The following is an attempt to control two slave pvs by a master pv via
a dfanout record.
The desired behavior is that wiggling masterC should cause both slave1C
and slave2C to follow.
record(ao, "masterC") {
field(DTYP, "SoftChannel")
field(OUT, "dfout PP")
field(SCAN, "Passive")
record(dfanout,"dfout") {
field(OUTA, "slave1C PP")
field(OUTB, "slave2C PP")
record(ao,"slave1C") {
field(SCAN,"Passive")
field(DTYP,"EtherIP")
field(OUT, "@cpu epics_outputs[0]")
record(ao,"slave2C") {
field(OUT, "@cpu epics_outputs[1]")
If I create a script as follows:
caput -t masterC 1
caput -t masterC 2
When executed, the result is that sometimes it works (i.e. slave1C and
slave2C have the final value 2) and sometimes it does not (slave1C and
slave2C have the final value 1).
Is the record linking in the above example flawed? If so, is there a way
to make this reliable?
TIA,
John Sinclair
Re: MEDM 3.1.4 + extensionsTop Bertrand H.J. Biritz
record linking question John Sinclair
<2009>
XAL Workshop Tom Pelaia
<2009>
