The "multiple servers" response also happens when using VirtualBox to
run virtual guest operating systems (such as Linux within a WindowsXP
host like my laptop). The guest host is on the 10.0.x.x subnet.
VirtualBox sets up a "VirtualBox Host-Only Network" network connection.
Disable that connection and close VirtualBox to remove that problem, if
it presents itself.
Kay's solution might be an alternative resolution and I'll try it soon.
-- Pete
Kasemir, Kay wrote:
Hi:
Could it be that 10.30.53.51 localhost.localdomain is the
same computer?
I've seen cases on laptops, trying to access a soft IOC on the
same laptop, where I got multiple responses for the "real" IP
as well as 127.0.0.1.
The workaround was to set EPICS_CA_ADDR_LIST=127.0.0.1,
EPICS_CA_AUTO_ADDR_LIST=NO.
Kay
On 6/19/09 12:44 , "Dayle Kotturi" <[email protected]> wrote:
You have the PV loaded onto (at least) two nodes on the subnet
(or list of IP addresses in your EPICS_CA_ADDR_LIST) that edm is using.
Edm is behaving as it should, it's just getting two replies fo the
PV "X15U1:EH:DXP:Z".
This can also happen if you have a gateway and edm can "see" both the
source IOC's PV and the gateway's copy.
Warning: "Identical process variable names on multiple servers"
Context: "Channel: "X15U1:EH:DXP:Z.BUSY", Connecting to:
10.30.53.51:5064, Ignored: localhost.localdomain:5064"
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
- Re: A problem about edm Kasemir, Kay
答复: A problem about edm 汪启胜
<2009>
Re: A problem about edm ??
<2009>
