1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ADEL field in motor record
To: "Pearson, MR (Matthew)" <[email protected]>
Cc: [email protected]
Date: Wed, 10 Jun 2009 10:21:48 -0500
Hello Matthew,
These seem like good enhancements to me.
Ron
Pearson, MR (Matthew) wrote:
At DLS we are currently attempting to reduce our PV archiving load. Some of the data that we archive is effectively noise, so we are setting up the use of ADEL wherever possible. The current version of the motor record doesn't have an ADEL field, which means that if we set an archive monitor on RBV (the motor controller readback value) then we archive every change of RBV, including encoder noise or insignificant servo motor changes. Would anyone have a problem with me adding ADEL to the motor record? The default value for ADEL would be zero, so that no change in default behaviour is seen. But it can then be set to a sensible value for archiving. I would implement it in the same way as it's done for the analogue input record. So this means an additional ALST field for use in the monitor() function. While I'm at it I could also add an MDEL field to enable a value monitor deadband. Cheers,
Matthew
DLS controls
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
ASYN Connection feedback Mathew Hicks
ADEL field in motor record Pearson, MR (Matthew)
Prev: ADEL field in motor record Pearson, MR (Matthew)
Next: RE: Vdct and autosave's info field Alarcon, Arturo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: ca examples Patrick Thomas
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
