1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS Update
To: tieman <[email protected]>, tech talk <[email protected]>
Date: Mon, 18 May 2009 11:53:37 -0400
Hi:
You're right that "Probe" was simply missing in the
"Basic EPICS" version of CSS.
So was the Preference GUI for configuring Channel Access.
Sorry for having overlooked that. Guess Friday is not a
good time for publishing stuff.
The web page now has new binaries:
 http://ics-web.sns.ornl.gov/css/products.html
The Data Browser should have been OK and still works for me under
OS X (Java 1.5), Redhat Linux  (Java 1.5) and Windows XP (Java 1.6),
so we'll have to figure out why that's not working for you.
On 5/18/09 10:31 , "tieman" <[email protected]> wrote:
> I've downloaded the "Basic EPICS" version of CSS.  I don't see "probe"
> under Diagnostic Tools. ...
> Nothing appears to happen when I select Date Browser from the Trends
> menu...
> Is there a log file to look at to see what the problem might be?
Yes, it's a file
  .metadata/.log
in the workspace directory, which defaults to
  <your home directory>/CSS-Workspaces/Default .
Check the CSS File/Switch Workspace... menu option
to see the current workspace.
-Kay
Re: CSS Update tieman
Prev: Re: Implementation of an EPICS IOC on an Embedded Soft Core Processor Using Field Programmable Gate Arrays David Kline
Next: Re: Re: Implementation of an EPICS IOC on an Embedded Soft Core ProcessorUsing Field Programmable Gate Arrays Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CSS Update tieman
Next: Re: CSS Update tieman
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
