1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: A problem about edm
To: Tech-talk <[email protected]>
Date: Fri, 19 Jun 2009 12:54:12 -0400
Hi:
Could it be that 10.30.53.51 localhost.localdomain is the
same computer?
I've seen cases on laptops, trying to access a soft IOC on the
same laptop, where I got multiple responses for the "real" IP
as well as 127.0.0.1.
The workaround was to set EPICS_CA_ADDR_LIST=127.0.0.1,
EPICS_CA_AUTO_ADDR_LIST=NO.
Kay
On 6/19/09 12:44 , "Dayle Kotturi" <[email protected]> wrote:
> You have the PV loaded onto (at least) two nodes on the subnet
> (or list of IP addresses in your EPICS_CA_ADDR_LIST) that edm is using.
> Edm is behaving as it should, it's just getting two replies fo the
> PV "X15U1:EH:DXP:Z".
> This can also happen if you have a gateway and edm can "see" both the
> source IOC's PV and the gateway's copy.
>>     Warning: "Identical process variable names on multiple servers"
>>     Context: "Channel: "X15U1:EH:DXP:Z.BUSY", Connecting to:
>> 10.30.53.51:5064, Ignored: localhost.localdomain:5064"
Re: A problem about edm Pete Jemian
Re: A problem about edm ??
Re: A problem about edm Dayle Kotturi
Prev: Re: A problem about edm Dayle Kotturi
Next: Re: A problem about edm Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
