Task Queuing : FIFO
> Pended Tasks : 1
> State : EMPTY
> VxWorks Events
> Options : N/A
> Pended Tasks
> ipToAsciiProxy 7bf82c0 189 0
> exitFlag boolean = 0
> exit event:
> Default mutex:
> 197
> Pended Tasks : 5
> SEM_DELETE_SAFE
> SEM_INVERSION_SAFE
> VxWorks Events
> Options : N/A
> Pended Tasks
> scan10 7c2d530 136 0
> CAC-UDP 7be23d0 147 0
> mutex:
> 197
> Pended Tasks : 5
> SEM_DELETE_SAFE
> SEM_INVERSION_SAFE
> VxWorks Events
> Options : N/A
> Pended Tasks
> preemptive callback is enabled
> there are 0 unsatisfied IO operations blocking ca_pend_io()
> the current io sequence number is 0
> IO done event:
> Semaphore Id : 0x7ca6b70
> Task Queuing : FIFO
> Pended Tasks : 0
> State : EMPTY
> VxWorks Events
> Options : N/A
> Synchronous group identifier hash table:
> Hash table with 0 buckets and 0 items of type 4CASG installed
> value = 0 = 0x0
> X04SA-VME-ID2 >
> Jeff Hill wrote:
> > Dirk,
> > The R3.14 design is more conservative from a perspective of avoiding
> > positive congestion feedback. Here are the primary differences.
> > O When a circuit times out the CAC library disconnects the application,
> but
> > not the circuit. We rely on TCP to decide when to give up on a circuit,
> and
> > disconnect it.
> > O When the CAC library sees a beacon anomaly the search rate receives a
> > boost, but this boost is only to once every 5 seconds. In contrast,
> newly
> > created channels are initially searched for at a rate which is closer to
> the
> > average measured round trip time. The CAC library sends multiple search
> > requests per UDP frame, and depending on past success rates also
> multiple
> > UDP frames per periodic search attempt (that part isn?t different
> between
> > R3.14 and R3.15). Nevertheless, if there many channels it can take a
> little
> > while to connect all of them if the IOC (or GW in this situation has
> been
> > off for a long time).
> > O In R3.14 the CAC library never stops searching for disconnected
> channels,
> > but the maximum search rate is adjustable with an environment variable.
> >> I cannot see any search requests from that IOC.
> > That doesn?t sound right, but bear in mind that if the IOC is sending
> > unicasts, and not broadcasts, to the gateway on a switched network then
> the
> > network sniffer may or may not see them if it isn?t listening at the
> source
> > or the destination cables. Directed broadcasts may also not be seen by
> the
> > network sniffer if it isn?t sniffing directly on the directed
> broadcast's
> > destination subnet.
> > The output from dbcar when its interest level argument is set very high
> (say
> > to 100) will show many things about the internals of the CAC library.
> Also,
> > there is a timer thread created by the CAC library that is scheduling
> the
> > search requests, and you might send a stack trace (if it isn?t simply
> > waiting on its time delay event flag).
> > Another possibility is that something is amiss in the GW. Does
> restarting
> > the GW improve the situation?
> > Jeff
> >> From: [email protected] [mailto:tech-talk-
> [email protected]]
> >> On Behalf Of Dirk Zimoch
> >> Sent: Wednesday, August 05, 2009 8:09 AM
> >> To: tech-talk
> >> Subject: CA reconnection problem
> >> Hi all (Jeff in particular)
> >> I have seen a problem with some of our IOCs today. Several beamline
> IOCs
> >> running
> >> 3.14.8 have disconnected CA input links to a central IOC (3.13.10) even
> >> though
> >> the channels are there. The beamline IOCs run behind ca gateways. It
> may
> >> be that
> >> the gateways or the central IOC had been offline for more than some
> hours
> >> recently in the last shutdown.
> >> Even though the channels are back and I can read them from the beamline
> >> network
> >> with caget the IOCs don't reconnect.
> >> I have started a softioc in the beamline network to generate a beacon
> >> anomaly
> >> but even then the links do not reconnect. I cannot see any search
> requests
> >> from
> >> that IOC.
> >> Only 3.14.8 systems show this problem. 3.13. systems don't. Is there a
> bug
> >> in
> >> the 3.14.8 implementation of CAC I should know of?
> >> Dirk
> >> Dr. Dirk Zimoch
> >> Paul Scherrer Institut, WBGB/006
> >> 5232 Villigen PSI, Switzerland
> >> Phone +41 56 310 5182
> Dr. Dirk Zimoch
- CA reconnection problem Dirk Zimoch
- RE: CA reconnection problem Jeff Hill
- Re: CA reconnection problem Dirk Zimoch
Re: Linux question Guy Jennings
devIocStats - add network statistics? Allison, Stephanie
<2009>
UV cameras Dirk Zimoch
<2009>
