1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS Update
To: [email protected], John Hammonds <[email protected]>
Cc: Tech-talk <[email protected]>, "Chen, Xihui" <[email protected]>
Date: Tue, 19 May 2009 17:03:19 -0400
John Hammonds wrote:
Not working for things like the gauge, tank and thermometer typically means that I have a static value of 50 which is hard coded into the default value hard coded into the display. To get things going to this point I have set the Default Schema to EPICS.
Hi John--
I was just playing with SDS the other day and saw the same thing. For the thermometer and presumably some other widgets, the value is not dynamic, but is set to the numeric value of 50 by default. (I don't know why). You need to right-click on the value on the properties tab and set dynamic aspect to the channel you are trying to monitor.
Steven Hartman
[email protected] || 865-466-6473
CSS Update Kasemir, Kay
Re: CSS Update John Hammonds
Prev: Re: CSS Update John Hammonds
Next: Re: CSS Update John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
