1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: MVME 5500
To: <[email protected]>
Date: Fri, 19 Jun 2009 13:25:29 +0200
Hello All,
This is a problem which not directly related to Epics, but as several labs are using the MVME5500 CPU I hope that maybe someone has encountered this problem and has a solution!
Whenever a C program has a misbehaved pointer, which causes a memory-write outside the allocated data memory, we have a crash of the CPU which is absolutely understandable, but then, it is impossible to reboot the CPU. Both flash banks containing the initial bootload and the VxWorks boot are corrupted and the only solution is to send back the CPU to the retailer !!! We had experienced this with several CPUs (we are probably bad C programmers) and didn’t get so far any explanation from our retailers or after sales services. We have VxWorks 6.5.
Thanks in advance
J.F. Gournay
CEA Saclay
IRFU/SIS
RE: MVME 5500 Feng, Kate
Re: MVME 5500 Kate Feng
Re: MVME 5500 Andrew Johnson
Prev: needs informations z abdou
Next: Re: needs informations J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: needs informations J. Lewis Muir
Next: RE: MVME 5500 Feng, Kate
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
