Hi Liu,
you create it along your build of vxWorks image.
gmake bootrom I think, but check their documentation.
Matthieu
On 06/25/09 04:19, liuping wrote:
> Hi all,
> Thank you for your reply! The problem was done.
> One guy gave me a bootrom.bin file, and I flash it into mvme5500 Boot
> Rom. Finally the hytec8401 works well. But really I don’t know the
> secret of bootrom.bin file.
> Best regards,
> LIU Ping
> *From:* [email protected]
> [mailto:[email protected]]
> *Send:* 2009.6.16日 11:40
> *to:* [email protected]
> *subject:* "A32 RegisterAddress error" about Hytec8401
> Hi,
> As a fresh man, I need your help. The hardware is Hytec8002 and
> hytec8401. Hytec8401ip driver came from Diamond website. I made my own
> application project with EPICS V3.14.8.2 and VxWorks V5.5.1. The codes
> compiling is no error but some warnings. When downloaded to
> VME(mvme5500), there are some error message as below:
> ## Load record instances
> dbLoadRecords("db/8401.db")
> value = 0 = 0x0
> # slot int options
> IPCAC6 = ipacEXTAddCarrier(&EXTHy8002, "6 2 10")
> Id: drvHy8002.c,v 1.10 2001/11/20 12:21:42 wscott Exp
> 8002 initialise 6 2 10
> PROM manufacturer ID: 0x8003 (HyTec Electronics Ltd., Reading, UK)
> PROM model #: 0x8002, board rev. 0x03
> PROM Xilinx rev.: 0x03, 0x00, 0x07
> PROM Serial #: 0x00 0x00 0x00 0x00 0x05 0xce
> drvHy8002filename="../.: A32 RegisterAddress error
> (status=./..34144267/src/libCom/)osi/devLib.c" line vmeslot number=282
> 6, ipslot unable to m0ap address VME A32 at address
> base=0X11800000800000 size =
> 0X100000
> 0xIP memo1ef31290ry register (error!
> tShell): drvHy8002ipacAddCarrie: Cannot register A32 device at r:
> 1800000Hytec VICB8002. Error is driver retur209000bned an error.
> new symbol "IPCAC6" added to symbol table.
> IPCAC6 = 0x1ee87ff0: value = -1 = 0xffffffff
> #-------- 8401 (Analogue
> Input)------------------------------------------------
> # card, slot, ipsl, intl, inte, aity, clks, clkr, inhi, samp, spac, trig
> Hy8401ipConfigure ( 60, IPCAC6, A, 0, 0, 0, 0, 15, 0, 1, 1, 0)
> $Id: drvHy8401ip.c,v 1.8 2005/10/27 09:07:01 mga83 Exp $
> Hy8401ipConfigure: card 60, VME slot -1, IP slot 0,
> vector 0, itr state 0, ai type 0,
> clock src 0, clock rate 15, inhibit 0,
> samples 1, spacing 1, trigger 0
> value = 0 = 0x0
> shellPromptSet "1054-Test> "
> value = 2178076 = 0x213c1c = shellHistSize + 0x4
> iocInit()
> Starting iocInit
> ### EPICS IOC CORE built on Jul 16 2008
> ### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
> ***drvIpac version extended for Hot Swap
> ***$Id: drvIpac.c,v 1.3 2004/05/17 10:57:14 pho Exp $
> SPAWNING HOTSWAP SCAN TASK
> 0x1ef31290 (tShell): drvHy8401ip: Cannot register Hy8401ip A16
> device.iocInit: All initialization complete
> value = 0 = 0x0
> Done executing startup script
> /home/blctrl/hytec_ADC/iocBoot/iocHy8401ADC/st.cmd
> 1054-Test>
> I check out the error “A32 RegisterAddress error” come from the line 667
> of drvHy8002.c file
> How to correct? Thanks a lot!
> LIU Ping
> Beamline Control Group
> Shanghai Synchrotron Radiation Facility
> Shanghai Institute of Applied Physics
> Chinese Academy of Sciences
> Zhangheng Rd 239,Pudong Dist.,
> Shanghai 201204
> China
> Tel:+86-21-33933237
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- re: "A32 RegisterAddress error" about Hytec8401 liuping
Re: Troubles building jca.jar J. Lewis Muir
<2009>
Controlling multiple CAN busses Elliott Wolin
<2009>
