1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MVME 5500
To: GOURNAY Jean-Francois <[email protected]>
Cc: [email protected]
Date: Fri, 19 Jun 2009 08:47:02 -0400
GOURNAY Jean-Francois wrote:
Hello All,
This is a problem which not directly related to Epics, but as several labs are using the MVME5500 CPU I hope that maybe someone has encountered this problem and has a solution!
Whenever a C program has a misbehaved pointer, which causes a memory-write outside the allocated data memory, we have a crash of the CPU which is absolutely understandable, but then, it is impossible to reboot the CPU. Both flash banks containing the initial bootload and the VxWorks boot are corrupted and the only solution is to send back the CPU to the retailer !!! We had experienced this with several CPUs (we are probably bad C programmers) and didn’t get so far any explanation from our retailers or after sales services. We have VxWorks 6.5.
We do not have the problem with the RTEMS-mvme5500 BSP. In that case,
I just have to debug and rewirte the software and reboot the CPU.
However, for vxWorks, I think you should be able to reload the initial bootload and the vxWorks boot yourself. Did'nt they send you the boot files ? I thought I reload the
those vxWorks boot files myself serveral times myself many yeras ago.
Cheers,
Kate
Thanks in advance
J.F. Gournay
CEA Saclay
IRFU/SIS
MVME 5500 GOURNAY Jean-Francois
Prev: RE: MVME 5500 Feng, Kate
Next: Re: MVME 5500 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: MVME 5500 Kate Feng
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
