John,
I suspect that this is because the EtherIP is asynchronous device support, and the second time you ask the output records to process they are still busy processing the first request. In that case the second caput does not get sent to the device. If I remember correctly if you change the dfanout output links from PP to CA then the records will process again after they are done.
record(dfanout,"dfout") {
field(SCAN, "Passive")
field(OUTA, "slave1C CA")
field(OUTB, "slave2C CA")
There is not really a queue, but a second request will be honored (but if a third request comes in before the first is done, that will be sent, and not the second one).
Sent: Tue 5/12/2009 5:58 PM
To: Tech-talk
Subject: record linking question
My first message was incorrect - sorry.
I meant to say that the slave pvs update but the device does not. So, I
guess this is an EthernetIP device support question.
So, I will instead ask if anyone has seen this behavior?
John
The following is an attempt to control two slave pvs by a master pv via
a dfanout record.
The desired behavior is that wiggling masterC should cause both slave1C
and slave2C to follow.
record(ao, "masterC") {
field(DTYP, "SoftChannel")
field(OUT, "dfout PP")
field(OUTA, "slave1C PP")
field(OUTB, "slave2C PP")
record(ao,"slave1C") {
field(SCAN,"Passive")
field(DTYP,"EtherIP")
field(OUT, "@cpu epics_outputs[0]")
record(ao,"slave2C") {
field(OUT, "@cpu epics_outputs[1]")
If I create a script as follows:
caput -t masterC 1
caput -t masterC 2
When executed, the result is that sometimes it works (i.e. slave1C and
slave2C have the final value 2) and sometimes it does not (slave1C and
slave2C have the final value 1).
Is the record linking in the above example flawed? If so, is there a way
to make this reliable?
TIA,
John Sinclair
- Re: record linking question Kasemir, Kay
- record linking question John Sinclair
<2009>
<2009>
