Hi Emmanuel,
We use the same solution. Our selection went to yorick that allows
processing the data and comes with a very fast graphics package. That
let us handle the rate we get out of our server (~22kB/frame at 30+ fps)
here's a link to yorick:
http://yorick.sourceforge.net
Matthieu
On 07/17/09 14:56, Mark Rivers wrote:
Hi Emmanuel,
For my new EPICS areaDetector software the video stream is delivered via
an EPICS waveform record. There are several other records that describe
the frame size, data type, color mode, etc.
I've written a plugin for the ImageJ open-source Java application that
displays this video stream. ImageJ has lots of nice features, like the
pseudocolor you are asking about. It also has dynamic line profiles,
showing the intensity of a line cut through the image data that updates
in real time, the ability to capture frames into a 3-D buffer for
playback as a movie or stills, etc.
The EPICS + ImageJ solution can display more than 50 frames/sec at
640x480 resolution.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Emmanuel Mayssat
Sent: Friday, July 17, 2009 1:51 PM
To: epics
Subject: pseudo coloring of video stream
All,
This is not directly related to epics, but rather to operations of
control system.
We are using a video stream of 640x480 black and white.
Operators are interested in the intensity of each pixel. This
information is used for diagnostics.
The human eye being more sensitive to colors than to shade of gray, I
would like to implement a pseudo coloring algorithm. That is filter the
video feed (real time) and map pixel depth to a color table.
Is anyone using this?
(very common for laser commissioning I was told)
If so, let's talk!
Emmanuel Mayssat
650/793-0626
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- RE: pseudo coloring of video stream Cobb, TM (Tom)
- pseudo coloring of video stream Emmanuel Mayssat
- RE: pseudo coloring of video stream Mark Rivers
GE Fanuc David Dudley
Re: GE Fanuc David Dudley
<2009>
<2009>
