As an aside, if you build epics using the rpm build system this kind
of problem is handled automatically
by the package dependency resolution system.
On Aug 6, 2009, at 10:01 AM, Mark Rivers wrote:
Thanks for the online and offline replies.
My original post had an error: the older Linux system was 32-bit,
not 64-bit.
The problem was missing 32-bit libraries on the new 64-bit Fedora
Core 10 system. The error message certainly could have been
clearer than "Command not found", that's for sure!
Once I installed the following packages I was able to run 32-bit
binaries that were already built on the other Linux system, as well
as run "make" to build 32-bit linux-x86 binaries on the new 64-bit
system.
116 9:45 sudo yum install glibc-devel.i386
124 9:48 sudo yum install readline-devel.i386
127 9:49 sudo yum install ncurses-devel.i386
130 9:50 sudo yum install libstdc++-devel.i386
Sent: Thu 8/6/2009 9:31 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Linux question
Mark,
I think you need to install the i386/i686 compatibility libraries
on the
64bit Linux machine. Do you have library files (libreadline.so.5, for
example) in /usr/lib32 or /lib32?
It's probably easier to compile a separate binary for the 64bit Linux.
ZY
Mark Rivers wrote:
Folks,
This is not exactly an EPICS-specific question, but I'm having
trouble running EPICS binaries built on one recent Linux system on
another recent Linux system. It just gives a "command not found"
error, which is not very helpful. Both systems are Fedora 64-bit;
the binary is built with HOST_ARCH=linux-x86, e.g. 32-bit.
Here is an example. I am trying to run a soft IOC in the current
directly. First I run "file" and "ldd" on it, then try to run it:
[epics@localhost linux-x86]$ file ./simDetectorApp
./simDetectorApp: ELF 32-bit LSB executable, Intel 80386, version
1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux
2.6.9, not stripped
[epics@localhost linux-x86]$ ldd ./simDetectorApp
not a dynamic executable
[epics@localhost linux-x86]$ ./simDetectorApp
./simDetectorApp: Command not found.
Note that ldd says this is not a dynamic executable, which is
incorrect.
Here is the version information on the system where the binary was
built and where the executable resides:
corvette:1-5beta/ADApp/simDetectorSrc>more /proc/version
Linux version 2.6.27.21-78.2.41.fc9.i686 (mockbuild@) (gcc version
4.3.0 20080428 (Red Hat 4.3.0-8) (GCC) ) #1 SMP Mon Mar 23
23:45:58 EDT 2009
Here is the version information on the system that will not run
the binary:
[epics@localhost linux-x86]$ more /proc/version
Linux version 2.6.27.25-170.2.72.fc10.x86_64
([email protected]) (gcc version 4.3.2
20081105 (Red Hat 4.3.2-7) (GCC) ) #1 SMP Sun Jun 21 18:39:34 EDT
If I run "file" and "ldd" on the file on the system that builds it
and runs it OK I get the following:
corvette:1-5beta/bin/linux-x86>file simDetectorApp
simDetectorApp: ELF 32-bit LSB executable, Intel 80386, version 1
2.6.9, not stripped
corvette:1-5beta/bin/linux-x86>ldd simDetectorApp
linux-gate.so.1 => (0x0035b000)
libpthread.so.0 => /lib/libpthread.so.0 (0x003b3000)
libreadline.so.5 => /lib/libreadline.so.5 (0x05ac2000)
libncurses.so.5 => /lib/libncurses.so.5 (0x05f3b000)
librt.so.1 => /lib/librt.so.1 (0x004c8000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x066c5000)
libm.so.6 => /lib/libm.so.6 (0x00363000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x066b5000)
libc.so.6 => /lib/libc.so.6 (0x004d2000)
/lib/ld-linux.so.2 (0x001d8000)
libtinfo.so.5 => /lib/libtinfo.so.5 (0x05c57000)
libdl.so.2 => /lib/libdl.so.2 (0x0038e000)
corvette:1-5beta/bin/linux-x86>./simDetectorApp
Any idea what could be wrong?
- Linux question Mark Rivers
- Re: Linux question ZY (Zhijian Yin)
- RE: Linux question Mark Rivers
RE: CA reconnection problem Jeff Hill
<2009>
RE: Linux question Ernest L. Williams
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
