1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: 答复: What is the maximum frequency for db scan?
To: "Dirk Zimoch" <[email protected]>
Cc: [email protected]
Date: Thu, 4 Jun 2009 09:16:46 +0800
Title: 答复: What is the maximum frequency for db scan?
Hi, Thanks. I will try to adjust the frequency.
Wang Qisheng 汪启胜
No.239 Zhangheng Road
PuDong District
Shanghai Institute of Applied Physics CAS
Shanghai, China
Tel: +86-21-33933256  Fax: +86-21-33933031
-----Original Message-----
Sent: 2009-6-2 (星期二) 18:07
To: 汪启胜
Subject: Re: What is the maximum frequency for db scan?
Hello Qisheng
You can just define your own menuScan with higher frequencies. Make sure that
the clock of your IOC can handle that frequency. For example on vxWorks use
sysClkRateSet() to increase the system clock frequency.
The other possibility is to use "I/O Intr" scanning. In that case your driver
must trigger the scanning. If your hardware generates interrupts you can use as
a trigger for scanning, it should not be a problem. Call scanIoRequest() from
the interrupt service function. You can do this as fast as the CPU load allows.
Dirk
汪启胜 wrote:
> Hello, every one.
> Normally the da scan frequency is 0.1s, I want to know how to chang and
> what is the maximum value. For the data acquisition hardware the
> internal clock is very fast, from some threads it is said the vxWorks
> and Epics can handle 60Hz or 100Hz in maximum. Is it possible to
> breakthrough the limit?
> Thanks for your any suggestion.
> Wang Qisheng 汪启胜
> PuDong District
> Shanghai, China
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
What is the maximum frequency for db scan? 汪启胜
Re: What is the maximum frequency for db scan? Dirk Zimoch
Prev: LabView shared memory interface Kevin Tsubota
Next: Converting DEC to HEX Prachi Chitnis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: What is the maximum frequency for db scan? Dirk Zimoch
Next: problem in epics installation K. Kiranbabu
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
