Hi again Christof,
I did not read your mail properly. You don't use the serial port of your
computer but the USB port, right?
I assume the USB device registers itself as a "serial interface" like a
USB/RS232 interface? So a /dev/tty... (probably /dev/ttyUSB0) appears in your
system? If so try to set the baudrate from the Linux command line:
stty -F /dev/ttyUSB0 921600
If that works, it should be possible to start the ioc afterwards. If not, the
driver for that device does not support this baudrate.
Dirk
Christof Motzko wrote:
I am trying to communicate with the I-7565 USB/CAN Converter with
StreamDevice, which can be used as local serial device. A baud rate of
921600 is necessary for the Converter, but I can't configure asyn to
this baud rate. Can anybody tell me how I can change the baud rate to
921600?
Thanks
Christof
Christof Motzko
Institut f. Experimentalphysik I
Ruhr-Universitaet-Bochum
Universitaetsstr. 150
D-44780 Bochum
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- How to change baudrate to 921600 in asyn? Christof Motzko
Re: cainfo does display host info Ernest L. Williams Jr.
Re: cainfo does display host info Dirk Zimoch
<2009>
Re: How to change baudrate to 921600 in asyn? Dirk Zimoch
cainfo does display host info Carl Schumann
<2009>
