LIU Ping,
We use a lot of Hytec on our 5500's and have the fololowing changes in mv5500A.h and config.h:
#define VME_A32_MSTR_BUS 0x00800000 /* This is in mv5500A.h */
#define VME_A32_MSTR_BUS 0x00800000 /* This is in config.h */
I hope this helps
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of liuping
> Sent: 22 June 2009 04:42
> To: [email protected]
> Subject: re: "A32 RegisterAddress error" about Hytec8401
> Yes, it is the first time to use a card that responds in the
> VME A32 space
> for me. My VME CPU is mvme5500. I find out some information about
> VME_A32_MSTR_BUS and VME_A32_MSTR_SIZE in the files config.h
> and mv5500A.h .
> The information showed below was taken from mv5500A.h:
> /* VME A32 outbound (master) - note ...MSTR_SIZE defined in
> "config.h" */
> #define VME_A32_MSTR_LOCAL ((VME_A24_MSTR_LOCAL -
> VME_A32_MSTR_SIZE)
> &\ 0xfff00000)
> #define VME_A32_MSTR_BUS 0x08000000
> /* VME A32 Inbound (slave) mapping for node 0 only - maps all
> of DRAM */
> #define VME_A32_SLV_BUS VME_A32_MSTR_BUS
> #define VME_A32_SLV_LOCAL LOCAL_MEM_LOCAL_ADRS
> #define VME_A32_SLV_SIZE (((ULONG)sysPhysMemTop()) -
> (LOCAL_MEM_LOCAL_ADRS))
> #define VME_MEM_LOCAL_START VME_A32_MSTR_LOCAL
> #define VME_MEM_LOCAL_SIZE (VME_MEM_LOCAL_END -
> VME_MEM_LOCAL_START)
> The information showed below was taken from config.h:
> /** VME Memory Mapping size Definitions - note: See "mv5500A.h" for
> commentary
> * regarding PCI-VME and VME-PCI mappings. */
> #define VME_A32_MSTR_SIZE 0x08000000 /* 128 MB */
> #define VME_A24_MSTR_SIZE 0x01000000 /* 16 MB */
> #define VME_A16_MSTR_SIZE 0x00010000 /* 64k */
> Is there anything wrong?
> By the way, without the experience of building vxWorks,
> setting up EPICS
> base and writing any device' driver, how can I do deeply to
> understand the
> working mechanism of EPICS? My biggest aim is to learn how to
> write driver
> codes for new hardware, even I know it is a very difficult road for a
> beginner.
> Best wishes,
> LIU Ping
> From: Andrew Johnson [mailto:[email protected]]
> Send: 2009年6月16日 22:28
> to: [email protected]
> to: Michael Abbott; liuping
> subject: Re: "A32 RegisterAddress error" about Hytec8401
> Hi Liu Ping,
> On Tuesday 16 June 2009 03:39:57 Michael Abbott wrote:
> > However, the problem is nothing to do with the 8401...
> I agree with Michael, this is not a problem with the 8401
> driver and it may
> not be one with the 8002 driver either.
> Is this the first time you have tried to use a card that
> responds in the VME
> A32 space? If so I would guess that the problem is that your
> vxWorks BSP
> needs to be configured to map the relevent portion of VME A32
> space into the
> CPU's memory map. The error message is occurring because the
> driver is
> asking the vxWorks BSP to give it the CPU address corresponding to a
> particular VME A32 address, but the BSP is replying that
> there is no such
> CPU
> address because the BSP is not configuring the VME Bridge
> chip with any A32
> Master windows that cover that range.
> Read the target.txt file in your target/config/<bsp>
> directory, it should
> document the window mappings. Look for the VME_A32_MSTR_BUS and
> VME_A32_MSTR_SIZE variables; you may be able to just modify
> them and rebuild
> the BSP, but don't just make the window as large as possible
> because that
> can
> significantly slow down the startup of the vxWorks image at
> boot time and
> also use up memory in MMU page tables.
> I can't give you any specific advice because I don't know
> what VME CPU board
> you are using, and I only know about a limited number of BSPs anyway.
> - Andrew
> The best FOSS code is written to be read by other humans --
> Harold Welte
Scanned by iCritical.
- Re: "A32 RegisterAddress error" about Hytec8401 Andrew Johnson
- re: "A32 RegisterAddress error" about Hytec8401 liuping
RE: MVME 5500 GOURNAY Jean-Francois
<2009>
<2009>
