1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Alarm if no status update received for a given time
To: "Martin Konrad" <[email protected]>, <[email protected]>
Date: Wed, 6 May 2009 11:16:54 -0400
The standard way to handle hardware errors is to have the device support set the alarm severity to INVALID and the alarm state to READ ERROR. The device support defines what conditions are needed to do this - how many reads before it fails. If you want to configure this, you can extend the device support to decide pseudo channels to the driver by using the INF extension. Create ao device support for setting these parameters. The device support for CAN and extend the OUT field with an @TIMEOUT. Make the record passive - and whenever you write to the VAL - this replaces the timeout counter. You can do this per link or per device - whatever you decide.
-----Original Message-----
Sent: Wed 5/6/2009 5:57 AM
To: [email protected]
Subject: Alarm if no status update received for a given time
Hi all,
I'm using some devices via a simple CAN device support for SocketCAN without
support for acknowledged writes etc. The IOC instead periodically asks the
devices for an update and they reply with a CAN packet containing the device
status.
Now my question is very simple: What is the EPICS way of implementing a
timeout which raises an alarm if a device did not answer for a given time? Is
it possible to configure this alarm condition in the database?
Thanks a lot in advance.
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel: 06151-16-5121
Fax: 06151-16-4321
Re: Alarm if no status update received for a given time Ralph Lange
Alarm if no status update received for a given time Martin Konrad
Prev: Failed to create single DLLs on Windows Wang Xiaoqiang
Next: Re: Alarm if no status update received for a given time Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Alarm if no status update received for a given time Martin Konrad
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
