On Monday 13 July 2009 13:24:27 Dr. Peter Zumbruch wrote:
> I have the following problem (EPICS 3.14.10 / Debian 4.0)
> with this tiny database (minimized to my problem) .
> Why don't I see the Value/Raw Value of "HAD:RPC:S1:M0:C9:ToTL" at the
> input D of the sub record "HAD:RPC:S1:M0:C9:stToTL", which I try to
> access at c-code.
There is a known bug in the subRecord that comes with R3.14.10 which is
documented on the Known Problems page for that release along with a patch to
fix it. Your symptoms sound fairly similar to what I remember seeing, so
hopefully the patch will fix it (it's the 3rd item from the end):
http://www.aps.anl.gov/epics/base/R3-14/10-docs/KnownProblems.html
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- sub routine record doesn't get value via INPD Dr. Peter Zumbruch
Re: sub routine record doesn't get value via INPD Matthieu Bec
Re: DB CA link to PROC field Benjamin Franksen
<2009>
<2009>
