1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CAS problem?
To: tech-talk <[email protected]>
Date: Fri, 08 May 2009 16:08:18 +0200
Hi all, (Jeff, Gasper, others?)
Today I got the following error message when trying to read through a CA gateway:
Invalid channel identifier
host=x05da-cagw-psi.ch:5064 ctx=Bad Resource ID=2172742414 detected
at ../../../../src/cas/generic/casStrmClient.cc.1700
On the gateway I found this error log:
--*snip*------------------------------------------------------------
CAS Request: e11277 on x05da-cons-1: cmd=12 cid=2172742414 typ=0 cnt=0 psz=0 avail=1
filename="../../../../src/cas/generic/casStrmClient.cc" line number=1389
postpone asynchronous IO - enum string tbl cache read ASYNC IO postponed ?
May 01 10:28:52 !!! Errlog message received (message is above)
The server library does not currently support postponment of
string table cache update of casChannel::read().
To postpone this request please postpone the PC attach IO request.
String table cache update did not occur.
Any idea what went wrong? Gateway and caget both use 3.14.8.2.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: CAS problem? Jeff Hill
Prev: Re: help for EPICS Zhichu Chen
Next: RE: CAS problem? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: help for EPICS Mauro Giacchini
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
