1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: problem about environment variables under vxWorks-6.6
To: "Jeff Hill" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Mon, 15 Jun 2009 21:28:18 -0500
Jeff,
Recall that if this is 3.14.10 on a little-endian architecture (e.g. Intel) then there is a bug that causes this message:
>    "The CA server's beacon address list was empty after initialization?"
if EPICS_CA_AUTO_ADDR_LIST=NO
-----Original Message-----
Sent: Thu 6/11/2009 7:36 PM
To: Andrew Johnson
Subject: FW: problem about environment variables under vxWorks-6.6
Andrew,
I sent this message to tech-talk ([email protected]) some time back but maybe it didn't go through. I am suspicious because I sent another one later and it did go through (so this isn't maybe a delay related issue).
Jeff
Sent: Thursday, June 11, 2009 5:45 PM
To: 'EPICS tech-talk'
If EPICS_CA_AUTO_ADDR_LIST is set to YES (the default) then the beacon address list is auto-configured using each of the network interfaces present on the local host. When fetching EPICS_CA_AUTO_ADDR_LIST, if envGetConfigParam returns a nill pointer, the server will decide to auto configure the beacon address list. So perhaps there is a 2nd possibility which might be that the system in question doesn't have any operable network interfaces installed?
Jeff
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Thursday, June 11, 2009 3:34 PM
> To: EPICS tech-talk
> Subject: problem about environment variables under vxWorks-6.6
> This message is from Gongfa Liu, I'm forwarding it while the APS sysadmins
> figure out why all email from DESY is being caught as spam...    - Andrew
> Hi, all,
> I created an ioc application with makeBaseApp.pl for test under the
> following environment:
>    epics base:          3.14.10
>    vxWorks:             6.6
>    target architecture: vxWorks-pentium
> I got a waring message after iocInit:
> This waring message is from ~base/src/rsrc/online_notify.c, I use
> epicsEnvShow(NULL) and epicsPrtEnvParams() to print the environment
> variables at the position where the warning message is created, but
> nothing is printed. It seems that the environment variables set is not
> inherited. What is missing in the vxWorks image? Any suggestions are
> appreciated.
> Thank you.
> Gongfa Liu
> Gongfa Liu                         MKS-2, DESY
> phone:  +49-40-8998-1642           Notkestr. 85
> fax:    +49-40-8998-4388           22607 Hamburg
> e-mail: [email protected]         Germany
RE: problem about environment variables under vxWorks-6.6 Jeff Hill
FW: problem about environment variables under vxWorks-6.6 Jeff Hill
Prev: Re: Installing Protocol Files Tim Mooney
Next: "A32 RegisterAddress error" about Hytec8401 liuping
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: FW: problem about environment variables under vxWorks-6.6 Jeff Hill
Next: RE: problem about environment variables under vxWorks-6.6 Jeff Hill
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
