Hello,
I am considering the Channel Access Portable Server for supporting the
C++ middle layer servers.
The associated PVs will maintain one-dimensional arrays of characters.
Their lengths can be
significant. So, passing by pointer in read/write methods would
be a preferable way. The ‘write’ case
looks straightforward (as described in the tutorial, p.35):
class my PV : public casPV {
gdd* pValue;
caStatus myPV::write(const casCtx& ctx, gdd &value){
pValue->unreference();
pValue = &value;
pValue->reference();
The ‘read’ case looks trickier (Probably, because it is not
explained).
In short, CORBA addresses such case by using the additional wrappers, e.g.
gdd_var objects,
in the ‘read’ method. However, the signature of this method
is already defined by the basis
class casPV. Fortunately, it seems we can still use the gdd-based
approach using another
mechanism, the pv-associated destructor, e.g. myPVReadDestructor:
caStatus myPV::read(const casCtx& ctx, gdd &value){
value.putRef(pValue->dataPointer(), new myPVReadDestructor(pValue));
where :
myPVReadDestructor::run(…){
Any comments and suggestions about a better solution.
Thank you,
Nikolay
