Ø Strangely,
the ioc's that build under areaDetector 1-4 using win32-x86,
Ø do
not have this error on exit and run fine.
One possible difference could be systems with and without SMP
(multi-core cpu or not). Alternatively, statically built or not might change the
order of process rundown as executed by windows (i.e. threads stopped first
versus shareable libraries unmapped from memory first).
Jeff
I'm
building a basic IOC under windows XP by doing the following:
makeBaseApp.pl
-t ioc <name>
makeBaseApp.pl
-i -t ioc <name>
Then
I build the ioc, and run it without databases. The IOC runs without
any initialisation errors. The EPICS version is 3.14.10, and the compiler
is Visual C++ Express 2005. The EPICS build system is set to build
statically.
Upon
exit I get the following errors
CAS: Client accept error was "WINSOCK Error 10004"
CAS: UDP recv error (errno=WINSOCK Error 10004)
..\online_notify.c: CA beacon routing (connect to
"10.123.255.255:5065") error w
as "WINSOCK Error 10093"
or
CA cast server: Unable to fetch N characters pending
Strangely, the ioc's that build under areaDetector 1-4 using
win32-x86, do not have this error on exit and run fine.
Has
anybody had this error ? Why is the IOC expecting a response to a
broadcast like this ? Does anyone know how to fix ?
This message and any attachments may contain proprietary or
confidential information. If you are not the intended recipient or you received
the message in error, you must not use, copy or distribute the message. Please
notify the sender immediately and destroy the original message. Thank you.
- Re: Winsock error10004 J. Lewis Muir
- Winsock error10004 Mark Clift
RE: Winsock errors Jeff Hill
<2009>
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
