1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: problem about environment variables under vxWorks-6.6
To: "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Thu, 11 Jun 2009 18:44:33 -0600
Andrew,
This is a 2nd try – this time clipping out Gongfa Liu’s original message which may be triggering some behavior in the mail system.
Jeff
------------------snip-snip-------------
Andrew,
I sent this message to tech-talk ([email protected]) some time back but maybe it didn’t go through. I am suspicious because I sent another one later and it did go through (so this isn’t maybe a delay related issue).
Jeff
-----Original Message-----
Sent: Thursday, June 11, 2009 5:45 PM
To: 'EPICS tech-talk'
>    "The CA server's beacon address list was empty after initialization?"
If EPICS_CA_AUTO_ADDR_LIST is set to YES (the default) then the beacon address list is auto-configured using each of the network interfaces present on the local host. When fetching EPICS_CA_AUTO_ADDR_LIST, if envGetConfigParam returns a nill pointer, the server will decide to auto configure the beacon address list. So perhaps there is a 2nd possibility which might be that the system in question doesn’t have any operable network interfaces installed?
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: FW: problem about environment variables under vxWorks-6.6 Jeff Hill
Next: Re: problem about environment variables under vxWorks-6.6 Liu, Gongfa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: problem about environment variables under vxWorks-6.6 Jeff Hill
Next: Kohzu SC-400 GPIB driver support Konstantin Ignatyev
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
