I would like to try to implement the following pseudo code as a device
support function for a motor. Basically, when called, it turns the motor
on, checks to see if the motor was on, tells the motor to move to a
position, waits for it to finish or time out, turns the motor off,
checks to see if the motor is off, then checks to see if the current
position is the one that was requested. The functions that it calls will
be provided by driver support. The question I have is that I want it to
immediately start moving to a new position if a new value is entered in
the associated ao record field, even if the motor is already in motion.
Is it possible to check for changes in the value field of the record
from this function? Do I need to start this function as a new thread,
set PACT to true, and then set it to false at the end of the thread? How
would the thread pick up on the fact that the record value field has
changed?
Another question I have is, that in driver support, in the init
function, I will open up a socket connection and spawn a thread which
constantly polls the motor for its status, ie current position,
trajectory mode, motion done, etc. This data will be written to a
structure which is available to the device support. However, when device
support calls other driver support functions which communicate with the
motor over the same socket connection, how do I ensure that these don't
collide with the functions that are constantly polling?
Thank you,
Patrick
request_move_to_absolute_position( record val field )
motor_on();
if (read_motor_on != true)
print error;
return;
move_to_absolute_position( record val field );
while ( (motion_done_status != true) and (timeout != true) ) {
if ( record val field changes ) {
reset timeout;
motor_off();
if (read_motor_off != true)
print error;
if (read_actual_position() != record val field) {
print error;
return;
- RE: checking for change in value in device support function Mark Rivers
EDM symbols GOURNAY Jean-Francois
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
