The newest version of LabVIEW (2009, due out next month) supposedly has full support for CA through the use of their "EPICS I/O Server" which will load an EPIC .db file and create a new set variables. These can then be tied directly into LabVIEW shared variables which are extremely easy to use.
This architecture has actually been available in LV applications running on a PC for a couple of versions (I think). I'm pretty good at LV (but really bad in EPICS) and have successfully created this reasonably direct connection with LV version 8.6 and EPICS 3.14.
LabVIEW 2009 supposedly now supports the same thing on Real-Time controllers. I am (this week) attempting to run an advance LV 2009 copy in the manner described. I will be very happy if this works...
Cheers,
-Jeff
On 7/20/09, Wesley Moore <[email protected]> wrote:
tech-talkers,
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
