1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Agilent E2050
To: [email protected]
Date: Tue, 14 Jul 2009 19:31:56 +0200
On Dienstag, 14. Juli 2009, Szalata, Zenon M. wrote:
> I am running a test soft IOC, which performs a few simple functions on a
> GPIB instrument.  The instrument is connected to Agilent E2050 gateway.
> The IOC is periodically reading the Status Byte.  After a few hours the
> communication between the IOC and the device is broken.  This is what I
> get:
> 02009/07/14 08:50:24.312 L0 vxi11 clientIoCall errno Connection reset by
> peer clnt_stat 4 2009/07/14 08:50:24.312 L0 vxiDestroyDevLink RPC error :
> RPC: Unable to send; errno = Broken pipe
> 2009/07/14 08:50:24.312 L0 vxiDisconnectPort : RPC: Unable to send; errno
> = Broken pipe
> 2009/07/14 08:50:26.314 L0 vxiDestroyDevLink RPC error : RPC: Unable to
> L0 port not connected
> 2009/07/14 08:50:26.314 L0 asynGpib:pollAddr srqEnable
> 2009/07/14 08:50:26.314 MAGS:ASYN:IO: Write error, nout=0, L0 RPC failed
> 2009/07/14 08:50:26.314 L0 port not connected
> 2009/07/14 08:50:26.314 MAGS:ASYN:IO: Error L0 port is not connected
> 2009/07/14 08:50:26.314 MAGS:ASYN:IO: error  nread 162331380 L0 port is
> not connected
> 2009/07/14 08:50:26.314 MAGS:ASYN:IO: Overflow nread 162331380 L0 port is
> not connected --------------------
> I have two E2050 devices and both exhibits the same behavior.  The length
> of time until the communication falls apart varies.  It could be as short
> as an hour or so, or as long as 10 hours.
> Here is the E2050 configuration:
> Configuration Parameters
>   hostname:        E2050-esalangpib2 # Internet domain name
>   hardware-addr:   0800091B1EEB    # Ethernet station address
>   ip:              134.79.59.12    # Internet Protocol address
>   default-gw:      134.79.59.1     # Default subnet gateway IP address
>   subnet-mask:     255.255.252.0   # Network subnet mask
>   syslog-svr:      0.0.0.0         # Syslog server IP address
>   bootp:           OFF             # Obtain config via BOOTP/TFTP
>   lan-timeout:     0               # LAN connect timeout in seconds
>   io-timeout:      120             # Server I/O timeout in seconds
>   allow:           *               # IP allow list
>   hpib-address:    0               # HP-IB System Controller Address
>   hpib-name:       gpib0           # HP-IB interface symbolic name
>   hpib-unit:       7               # HP-IB logical unit number
> Is this problem due to improper use of the gateway or are these devices
> malfunctioning?
Since you get "Connection reset by peer" error, I bet this is either a bug
in the E2050 firmware or a network problem (or both). Try to update the
firmware. If that doesn't help or it is already the newest version, try to
analyse the network traffic, especially between IOC and gateway. Sometimes
devices have problems with auto-negotiation of low-level ethernet protocol
(10 or 100 Mbit/s, half or full duplex). If there are conspiciously many
erroneous packages you might want to experiment with fixed settings, such
as 100 Mbit/half duplex.
Just my 2 cents.
Cheers
Ben
Agilent E2050 Szalata, Zenon M.
Prev: RE: When an external device does not provide termination on TCP ASCIIstream replies Mark Rivers
Next: Re: DB CA link to PROC field Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Agilent E2050 Szalata, Zenon M.
Next: When an external device does not provide termination on TCP ASCII stream replies Allison, Stephanie
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
