Mark,
I think you need to install the i386/i686 compatibility libraries on the
64bit Linux machine. Do you have library files (libreadline.so.5, for
example) in /usr/lib32 or /lib32?
It's probably easier to compile a separate binary for the 64bit Linux.
ZY
Mark Rivers wrote:
Folks,
This is not exactly an EPICS-specific question, but I'm having trouble running EPICS binaries built on one recent Linux system on another recent Linux system. It just gives a "command not found" error, which is not very helpful. Both systems are Fedora 64-bit; the binary is built with HOST_ARCH=linux-x86, e.g. 32-bit.
Here is an example. I am trying to run a soft IOC in the current directly. First I run "file" and "ldd" on it, then try to run it:
[epics@localhost linux-x86]$ file ./simDetectorApp
./simDetectorApp: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.9, not stripped
[epics@localhost linux-x86]$ ldd ./simDetectorApp
not a dynamic executable
[epics@localhost linux-x86]$ ./simDetectorApp
./simDetectorApp: Command not found.
Note that ldd says this is not a dynamic executable, which is incorrect.
Here is the version information on the system where the binary was built and where the executable resides:
corvette:1-5beta/ADApp/simDetectorSrc>more /proc/version
Linux version 2.6.27.21-78.2.41.fc9.i686 (mockbuild@) (gcc version 4.3.0 20080428 (Red Hat 4.3.0-8) (GCC) ) #1 SMP Mon Mar 23 23:45:58 EDT 2009
Here is the version information on the system that will not run the binary:
[epics@localhost linux-x86]$ more /proc/version
Linux version 2.6.27.25-170.2.72.fc10.x86_64 ([email protected]) (gcc version 4.3.2 20081105 (Red Hat 4.3.2-7) (GCC) ) #1 SMP Sun Jun 21 18:39:34 EDT 2009
If I run "file" and "ldd" on the file on the system that builds it and runs it OK I get the following:
corvette:1-5beta/bin/linux-x86>file simDetectorApp
corvette:1-5beta/bin/linux-x86>ldd simDetectorApp
linux-gate.so.1 => (0x0035b000)
libpthread.so.0 => /lib/libpthread.so.0 (0x003b3000)
libreadline.so.5 => /lib/libreadline.so.5 (0x05ac2000)
libncurses.so.5 => /lib/libncurses.so.5 (0x05f3b000)
librt.so.1 => /lib/librt.so.1 (0x004c8000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x066c5000)
libm.so.6 => /lib/libm.so.6 (0x00363000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x066b5000)
libc.so.6 => /lib/libc.so.6 (0x004d2000)
/lib/ld-linux.so.2 (0x001d8000)
libtinfo.so.5 => /lib/libtinfo.so.5 (0x05c57000)
libdl.so.2 => /lib/libdl.so.2 (0x0038e000)
corvette:1-5beta/bin/linux-x86>./simDetectorApp
Any idea what could be wrong?
- RE: Linux question Mark Rivers
- Linux question Mark Rivers
RE: Linux question Ernest L. Williams
<2009>
<2009>
