1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: reading with the asyn record
To: [email protected]
Date: Mon, 29 Jun 2009 21:27:28 -0700
Two questions:
1) Does the asyn record block when reading until the requested amount of bytes (NRRD) is available in the serial fifo buffer, or does it only block until 1 byte is available (like the c read function), or not at all?
2) Is there a way to check that it has gotten all the requested bytes into the record before doing a caget on the BINP field to retrieve them?
Thank you for your time,
Patrick
Re: reading with the asyn record Eric Norum
Prev: Re: choosing snmp version Euan Troup
Next: RE: choosing snmp version Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: choosing snmp version Rees, NP (Nick)
Next: Re: reading with the asyn record Eric Norum
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
