1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: sub routine record doesn't get value via INPD
To: "Dr. Peter Zumbruch" <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Tue, 14 Jul 2009 00:35:22 +0100 (BST)
Hi Peter,
The "dbpf HAD:RPC:S1:M0:C9:ToTL 200" is putting 200 into
the VAL field of the AO record: "HAD:RPC:S1:M0:C9:ToTL"
rather than the RVAL field. Thus, the RVAL field remains at 0.0.
The OUT link from the AO record gets processed as a result of
writing to the AO record:
field(OUT, "HAD:RPC:S1:M0:C9:stToTL")
This link causes the "200" to be placed in the VAL field of
the sub record: "HAD:RPC:S1:M0:C9:stToTL".
The sub record INPD field is looking at the RVAL field of
the AO field which is still at 0.0.
Cheers,
Andy
On Mon, 13 Jul 2009, Dr. Peter Zumbruch wrote:
> Hi all,
> I have the following problem (EPICS 3.14.10 / Debian 4.0)
> with this tiny database (minimized to my problem) .
> Why don't I see the Value/Raw Value of "HAD:RPC:S1:M0:C9:ToTL" at the
> input D of the sub record "HAD:RPC:S1:M0:C9:stToTL", which I try to
> access at c-code.
> 1) The ingredients:
> > record(ao, HAD:RPC:S1:M0:C9:ToTL) {
> >   field(DESC, "0 0 0 2")
> >   field(DTYP, "Raw Soft Channel")
> >   field(FLNK, "HAD:RPC:S1:M0:C9:stToTL")
> >   field(EOFF, "0")
> >   field(LOPR, "0")
> >   field(HOPR, "199")
> >   field(DRVH, "250")
> >   field(DRVL, "0")
> >   field(LINR, "LINEAR")
> >   field(OMSL, "supervisory")
> > record(sub, HAD:RPC:S1:M0:C9:stToTL) {
> >   field(DESC, "store 0 0 0 2")
> >   field(INAM, "mySubInit")
> >   field(SNAM, "myStoreFcn")
> >   field(INPA, "0")
> >   field(INPB, "0")
> >   field(INPC, "2")
> >   field(INPD, "HAD:RPC:S1:M0:C9:ToTL.RVAL")
> >   field(INPE, "0")
> The referenced C-Code:
> > static long myStoreFcn(subRecord *precord)
> >   short thr;
> >   thr = precord->d;
> >   printf( "Record %s called myStoreFcn(%p), thr %d, precord->d %f\n",
> >            precord->name, (void*) precord, thr, precord->d);
> >   return(0);
> > epicsRegisterFunction(myStoreFcn);
> 2.) The test: (caput / dbpf)
> > epics> dbgf HAD:RPC:S1:M0:C9:ToTL
> > DBR_DOUBLE:         0
> > epics> dbpf HAD:RPC:S1:M0:C9:ToTL 200
> > Record HAD:RPC:S1:M0:C9:stToTL called myStoreFcn(0x80577b0), thr 0,
> > precord->d 0.000000
> > DBR_DOUBLE:         200
> > epics>dbpr HAD:RPC:S1:M0:C9:stToTL
> > A: 0                ASG:                B: 0                C: 2
> > D: 0                DESC: store 0 0 0 2 DISA: 0             DISP: 0
> > DISV: 1             E: 0                F: 0                G: 0
> > H: 0                I: 0                J: 0                K: 0
> > L: 0                NAME: HAD:RPC:S1:M0:C9:stToTL           SEVR: NO_ALARM
> > STAT: NO_ALARM      TPRO: 0             VAL: 200
> 3. ) The (stupid) question: Why don't I get the value of
> HAD:RPC:S1:M0:C9:ToTL at D? At VAL I see it.
> Thanks  for any explanation.
> Peter
>  Dr. rer. nat. Peter W. Zumbruch
>  EE - department / Controls group / GSI
>  E-Mail: P.Zumbruch_at_gsi.de
>  Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
>  GSI Helmholtzzentrum für Schwerionenforschung GmbH
>  Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
>  Gesellschaft mit beschränkter Haftung
>  Sitz der Gesellschaft: Darmstadt
>  Handelsregister: Amtsgericht Darmstadt, HRB 1528
>  Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
>  Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
>  Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
RE: sub routine record doesn't get value via INPD Allison, Stephanie
sub routine record doesn't get value via INPD Dr. Peter Zumbruch
Prev: Re: sub routine record doesn't get value via INPD Maren Purves
Next: RE: sub routine record doesn't get value via INPD Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
