Thanks for the online and offline replies.
My original post had an error: the older Linux system was 32-bit, not 64-bit.
The problem was missing 32-bit libraries on the new 64-bit Fedora Core 10 system. The error message certainly could have been clearer than "Command not found", that's for sure!
Once I installed the following packages I was able to run 32-bit binaries that were already built on the other Linux system, as well as run "make" to build 32-bit linux-x86 binaries on the new 64-bit system.
116 9:45 sudo yum install glibc-devel.i386
124 9:48 sudo yum install readline-devel.i386
127 9:49 sudo yum install ncurses-devel.i386
130 9:50 sudo yum install libstdc++-devel.i386
Sent: Thu 8/6/2009 9:31 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Linux question
Mark,
I think you need to install the i386/i686 compatibility libraries on the
64bit Linux machine. Do you have library files (libreadline.so.5, for
example) in /usr/lib32 or /lib32?
It's probably easier to compile a separate binary for the 64bit Linux.
ZY
Mark Rivers wrote:
> Folks,
> This is not exactly an EPICS-specific question, but I'm having trouble running EPICS binaries built on one recent Linux system on another recent Linux system. It just gives a "command not found" error, which is not very helpful. Both systems are Fedora 64-bit; the binary is built with HOST_ARCH=linux-x86, e.g. 32-bit.
> Here is an example. I am trying to run a soft IOC in the current directly. First I run "file" and "ldd" on it, then try to run it:
> [epics@localhost linux-x86]$ file ./simDetectorApp
> ./simDetectorApp: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.9, not stripped
> [epics@localhost linux-x86]$ ldd ./simDetectorApp
> not a dynamic executable
> [epics@localhost linux-x86]$ ./simDetectorApp
> ./simDetectorApp: Command not found.
> Note that ldd says this is not a dynamic executable, which is incorrect.
> Here is the version information on the system where the binary was built and where the executable resides:
> corvette:1-5beta/ADApp/simDetectorSrc>more /proc/version
> Linux version 2.6.27.21-78.2.41.fc9.i686 (mockbuild@) (gcc version 4.3.0 20080428 (Red Hat 4.3.0-8) (GCC) ) #1 SMP Mon Mar 23 23:45:58 EDT 2009
> Here is the version information on the system that will not run the binary:
> [epics@localhost linux-x86]$ more /proc/version
> Linux version 2.6.27.25-170.2.72.fc10.x86_64 ([email protected]) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #1 SMP Sun Jun 21 18:39:34 EDT 2009
> If I run "file" and "ldd" on the file on the system that builds it and runs it OK I get the following:
> corvette:1-5beta/bin/linux-x86>file simDetectorApp
> corvette:1-5beta/bin/linux-x86>ldd simDetectorApp
> linux-gate.so.1 => (0x0035b000)
> libpthread.so.0 => /lib/libpthread.so.0 (0x003b3000)
> libreadline.so.5 => /lib/libreadline.so.5 (0x05ac2000)
> libncurses.so.5 => /lib/libncurses.so.5 (0x05f3b000)
> librt.so.1 => /lib/librt.so.1 (0x004c8000)
> libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x066c5000)
> libm.so.6 => /lib/libm.so.6 (0x00363000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x066b5000)
> libc.so.6 => /lib/libc.so.6 (0x004d2000)
> /lib/ld-linux.so.2 (0x001d8000)
> libtinfo.so.5 => /lib/libtinfo.so.5 (0x05c57000)
> libdl.so.2 => /lib/libdl.so.2 (0x0038e000)
> corvette:1-5beta/bin/linux-x86>./simDetectorApp
> Any idea what could be wrong?
> Thanks,
> Mark
- Re: Linux question Guy Jennings
- Linux question Mark Rivers
- Re: Linux question ZY (Zhijian Yin)
RE: Linux question Ernest L. Williams
<2009>
<2009>
