1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CA reconnection problem
To: tech-talk <[email protected]>
Date: Wed, 05 Aug 2009 16:08:35 +0200
Hi all (Jeff in particular)
I have seen a problem with some of our IOCs today. Several beamline IOCs running 3.14.8 have disconnected CA input links to a central IOC (3.13.10) even though the channels are there. The beamline IOCs run behind ca gateways. It may be that the gateways or the central IOC had been offline for more than some hours recently in the last shutdown.
Even though the channels are back and I can read them from the beamline network with caget the IOCs don't reconnect.
I have started a softioc in the beamline network to generate a beacon anomaly but even then the links do not reconnect. I cannot see any search requests from that IOC.
Only 3.14.8 systems show this problem. 3.13. systems don't. Is there a bug in the 3.14.8 implementation of CAC I should know of?
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: CA reconnection problem Jeff Hill
Prev: RE: CAJ questions Mark Rivers
Next: UV cameras Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Parker 9000 Ron Sluiter
Next: RE: CA reconnection problem Jeff Hill
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
