1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: uptodate version of modtcp?
To: "Burkhard Kolb" <[email protected]>, <[email protected]>
Date: Wed, 15 Jul 2009 08:35:08 -0500
I have an EPICS module called "modbus".  It uses asyn, and works on all supported EPICS architectures (Linux, Windows, vxWorks, etc.).  It supports TCP, serial RTU, and serial ASCII.  It has been tested on a variety of Modbus devices, but probably not WAGO.   Are you using a WAGO?  I looked at the NSLS WAGO support when I was writing my package, and I recall that there was something strange about the way WAGO treated addresses.  I didn't have a WAGO to test, so the driver may need a small addition to work on WAGO.
Here is the link:
http://cars.uchicago.edu/software/epics/modbus.html
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Burkhard Kolb
Sent: Wednesday, July 15, 2009 8:27 AM
To: '[email protected]'
Subject: uptodate version of modtcp?
I saw the modtcp with WAGO support version for use on linux at NSLS.
Is this the latest version? Is there a version for the
current epics build system?
I downloaded this version and tried by fiddling with the Makefiles,
RELEASE and CONFIG files and ended up with compile errors:
/usr/bin/cc -c               -DUNIX  -Ddarwin   -ansi   -O3 -g   -Wall
        -fno-common  -I. -I../O.Common -I. -I..
-I../../../include/os/Darwin -I../../../include
-I/epics/base-3.14.10/../modules/sncseq-2.0.12/include
-I/epics/base-3.14.10/include/os/Darwin -I/epics/base-3.14.10/include
    -I/opt/local/include -I/sw/include   ../modtcpLib.c
In file included from ../modtcpLib.c:81:
../modtcp.h:7:23: error: asm/errno.h: No such file or directory
../modtcp.h:72: error: syntax error before 'UINT8'
../modtcp.h:72: warning: no semicolon at end of struct or union
../modtcp.h:73: warning: type defaults to 'int' in declaration of 'func'
../modtcp.h:73: warning: data definition has no type or storage class
../modtcp.h:74: error: syntax error before 'data'
Dr. Burkhard Kolb
HADES
E-Mail: [email protected]
Tel: +49-(6159)-71-2667 / Fax: +49-(6159)-71-2155
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker, Christiane Neumann
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
uptodate version of modtcp? Burkhard Kolb
Prev: uptodate version of modtcp? Burkhard Kolb
Next: Re: CAEN SY127 and SY527 Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: uptodate version of modtcp? Mark Rivers
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
