1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM Properties Windows
To: Kevin Anderson <[email protected]>
Date: Tue, 9 Jun 2009 09:06:22 -0600
Hello Kevin,
Thanks for your reply. I think I am closer, I figured there was a
setting I was missing somewhere. I attached a screen shot of  what I
am seeing. If you  notice all the text on the left side of the screen
is cut off.
Aaron
On Mon, Jun 8, 2009 at 5:00 PM, Kevin
Anderson<[email protected]> wrote:
> Hello,
> I'm not quite sure what you're referring to, but I did used to have problems with the EDM Properties windows.  As with other Motif applications, the key to customizing EDM's display lies in the .Xdefaults file in your Home folder; editing it might be worth a try.
> If this file does not exist in your Home folder, create it and paste in the following lines:
> *fontList: -*-lucida-medium-r-normal-*-*-100-75-75-*-*-*-*
> edm*background: gainsboro
> edm*XmScrollBar*shadowThickness: 1
> edm*XmScrolledWindow.shadowThickness: 1
> edm*XmPushButton.shadowThickness: 1
> edm*XmCascadeButtonGadget*shadowThickness: 1
> edm*XmTextField.shadowThickness: 1
> edm*XmTextField.marginHeight: 1
> Regards, Kevin Anderson.
>> Hello,
>> I am working with EDM 1.12 to make a control display. Things are going
>> ok, however the various properties windows are not the right size and
>> the titles on the left side of the screen for a lot of the input boxes
>> are cut off. Being that I have not used this program before I have no
>> idea what these boxes control or even what to search for in the
>> manual. If anyone has a suggestion on how to show all the text it
>> would be appreciated.
>> I am using Fedora Core 8, and 7 and this issue happens in a VM windows
>> as well as a regular Linux work environment.
>> I have tried simply resizing the window but the controls in the window
>> do not refresh.
>> There are no scroll bars to show the text.
>> Thanks
>> Aaron
Aaron Joos
Application Engineering
ZTEC Instruments
7715 Tiburon St. NE
Albuquerque NM 87109
Telephone: (505)924-0621
Fax:          (505)342-0222
Attachment: edm.jpg
Description: JPEG image
RE: EDM Properties Windows Kevin Anderson
Prev: Re: misleading error message from dbLoadRecords in Epics 3.14.8.2 Andrew Johnson
Next: problem about environment variables under vxWorks-6.6 Liu, Gongfa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EDM Properties Windows Kevin Anderson
Next: Plotting array of data in striptool Prachi Chitnis
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
