The ColdFire MCF5282 processor has a hardware fault that can be worked
around only by disabling buffered writes. From the Chip Errata
(MCF5282DE, Rev. 6, 5/2009):
SECF124: Buffered Write May Be Executed Twice
Errata type: Silicon
Affected component: Cache
Description: If buffered writes are enabled using the CACR or ACR
registers, the imprecise write transaction generated
by a buffered write may be executed twice.
Workaround: Do not enable buffered writes in the CACR or ACR registers:
CACR[8] = DBWE (default buffered write enable) must be 0
ACRn[5] = BUFW (buffered write enable) must be 0
Fix plan: Currently, there are no plans to fix this.
I've committed the change to the RTEMS CVS repository and attached a
patch you can apply:
patch
Description: Binary data
I ran into this bug in one of my ColdFire/FPGA designs -- some
registers in the FPGA were getting written more often than I expected!
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RE: problem in epics installation Mark Rivers
subArray processing Hinko Kocevar
<2009>
<2009>
