1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Stream Device I/O Intr bugs, ongoing
To: Michael Abbott <[email protected]>
Date: Thu, 23 Jul 2009 13:54:15 +0200
Hi Michael,
There have always been issues with "I/O Intr" mode but I thought that version 2 is more stable than version 1. Unfortunately asynDriver does not natively support unsolicited messages from a device -- at least not without blocking the port for all other users. Thus I have to poll frequently for new messages. This makes the code quite hard to debug. (Messages during polling would flood the screen and change the timing behavior of the system.)
Changing SCAN from "I/O Intr" to anything else aborts the currently running protocol. Going back to "I/O Intr" restarts the protocol. Thus I guess the record is waiting for a reaction (data or timeout) and sees neither. The driver _should_ restart a timer in that case and try again later. It seems this does not happen. It may be a race condition somewhere in the code (e.g. between timeout and incoming data). That would explain the rare occurrence.
At the moment, I do not have much time but I will have a look at the problem in August.
Dirk
Michael Abbott wrote:
Dear Dirk,
I'm sorry this isn't a more helpful report, but I'm continuing to see problems with stream Device version 2 (my latest test was with version 2.4, I believe) with I/O Intr records.
For a long time (a couple of years, I think) my IOCs would see crashes when using stream Device v2 on my configuration (which I'll describe in a moment), so I'm currently running them with stream Device v1 (ported to 3.14). There were some bug fixes in the last year which seem to have removed the crashes (I think there was some stack overflow). I believe you've been in communication with some of my colleagues on this.
Unfortunately, in my latest test with v2, I see the following behaviour: records with I/O Intr processing will suddenly stop processing. This is *very* rare, on around thirty IOCs I saw this occur twice in a fortnight. Curiously, if the .SCAN field is changed to Passive and back to I/O Intr then processing resumes normally!
My IOCs are configured with Hytec 8516 RS-485 cards connected to CMS ION radiation monitors which send long packets with many fields to decode. A packet is automatically sent every second, and one record is configured with SCAN="I/O Intr", and processes the remaining 14 fields contained in the record. I'm using asyn version 4-10 (and a fair number of other components on each IOC).
It's a difficult bug to track down, as it seems almost unreproducible, but alas it occurs often enough that I can't run v2 on my IOCs. I know that some of my colleagues also see intermittent I/O Intr related issues, but I don't have details.
I wish I could be more helpful!
	Michael Abbott
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Stream Device I/O Intr bugs, ongoing Michael Abbott
Prev: Waveform record updating problem Prachi Chitnis
Next: --more-- Waveform record updating problem Prachi Chitnis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Stream Device I/O Intr bugs, ongoing Michael Abbott
Next: Waveform record updating problem Prachi Chitnis
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
