I'm running 3.14.10 with v2.9.2 Channel Archiver on linux Centos.
I'm reading some environmental variables (temperatures, humidity,
etc.) at the rate of once per hour. However, though the archiver does
not stop running, when I look at the output with ArchiveExport, I never
see more than a hand full of readings. (I've not gotten the viewer
operational yet, so it may be a problem in how I'm using ArchiveExport).
Has anyone seen this before? Any suggestions as to how I might
log slowly? Might I not be setting the global variables in my engineconfig
file correctly?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Re: Escaped strings from fullPathName.pl Andrew Johnson
EDM: Text Monitor Widget Szalata, Zenon M.
<2009>
Re: IOC crash when asyn traceflow turned on Eric Norum
<2009>
