1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Epics extension problems
To: <[email protected]>
Date: Fri, 19 Jun 2009 11:18:09 -0400
When you installed cygwin, did you install motif (that's the Xm library)?
Make sure the Xm library can be found
David
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Pacios Rodriguez Luis Orlando
Sent: Friday, June 19, 2009 10:34 AM
To: [email protected]
Subject: Epics extension problems
In preparation for building EPICS extensions on my gygwin-x86 machine, I
am
trying to install probe first. I have followed step by step the
instructions.
I had the following error messages:
==== here starts the make output for cygwin-x86 ===
gcc -c   -D_POSIX_THREADS -D_POSIX_TIMERS            -DUNIX  -DCYGWIN32
-O3   -Wall      -m32   -DEPICS_DLL_NO -D_DLL   -I. -I../O.Common -I.
-I.. -I../../../include/os/cygwin32 -I../../../include
-I../../../../base/include/os/cygwin32 -I../../../../base/include
-I/cygwin/usr/include -I/cygwin/usr/include    ../probeUpdate.c
-I/cygwin/usr/include -I/cygwin/usr/include    ../probe_main.c
../productDescriptionShell.c
make[1]: *** No rule to make target `/cygwin/usr/X11R6/lib/Xm.lib',
needed by `probe.exe'.  Stop.
make[1]: Leaving directory
`/cygdrive/c/epics/extensions/src/probe1_1_5_0/O.cygwin-x86'
make: *** [install.cygwin-x86] Error 2
In the file
C:\EPICS\extensions\configure\os\CONFIG_SITE.cygwin-x86.cygwin-x86
Are these the correct settings:?
X11_LIB = c:/cygwin/usr/X11R6/lib
X11_INC = c:/cygwin/usr/X11R6/include
MOTIF_LIB = $(X11_LIB)
MOTIF_INC = $(X11_INC)
Can anyone help me?
Thanks in advance.
Confidencialidad:
Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su destinatario y puede contener información privilegiada o confidencial. Si no es vd. el destinatario indicado, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente respondiendo al mensaje y proceda a su destrucción.
Disclaimer:
This message and its attached files is intended exclusively for its recipients and may contain confidential information. If you received this e-mail in error you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited and may be unlawful. In this case, please notify us by a reply and delete this email and its contents immediately.
Epics extension problems Pacios Rodriguez Luis Orlando
Prev: Epics extension problems Pacios Rodriguez Luis Orlando
Next: RE: MVME 5500 Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: sigsev while creating new gdd in multiple threads Bruno Coudoin
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
